Question about Garden
Macallister pro50 type TD534TR
Serial number of pull cord spring casing
3 Suggested Answers
  • 76 Answers
SOURCE: spring for pull cord broken
Hi
follow the instruction in :
http://www.cockeyed.com/lessons/mower/mower01.shtml
hope it helps
good luck
Posted on Jul 20, 2009
  • 760 Answers
SOURCE: Pull start cord got pinched. Dumb me took off
Yes you can put the spring back in but it takes patience. Wind the spring inside the pully first. Then install the cord on the outside of the pully. Make sure you wind both in correct direction. You probably should replace the cord while you have it apart. The parts would be listed by the engine brand and model number, not by MTD. Probably a Briggs & Stratton engine? You can go to their web site :www.briggsandstratton.com to get part numbers. Or you can try a place like www.jackssmallengines.com
Posted on Jul 18, 2010
Procedure for replacing pull cord on my mcCulloch M1255 CLS
The first thing you do is to reattach the pull cord to the pulley. If you are lucky both ends of the spring are where they belong. To test this turn the pulley in the the direction the pulley would turn when the starter cord is pulled and see if you can feel the spring winding up.If you can not you will need to pull out pully out and attach the the spring on one end to the pully and the other end to the case. After that you find a notch in the pulley. Place the cord in the notch and start winding the spring. The cord should not be winding up on the pully.Now take the cord out of the notch and let it wind up on the pulley.If the cord is not fully wound up you repeat the process till the rope is wound up all the way.
Sep 05, 2014 | Garden
Pull cord on homelite ut20006 trimmer
on the side where the pull cord was remove casing pull the cord through the hole on the casing wind the spring back on the strimmer not to tight but tight enough for the cord to return once pulled. Attach the cord onto the spring this will be obvious there is a little hole the cord goes through then pull a bit of cord through tie a nott then pull the cord back so the nott is tight against the spring ,let the spring spring back the gord shoul wind onto the spring reattach the casing and job done hope this helps
Apr 21, 2012 | Homelite Mighty Lite Lawn Trimmer
Model #911503 ,serial #000278 The pull
Here a couple of links with instructions on replacing your rope... Text Good Luck
Jul 03, 2011 | Ariens 21 In Classic Walk Behind Push Lawn...
Jul 18, 2010 | Mtd 22" Yard Machine Push Mower
Cant remember how to put the spring back on the pull cord recoil
This reply is based on the following assumptions:
A Poulan PP2375LE (wildthing) Type 2
The starter recoil spring is unwound.
All components aer servicable
Poulan 2375LE Type 2 IPL
http://www.ordertree.com/modelinfo/PWE/2375LE-Gas-Saw-Type-2/75.2375LE-Gas-Saw-Type-2.1.59.1.html
Starter components and reassembly order are illustrated on the "Handle, Chassis & Bar Assembly" detail.
If the spring needs rewound this is how I do it, there are other methods.
Recoil Spring Rewind
I invert and secure the housing and rewind the spring large coil to small (need eye protection, and both hands). I am right handed so I tension the spring enough to insert it inside the previous coil while holding what has already been installed with my left about 180° from my right hand. The tension will hold the spring in the housing once completely inserted. Then bend slightly the inner most part to engage the starter spool.
This illustrates proper pretension and rope installation:
Smalleng.com (about 3.5 minutes long and worth watching the entire video)
http://www.youtube.com/watch?v=eRyy3MlsjVo
If yours is not a Type 2 you can find the correct IPL here:
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
The dash number of your serial number is the type.
I hope this was helpful
Lou
Jan 29, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
I need to replace the pull cord and put the pull cord spring back in its casing on a Yamaha 250 ATV. Milly
okay,after you have dissembled replace pull cord set aside now place the spring into the casing by catching the end into the retaining slot and wind it down into the casing hang onto to it now feed the cord end thru the hole afix handle onto cord then place into casing make sure that the spring and cord pulley dog together now holding pulley down in casing pull alittle cord out between case housing and pulley and preload spring by turning pulley around with cord 4 to 6 times secure pulley you should be all set good luck
Nov 18, 2009 | 2003 Yamaha YZ 250
Pull cord stays out. Mechanic says I need new
check with home depot on parts for a homelite.
Oct 21, 2009 | Homelite Mighty Lite Lawn Trimmer
How to re assemble recoil spring on macallister pro 50 lawn mower. I have inherited this machine which has only been used a few times and the previous owner has given up on it. The whole recoil housing has...
Hello there it is hard to do but with patients you can put a loop of tape or a cable tie around the start of the coil and everytime you rewing the coil you can put it under the loop to keep it in place hope this helps
Sep 26, 2009 | Garden
Pull cord on weedeater wont recoil
sounds like the spring is broken itself.there should be a hook at one end and a loop at the other end.the hook usualy breaks off but the spring looks good.replace the spring with part number..4140 190 0600 ....that is the stihl part number.let me know if this helped you...if not give me a quick mail and i'll try to help some more......
Mar 12, 2009 | Garden
Garden Logo
49 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
