Question about Mtd 22" Yard Machine Push Mower
How to remove spark plug - Mtd 22" Yard Machine Push Mower
    Habit-Forming:
  • 34 Answers
I have attached an article about how to change the spark plug on a walk behind mower.
The directions should be roughly the same despite the difference in brand and model.
I hope this helps!
How to Change the Spark Plug on Toro Recycler Self Propelled Mower
Posted on Oct 06, 2015
Spark plug wiring diagram for a 2003 chevy malibu
SPARK PLUG WIRE REPLACEMENT (ENGINE CONTROLS - 3.1L)
Removal Procedure
  1. Turn OFF the ignition.
  2. Notice: Twist the spark plug boot one-half turn in order to release the boot. Pull on the spark plug boot only. Do not pull on the spark plug wire or the wire could be damaged.
  3. Remove the spark plug wires 2, 4, and 6 from the engine left side spark plugs.
  4. Remove the spark plug wires from the retaining clips.
  6. Remove the spark plug wires 1, 3, and 5 from the engine right side spark plugs.
  7. Remove the spark plug wires from the retaining clip.
  9. Remove the spark plug wires from the ignition coils.
  10. Remove the spark plug wires from the engine.
  11. If you are replacing the spark plug wires, transfer any of the following components:
    • Spark plug wire conduit
    • Spark plug wire retaining clips
Installation Procedure
  1. Install the spark plug wires to the engine.
  2. Install the spark plug wires to the ignition coils.
  4. Install the spark plug wires 1, 3, and 5 to the engine right side spark plugs.
  5. Install the spark plug wires to the retaining clip.
  7. Install the spark plug wires 2, 4, and 6 to the engine left side spark plugs.
  8. Install the spark plug wires to the retaining clips.
v\:* { behavior : url(#default#VML); position:absolute; } v\:* { behavior : url(#default#VML); position:absolute; }
Aug 20, 2014 | Vehicle Parts & Accessories
Replace spark plug's
Things you will need
Spark Plug Socket And Wrench of the correct size for your spark plugs
Basic Instructions.
Step 1
Locate your spark plugs
look for other obstructions besides your spark plug wires
if you have any other obstructions you will need to remove them as well to gain access to your spark plugs.
Step 2
Remove the spark plug wire for one single spark plug at a time.
this will insure you will not replace the wrond spark plug wire to the incorrect spark plug,
if not done this way you could change the firing order of your engine.
Step 3
With your spark plug Socket and wrench rotate the spark plug in a counter clock wise direction for removing.
Step 4
After you have removed your spark plug insert your new replacement spark Plug into your spark plug socket before inserting it into the correct location. spark plug sockets are made to hold on to the spark plug for easy removal and install.
Step 5
insert your new spark plug,
before you rotate your spark plug for tightening rotate the spark plug a 1 quarter turn in the counter clock wise direction, then start tightening the spark plug by rotating it in a clockwise direction
This will insure you will not strip the threads.
Step 6
Continue rotation your spark plug in the clock wise direction untill snug, then with just a lil more pressure tighten it up just a little more.
be sure to not put to much force on the spark plug after it has been snug, you just have to apply a little more pressure but not to much that could cause it to break.
Step 7
After tightening the spark plug replace the correct spark plug wire.
then move on to the next spark plug and follow the same instructions.
if you have any other visiable obstructions preventing you access for replacing your spark plugs you will need instructions on how to remove them parts. i have just instructed you on how to remove and reinstall the spark plugs only.
Feb 16, 2013 | 2008 Mazda Tribute
How many spark plugs are on the mercury milan 2007. I only found 3.
For 2007 Mercury Milan 3.0L SFI DOHC 6cyl the upper intake manifold must be removed to access the RH spark plugs only.
  1. Remove the upper intake manifold, if removing the RH spark plugs. Refer to the Intake Manifold procedure in the Engine Mechanical Section
  2. Disconnect the 6 ignition coil-on-plug electrical connectors.
    NOTE When removing the ignition coil-on-plugs, a slight twisting motion will break the seal and ease removal.
  3. Remove the 6 bolts and the 6 ignition coil-on-plugs.
    WARNING Only use hand tools when removing or installing the spark plugs, or damage can occur to the cylinder head or spark plug.
    NOTE Use compressed air to remove any foreign material in the spark plug well before removing the spark plugs.
  4. Remove the 6 spark plugs.
To install:
  1. Inspect the spark plugs, as outlined in this section.
  2. Inspect the 6 spark plugs.
  3. Adjust the spark plug gap, as necessary, to 1.32-1.42mm (0.052-0.056 in.).
  4. Install the 6 spark plugs. Tighten to 15 Nm (11 lb-ft).
    NOTE Apply a small amount of dielectric grease to the inside of the ignition coil-on-plug boots before attaching to the spark plugs.
  5. Install the 6 ignition coil-on-plugs and the 6 bolts. Tighten to 7 Nm (62 lb-in).
  6. Connect the 6 ignition coil-on-plug electrical connectors.
  7. If removed, install the upper intake manifold
Hope helps.
Mar 07, 2011 | 2007 Mercury Milan V6 AWD Sedan
Describe your how fix my pontiac 2000 montana Problem changing spark plugs
Inspection
Inspect for the correct routing of the spark plug wires. Improper routing may cause cross-firing. Inspect each wire for any signs of cranks or splits in the wire. Inspect each plug wire boot for tearing, piercing, arcing, carbon tracking or a corroded terminal.
If there is any corrosion, carbon tracking or arcing indicated on a plug wire boot or terminal, both the plug wire and component it was connected to should be replaced.
Removal & Installation
3.5L Engine
  1. Before servicing the vehicle, refer to the Precautions Section.
  2. Remove the left side spark plug wires from the spark plugs.
  3. Remove the left side plug wires from the retaining clips.
  4. Rotate the engine for access as follows:
    1. Set the parking brake.
    2. Shift the transaxle into neutral.
    3. Remove the engine mount strut bolts. Swing the engine mount struts aside.
    4. Install the Engine Tilt Strap J-41131.
    5. Pull on the engine in order to rotate the engine forward.
    6. Tighten the strap.
  5. Remove the right side spark plug wires from the spark plugs.
  6. Remove the plug wires from the retaining clip.
  7. Remove the spark wires from the ignition coils.
  8. Remove the plug wire assembly from the engine.
    NOTE If you are replacing the spark plug wires, the spark plug wire conduit and retaining clips should be transferred to the replacement wires.
To install:
  1. Install the right side plug wires to the ignition coils and then the spark plugs.
  2. Install the spark plug wires to the retaining clip.
  3. Rotate the engine back to the original position.
  4. Install the left side spark plug wires to the ignition coils and then to the spark plugs.
  5. Install the spark plug wires to the retaining clips.
3.9L Engine
  2. Remove the intake manifold cover.
  3. Remove the left side spark plug wires as follows:
    1. Disconnect the left side spark plug wires from the spark plugs.
    2. Disconnect the left side spark plug wires from the ignition coil.
    3. Remove the left side spark plug wire clips from the intake manifold and heater inlet and outlet pipe.
    4. Remove the left side spark plug wire assembly.
  4. If removing the right side spark plug wires, the engine must be rotated for access as follows:
  5. After rotating the engine, remove the right side spark plug wires as follows:
    1. Disconnect the right side spark plug wires from the spark plugs and ignition coil.
  6. Remove the right side spark plug wire clip from the ignition coil bracket.
  7. Remove the right side spark plug wire assembly.
To install:
  1. Install the spark plug wire assembly.
  2. Install the right side spark plug wire clip at the ignition coil bracket.
  3. Connect the plug wires to the ignition coil and spark plugs.
  4. If the engine was rotated for access, return the engine to the original position.
  5. The remainder of the installation is the reverse order of removal.
Feb 05, 2011 | 2000 Pontiac Montana
Where are you spark plugs on a 2006 Ford Fusion. I have changed many vehicles Spark Plugs but Im not familiar with this model and do I have to remove the intake manifold to get to them ???
Inspection & Gapping
Fig. Inspect the spark plug to determine engine running conditions
2.3L Engine
  1. Disconnect the negative battery cable.
  2. Remove the 2 nuts, the bolt and the alternator air inlet duct.
    Fig. Remove the 2 nuts, the bolt and the alternator air inlet duct-2.3L engine
  3. Disconnect the 4 ignition coil-on-plug electrical connectors.
    NOTE When removing the ignition coil-on-plugs, a slight twisting motion will break the seal and ease removal. Remove the 4 bolts and the ignition coil-on-plugs.
  4. Remove the 4 spark plugs.
To install:
  2. Adjust the spark plug gap, as necessary, to 1.25-1.35mm (0.049-0.053 in.).
  3. Install the spark plugs and tighten to 12 Nm (9 lb-ft).
  4. Install the 4 ignition coils and bolts and tighten to 10 Nm (89 lb-in).
  5. Connect the 4 ignition coil electrical connectors.
  6. Install the alternator air inlet duct and the 2 nuts and the bolt. Tighten to 6 Nm (53 lb-in).
  7. Connect the negative battery cable.
Oct 12, 2010 | 2004 Toyota Corolla
How do i change my spark plugs on suzuki c50 motorcycle
No. 1 (FRONT) SPARK PLUG REMOVAL
• Remove the rear and front seats.
• Remove the fuel tank.
• Remove the right frame cover 1 (remove hooked part)
• Remove the spark plug cap
• Remove the spark plug with a spark plug wrench.
No. 2 (REAR) SPARK PLUG REMOVAL
• Remove the spark plug cap.
Hope this help you quest. Good enough?
Apr 18, 2010 | 2005 Suzuki Boulevard C50
Replace Spark Plugs
What size engine have your behicle?
2.2L Engine
  1. Remove the ignition coil housing.
    NOTE Remove any water and debris from the spark plug holes before spark plug removal with compressed air. Remove the spark plugs with a spark plug socket.
  2. Inspect the spark plugs.
To install:
  1. Gap the spark plug, using round wire type spark plug gap gauge. Adjust the spark plug gap to 0.045 in. (1.14mm).
    WARNING DO NOT coat the spark plugs with anti seize compound. Over torquing could occur and damage to the cylinder head threads may result.
  2. Install the spark plugs with a spark plug socket. Tighten to 15 ft. lbs. (20 Nm).
  3. Install the ignition coil housing.
2.4L Engine
The spark plugs on this engine are located under the ignition coil and module assembly. To gain access to the spark plugs, the coil and module assembly must be removed. On the 2.4L (VIN T) engines, the spark plugs are platinum and require replacement every 100,000 miles (160,900 km) or 60 months which ever comes first.
  2. Remove the 4 bolts retaining the Electronic Ignition (EI) coil/module/cover assembly (depending upon vehicle application), then detach the electrical connector. Remove the assembly by pulling it straight up away from the engine.
    Fig. To remove the cover, unfasten the four bolts, then pull the assembly straight up from the engine
  3. If the connector(s) sticks to the spark plug, use spark plug connector removing tool J-36011 or equivalent, and a twisting motion to detach the connector(s) from the plugs.
  4. Clean any dirt away from the spark plug recess area.
  5. Remove the spark plug using the proper size socket, extensions and universal joints, as necessary. Hold the socket or the extension close to the plug with your free hand, as this will help lessen the possibility of applying a shear force which might snap the plug in half.
To install:
  1. Lubricate the threads lightly with an anti-seize compound, then start the four spark plugs by hand. Tighten the plugs to 14 ft. lbs. (19 Nm).
  2. If removed, install any the plug boot connectors that may have stuck to a spark plug to the EI assembly.
    NOTE Check to make sure the spring terminal is inside the boot.
  3. Install the EI coil/module/cover assembly to the engine, while carefully aligning the boots with the spark plug terminals, by pushing the assembly straight down.
  4. Apply Loctite®thread locking compound, or equivalent to the cover bolts. Install the bolts and tighten to 16 ft. lbs. (22 Nm).
  5. If removed, engage the ignition cover electrical connectors.
  6. Connect the negative battery cable.
I really hope helped with this (remember rated this help) Good luck.
Nov 27, 2009 | 2003 Pontiac Grand Am
Change sparks plugs on 06 hyundai sonata v6
You didn't specify whether you have the (4) cylinder or the (6) cylinder engine..... I have a 2004 Hyundai Sonata 2.4L 4 cylinder and I just changed the spark plugs in it. I believe that the 2005 2.4L engine is the same. To locate and change the (4) spark plugs on a 2004 Hyundai 2.4L 4 cylinder engine: Remove the (4) 12mm bolts from the decorative plastic engine cover. Remove plastic cover from engine and place it off to the side out of your way. Standing in front of the car, the (4) spark plugs are located laterally (left to right) in the recessed area underneath where the plastic engine cover was removed. Note: This engine has (2) coils....They are located above spark plugs number (2) and (3) from left to right. Starting with the fist spark plug on the left: Remove the spark plug cable by pulling straight up on the insulated connector. Using a spark plug socket, remove the old spark plug and install a new one in it's place. To access the second spark plug from the left, remove the electrical connector and the spark plug cable wire from coil number (1) and then remove the (2) 12mm bolts that secure the coil to the engine. Spark plug number (2) is located directly under the coil. Lift the coil straight up removing the insulated connector from spark plug number (2). Using a spark plug socket, remove old spark and install a new one in it's place. Repeat same procedures for spark plugs number (3) and (4). Note: If you have the (6) cylinder engine, the front (3) sparks pluge are readilly accessible but in order to access the (3) rear spark plugs, you will have to remove the intake manifold
Jul 08, 2009 | 2006 Hyundai Sonata
How do I change spark plugs on 2000 VW jetta 2.0 engine
Here is a diagram and step to step to take out your spark plugs and re-install them. Please do not forget to rate and comment about yor experience with fixya today
2.0L (Aeg, Avh, Azg, Bbw, Bev) Engines
NOTE This procedure requires the use of the following special tools, or their equivalents:
  • Spark plug wrench VAS 3122B
  • Seal puller T10018
  • Removal/Installation tool T10029
  • Puller T10095
  • Torque wrench V.A.G 1331/ (5 - 50 Nm)
  1. Make sure you have the radio code, if necessary.
  2. Disconnect the negative battery cable.
  3. Pry the plugs out (arrows), then remove the nuts underneath.
  4. Remove the nut (1).
    42075_vwca_g0016.gif Pry the plugs out (arrows), then remove the nuts underneath. Remove the nut (1)
  5. Pull out oil dipstick.
  6. Remove engine cover.
    42075_vwca_g0018.gif Spark plug applications—2.0L (AEG, AVH, AZG, BBW, BEV) Engines
  7. Remove the spark plug connector (arrows) using tool T10029.
  8. Remove the spark plug using Spark plug wrench VAS 3122B.
  9. Inspect the spark plugs, as outlined in this section.
    42075_vwca_g0017.gif Remove the spark plug connector (arrows) using tool T10029 and remove the spark plug using Spark plug wrench VAS 3122B (arrow)
To install:
  1. Install spark plugs with Spark plug wrench VAS 3122B. Tighten to 22 ft. lbs (30 Nm).
  2. Install spark plug connectors using Removal/Installation tool T10029
  3. Check that ignition wiring and spark plug connectors are seated securely.
  4. Install engine compartment cover.
  5. Connect the negative battery cable.
Apr 15, 2009 | 2000 Volkswagen Jetta TDI
I can't find the spark plugs in my 2005 sonata
Note: If you have the (6) cylinder engine, the front (3) sparks pluge are readilly accessible but in order to access the (3) rear spark plugs, you will have to remove the intake manifold.
please rate!
Mar 18, 2009 | 2006 Hyundai Sonata
Mtd 22" Yard Machine Push Mower Logo
118 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
