Question about Tasco Essentials 165BCR (8x21MM) Binocular
Prism came apart need assy instructions - Tasco Essentials 165BCR (8x21MM) Binocular
  • 26 Answers
You dont say what kind of bino it is....if its cheap model probably not worth repair and shipping charges.if i can be of further help call 5088331232...larry
Posted on Jun 22, 2009
How do I get rid of the dark shadow across the top of the screen?
This is actually a fairly common issue with the NEC projectors, especially if they are mounted from the ceiling (upside down). The problem is the compartment immediately after the bulb. What happens is the 'paste' they use to adhere the glass prisms to it's plastic component wears off overtime due to the immense heat from the bulb being projected onto it. The glass prism piece ends up leaning against the bulb compartment creating the annoying 'shadow'.
Heads up; you will need to take apart almost the whole projector. You'll need to expose the mirror array to get to the compartment just after the bulb. Once you've dissassembled the projector down to the mirror array, take out the problem part. It's a small black plastic cube frame that's held in by a screw and has 3 glass/plastic prism pieces. Looking down at the disassembled projector, you may not be able to see the glass/plastic prism pieces but I can assure you that it is the small compartment immediately after the bulb compartment.
Once you've identified the component and taken it out, you'll see the prism piece(s). The problem prism is the one that sits closest to the bulb and it was either slightly loose or had fallen off completely. Please note that there is another one of these exact prisms on the other side of the assembly you pulled out just behind the plastic looking prism. This secondary one come loose very rarely but if it does, you'll need to fix that too.
The Fix: Since the component is going to be exposed to immense heat again, you'll need to buy an adhesive that can withstand that heat (think at least a few hundred degrees for safety sake). I bought the JB-Weld Steel Reinforced Epoxy since it can withstand heat up to 550F. Make sure you read the instructions before starting. An added suggestion is to scrape all the old residue from the old adhesive off the component and prism(s) first, then scratch some grooves into the connecting pieces and apply the epoxy/adhesive. Do not scratch up the actual prism itself; scratch the 'extra' glass on the prism piece where it will connect with the plastic component. The grooves help the epoxy bind to the pieces and I highly suggest this since I've had to re-do a few in under a year. Let the epoxy set for a good 24 hours before putting the projector back together.
Nov 03, 2014 | NEC NP400 Projector
Sony VPL-CS5
you must change the lens. the cost is high. see the sony site for replace the parts.
Sergio
Mar 27, 2008 | Sony VPL CS5 Multimedia Projector
How do I clean the Prism/LCD assembly on Eiki LX-85
LCD panels with the prism assembly,
put the assembly into the water,clean with some kitchen cleaners
to dry the assembly up with hair dryer
suggestion: keep the panels and the prism as a assembly,do not take the panels apart from the prism.
any questions, feel free to contact me
We supply original projector lamp,bulb,accessories,Lcd panel,Lens,DMD chip,color wheel,motherboard,powersupply,ballast... with high quality and competitive price.
have a nice day!
Jerry,Lampdeng Limited
skype:lampdeng
Mar 03, 2014 | Office Equipment & Supplies
Dirt on the prism LCD assembly
LCD panels with the prism assembly, put the assembly into the water,clean with some kitchen cleanersto dry the assembly up with hair dryersuggestion: keep the panels and the prism as a assembly,do not take the panels apart from the prism.
Mt Tmobile Prism is locked, How do i unlock it?
You can unlock your T-Mobile Prism easily by using an unlock code.You can get this code with easy step by step unlocking instructions from Mobile-Unlocker.com .
Sep 13, 2013 | Huawei Prism U8651t Grey t-mobile
94 geo prism replace wheel bearing assy
Rear are a HUB ASSEMBLY and replaces as a Unit. Same for the Front. Remove the Axle Nut, Remove the Brakes, Remove the 3 or 4 Bolts and the hub will come off.
Apr 09, 2013 | 1994 Geo Prizm
Require unlock code nokia 7500
Hi, to which UK network has your Nokia 7500 Prism been locked to? you can visit www.SimpleUnlocking.Com to get the accurate unlock code for your Nokia 7500 Prism at affordable cost with free step by step unlocking instructions. Good luck mate.
Feb 16, 2013 | Nokia 7500 Prism
There is a purple image showing even when there are no cables connnected. Is this something wrong with the optical engine? I read this somewhere.
If the entire image is indeed purple from corner to corner uniformly, I'd say maybe one of your lcd ribbon cables is not plugged in all the way. BUT--- if the purple is like a blob in the center but not quiet spreading out to each corner, one or all of your lcd panels/polarizers in the prism assy is burnt and the prism assy will have to be replaced. Very expensive.
Nov 01, 2010 | InFocus LP 540 Multimedia Projector
When I on the projector on blue screen one black big spot coming
broken lcd panel, entire optical prism assy to be replaced, costly !!
Jul 11, 2010 | Eiki LC-XB28 XGA LCD Projector Multimedia...
We had a fire and my binos got smoked inside. I took apart the front and cleaned the prisms in front and lenses. How do I access the back prisms? How do i get the cover off the prisms at back of binos.
most prisms have coating on their air to glass surfaces. Chances are you have already degraded their original quality, even with the smoke gone. From past exp. you will be better of getting another bino...
Feb 16, 2010 | Bushnell Legend 19-1050 (10x50) Binocular
Tasco Essentials 165BCR (8x21MM) Binocular Logo
71 people viewed this question
Top Tasco Optics Experts
Marvin
Marvin
ray gallant
Are you a Tasco Optic Expert? Answer questions, earn points and help others
