Question about Bush Televison & Video
Bushled 32127 hdcntd tv keeps turning off every 30 seconds
Tv turns on for less than 30 seconds and turns off and red light is blinking
Hi John,
TV going off in thirty seconds and red light blinking means there is something wrong inside your Tv and it should not be working in this condition and hence is the "going off" happening. The automatic protection inside is switching your tv off. Please consult some local TV tech. There is nothing you can do about it yourself.
Good Luck.
May 23, 2015 | LG Televison & Video
My 55 e series vizio tv want come on but the vizio logo does
It is possible that you would have pressed a different source like USB or Component, etc. Check it first. In situations like this power recycling too helps. Turn on the TV, after 30 seconds turn it off, remove the power chord from wall unit, keep pressing the on/off switch on the TV (not on the remote) for 30 seconds, release the on/off switch, power the TV and see now whether the TV is working. If not, most probably the main board of the TV may have to be examined for defects.
Mar 21, 2015 | Vizio Televison & Video
Sanyo beeps every 30 seconds
Any timer working? Any keys on the remote are jammed? Do you get the same problem even when you use some other input like a DVD player?
Aug 19, 2012 | Televison & Video
Tv keeps self restarting after about 30 - 45
When lamp in TV become weak in result and consume more current then its rating , TV gets that symptom, on for few seconds/ minutes, shuts down and turns on itself.
Please replace lamp in TV as procedure is written in user manual of TV and its easy.
Let me know if you have further question.
Thanks.
Dec 13, 2009 | Sony KDS-R50XBR1 50" HDTV
My Tv Keeps Turning Off like 30 seconds after i turn it on...
This sounds like your flyback went out on the main board (about 70.00 for part!
This should fix ya!
Dec 12, 2008 | Sansui DTV2760 27" TV
PICTURE AND SOUND KEEP GOING OUT AND COME BACK FOR 30 SECONDS
One of the power supply areas are most likely going intermittent. This can be from cold solder connections on the circuit boards, or from some components failing due to age.
An experienced tech should be able to service your set, but it will be expensive for the time involved. Sometimes these types of faults can be very time consuming to resolve.
Jerry G.
Nov 21, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
SONY Projection TV keeps turning off.
Our Sony TV kept going on and off too. Repairman replaced the lamp, even though red light was never on. Problem solved.
Sony support insisted it was not the lamp if red lamp light was not on. Don't believe it. Picture and sound would go on for 30 seconds, then off for 30 seconds. The new lamp did fix the problem.
Jul 12, 2008 | Televison & Video
Samsung DLP HL-P5063W
you have the same problem I have. The problem is fixed by changing the new light bulb. The problem appears again after 1500 hours of use. You can keep buying new light bulbs or avoid it by not buying another Samsung TV.
Sep 23, 2007 | Samsung DLP HL-P4663W 46" Rear Projection...
TV keeps turning off after 30 seconds
This is usually a sign that a function has not completed or a switch has stuck in an incorrect position. eject can only happen if the sensor (either optical or mechanical senses that a tape is present. The swich might be stuck or the sensor might be blocked or bad. You can open up the unit and try to determine if the sensors are not being blocked by any of the mechanical parts of the unit. You will need the service docs to show you where the components are located. I hope this helps. Shuttle83
Feb 16, 2007 | Symphonic SC3813 13 in. TV/VCR Combo
Televison & Video Logo
21 people viewed this question
Top Bush Televison & Video Experts
Joseph Hoffmann
Are you a Bush Televison and Video Expert? Answer questions, earn points and help others
