Question about Baumatic 23 in. BDW13 Built-in Dishwasher
Why does the 40 amp starter fuse blows on 2008 impala
I have a 2011 kia Sorento that continues to blow the 40 amp ignition fuse under the hood. Replace the fuse...runs a couple days then blows again. We have replace relays and fuses and checked starter..
Starters will still work when worn but will have increased drag drewing too many amps. which will blow your fuses. before replacing older starter first remove all wire connections shiny clean and replace. make certain starter is tight to block(this is your ground. ) Important to remove ground cable from battery before working on starter.
May 07, 2017 | Kia Cars & Trucks
Blowing 40 amp fuse when trying to start
check that the small wire on the solenoid is not touching the big terminal on the starter solenoid or is not shorting out any where .
Apr 22, 2014 | 1991 Dodge Dakota
I have a 2008 impala the remote start will not work the re mote locks work and there is no check engine light on
your remote starter has 2 fuses, please check them both. if they are good, your remote starter is at fault
Jan 02, 2011 | 2008 Chevrolet Impala
40 amp ignition fuse blew. I replaced the fuse and now the lights all go on when the key is turned on but the vehicle will not start...or even try to start. The battery is fully charged.
The 40 amp maxi fuse in the underhood junction block (According to the information I have, there is only one 40 amp fuse in there..) goes directly to the ignition switch. From there, it goes to the buss bar in the Instrument Panel Fuse Block where it feeds several smaller fuses. It also feeds the starter relay in the Underhood Fuse and Relay Center.
My biggest concern would be: What caused the fuse to blow in the first place?
If you get nothing else from my preaching, get this:
Fuses don't blow for no reason....ESPECIALLY not a 40-amp Maxi Fuse!
I can't count how many times I have heard people say: "It's JUST a blown fuse." WHAT???
I have been at this for 35 years and I can tell you that blown fuses are reason for major concern in my book. That 40-Amp Maxi Fuse just saved your truck from burning to the ground and you need to find out why!
The only way that fuse is going to blow is if there is a direct short to ground between the Underhood Fuse and Relay Center and the Instrument Panel Fuse Block (The only "component" between these two is the ignition switch.) or if the secondary side of the starter relay circuit is shorted to ground. The secondary side of the starter relay feeds the "S" terminal of the starter solenoid. (at the starter)
I think the first place I would look for the problem would be the circuit between the starter relay and the starter. It is likely to be shorted against the exhaust or engine block. If this is the case, it most likely fried the starter relay in the process. (which is why the fuse no longer blows and the engine no longer starts)
Aftermarket remote starting units are also usually tied into this circuit. If your vehicle has one of these, it could very likely be the original source of your problem.
At any rate, there should be no rest, truck running or not, until the reason for the blown fuse is found. You will most likely get the truck running in the process of locating the reason for the blown fuse.
Nov 23, 2010 | 1996 Chevrolet Suburban
40 amp starter fuse keeps blowing. Before I start "blowing" money, is it the starter?
It could be. A 40 A fuse is one of the bigger fuses.
It's either the starter or the wiring to it.
Oct 27, 2010 | 1997 Dodge Dakota
2002 chevy van 2500 when i turn key to start van
Fuses only blow if-Old,Overheated or you have a Short circuit.
That should be any easy fix,to the extent that there aren't many 40 Amp Fuses and you will need a wiring diagram to follow the problem from the fuse to the cause. If you know what fuse it is, you can guess,but I wouldn't recommend that,it will be time consuming and maybe costly ,if you don't have a test procedure to follow and throw parts at it.
Don't replace the fuse.Their expensive and will keep blowing.
May 05, 2010 | 2002 Chevrolet Express
1999 Chevy Venture 40 amp fuse keeps blowing when I try to start the van. This happened on three seperate days. I drove 150 miles and stopped the van. The could not start the van again. When I try to...
make sure of two things one is any wires touching at the starter to ground or melted and or is the starter drawing too much amperage causing the fuse to blow.starter may have a dead short in it.
Aug 16, 2009 | 1999 Chevrolet Venture
2003 Cavalier Keeps blowing the 40 amp fuse in BATT2
I'm sure there's a short somewhere, but I can't find it. I've even replaced the starter and it is still doing it..???????
The wiring that fuse protects is shorted to ground ! You don't know how to find a short ? Your best bet ,take it to a shop that can .
Finding The Source Of Electrical Shorts In Your Car
Aug 01, 2017 | Chevrolet 1500 Cars & Trucks
Baumatic 23 in. BDW13 Built-in Dishwasher Logo
13 people viewed this question
Top Baumatic Dishwashers Experts
Oloyede Monsuru
Kolbrun...
Are you a Baumatic Dishwasher Expert? Answer questions, earn points and help others
