Question about Canon Office Equipment & Supplies
I have a canon machine ir 3035,when ever you switch the machine on it says set the finisher as far as it can go which i did but its still persisting could you plz tell me what to do thank you
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 118 Answers
The problem cause could be the machine detects that the finisher is not positioned properly if you can detached the finisher from the machine check a hole in the finisher that match a protrusion from the machine , it pushes an interrupter to tell the machine that a finisher was in the correct position. to check fold a small piece of paper and push in to the hole( while the finisher is detached) check the display panel, hope this will help
Posted on Jun 29, 2009
The copier Ir 2570 its Opc drum in which copier is Equiverant to
The drum for Canon Ir 2570 is also equivalent to this machines: Like Canon IR 2230
Like Canon IR 2270
Like Canon IR 2530
Like Canon IR 2570
L ike Canon IR 3530
Like Canon IR 3570
Like Canon IR 2830
Like Canon IR 2870
Like Canon IR 4530
Like Canon IR 4570
Like Canon IR 3030
Like Canon IR 3025
Like Canon IR 3035
Like Canon IR 4035
Like Canon NPG 25
Like Canon NPG 26
Jul 30, 2017 | The Office Equipment & Supplies
MY canon iR3035 ccd scanner position is faulty..
Re: canon ir 3035 copy not lined up 1/4 inch higher it scans but configuration page i
service mode > copier > adjust > adjust xy > adjust Y input the value from the label on the front cover
This is all I could find. Try adjusting by 1/4 inch. Thank you Santosh
Jun 25, 2016 | Canon imageRUNNER 3035 Black and White...
How do i fix power on paper jam on canon ir 3035 copier?
Probably one of the sensors on the papers way through the machine is out of position,or not working
Mar 05, 2015 | Canon Office Equipment & Supplies
MY CANON IR 3035 START UP PROBLEMS
you are not very clear in you problem but i think that maybe you have to make the firmware first of the copier and than if does not work change the hdd and again firmware.
Oct 31, 2014 | Canon iR3035 Copier
E000808 0000
Please What can the solve of Problem Restart the machine if problem persists call service rep. error message : E000808-0000 model canon ir 2420L
Nov 30, 2013 | Computers & Internet
CANON ir 3530 finisher error
canon ir 3530 shows finisher error (displays spanner)
Nov 10, 2012 | Canon gpr-16 ir 3530 blk...
Canon xerox machine error code E000007 000 how it is solve the problem
This is a fuser temperature issue, it can be cleared in service mode but if the problem persists after being cleared then the fuser may need to be rebuilt or replaced. To clear press:
additional functions
2+8
copier
function
clear
err
ok
shut down and turn on with switch on the side of copier
Sep 20, 2011 | Canon imageRUNNER 3035 Black and White...
My canon machine is IR 3035 and having a error code E000001-002 How can I fix this.
this is error code for abnormal temperature rise in fixing section.
You can try to reset error in service mode, but if the problem persist you need to change the fixing film unit.
To reset the error:
1) Press the asterisk key " * " on the control panel.
2) Press the 2 and 8 keys of the keypad at the same time.
3) Press the asterisk key " * " on the control panel.
Choose: COPIER>FUNCTION>CLEAR>ERR.
Turn off and back on.
Hope that helps!
Aug 22, 2011 | Canon imageRUNNER 3035 Black and White...
I have a canon copier ir 3035, its giving error code E000002-0000, whars the problem?
this error is power related. reset the fixing error by pressing * 2 & 8 then * Go to function, clear, error switch off the machine then switch on
Aug 21, 2010 | Office Equipment & Supplies
Canon 3035 missing drawer options
On your computer go to the start menu,select control panel,printers and faxes,right click on the ir 3035 driver,select properties from there go to device settings.In the paper source options inable the casette unit.
Then you will be able to print from the extra cassette unit.
Mar 13, 2009 | Canon imageRUNNER 3035 Black and White...
154 people viewed this question
old marine
old marine
