Question about Wascomat Parts Wascomat F131900200 Washer VALVE,WATER 115V WE17 - Wascomat Laundry P
Why does the washer say OD when the door is locked
HELP ~ My washer code is od and it will not do anything. Thank you ~ Gail
od-means the door has not been opened since the last cycle.
try opening the dorr ands shutting it hard. If the code still comes up then reset the unit at the breaker box. Leave the breaker off for 1 to three minutes then check the unit. If the code is STILL there then the door lock is malfunctioning.
Sep 07, 2011 | Maytag Neptune FAV6800AW Top Load Washer
When i start the washer, i get an error od and the washer does not lock
'od' stands for Open Door (fault). There is likely to be a problem with either the door solenoid/lock or the 'door closed' sensor. Both require a service engineer's attention I suggest ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Apr 30, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Won't start/"od" displayed
Yes, OD is a open door error code. You may need a new door latch assembly. pn 22002262.
Jul 23, 2010 | Maytag Neptune MAH5500B Front Load Washer
Od litght is on but door is closed
OD Opened Door not sensed by machine control board Machine control board did not see the door open prior to the beginning of a new wash load. 1.Open and close door, then restart washer. 2.Check wire connections in harness leading from machine control board to door lock mechanism.
3.Check door monitor switch for welded contacts.
4.Check inputs and outputs at machine control board.
May 28, 2010 | Maytag Neptune MAH5500B Front Load Washer
Flashing od
If your machine is a FAV6800AW or FAV9800AW see if this post will help you clear the OD error code on your machine.
Sep 22, 2009 | Maytag Neptune FAV6800AW Top Load Washer
"od" on screen
OD = Open Door.
Your door latch senssor has failed - or the door is not shut completely.
For the od error, open the door and jiggle the locks. It's possible that soap has gotten there and is making them not knock whatever it is they need to knock to register that the door has opened. You might need something fairly long and thin such as jeweler's screwdrivers.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
May 14, 2009 | Maytag Neptune MAH5500B Front Load Washer
How do you replace left lid lock on Maytag Neptune washer
Problem may be with door switch and not the door lock. If you are able you could try to locate the switch and jump the two wires together to see if the od code goes away. Even if it works you should not leave it that way but get a new switch and replace the faulty one.
Feb 25, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Od code
od code is supposed to mean that lid has not been opened for the last 3 completed cycles. Also, apparently you tried the service mode and found the door lock to be working. So, unless the problem is with the electronic board itself the only other thing that could be happening is a faulty sensing switch at the door lid or a bad connection to it. I would try shorting the leads from the switch and see if the problem goes away. Then you might just need a new switch.
Feb 15, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Wascomat Parts Wascomat F131900200 Washer VALVE,WATER 115V WE17 - Wascomat Laundry P Logo
55 people viewed this question
Top Wascomat Parts Washing Machines Experts
Are you a Wascomat Parts Washing Machine Expert? Answer questions, earn points and help others
