Question about Kenmore Dryers
Belt replacement kenmore 80 series, model 110-71804000. squealed then smelled like rubber and tumbler isn't turning. I think it's a belt but don't know how to change one.
  • 1,305 Answers
Visit youtube.com and type in Kenmore dryer repair. You'll find step by step instructional videos to service your unit.
BUT.... You've probably burned a belt, but this may only be a symptom of another problem. Something caused the belt to freeze up and burn on the motor pulley.
Check the roller bearings while it's apart... Make sure that the motor's turning free and all related rollers, pulleys etc are in good shape... save yourself from having to open it up twice..
Good luck and let me know how it goes.
k
Posted on Jun 22, 2009
Kenmore 80 series dryer banging
Yes you need to replace the tumbler guiding wheels .should do that soon so you don't ruin the motor and belt
May 03, 2014 | Dryers
Kenmore 11062612101
From your description, the dryer belt could be in need of replacement. The burning smell could come from the motor pulley spinning and trying get a grip to turn the drum.
Dec 20, 2013 | Kenmore series 70 80 90 Dryer Motor...
Kenmore series 80 Gas Dryer, in back of the dryer there is a fan at the bottom that squeals when I turn the dryer on. Is this easy to replace or oil to resolve the squealing. Suggestions are...
that fan runs off the motor shaft and can be lubed with some spray lube,, be sure that its not the belt thats squealing, check it for cracks, and bare spots
Jul 06, 2011 | Dryers
80 series model#26852504. just replaced the trans and now i have to open and close the lid to get the drum to spin
I don't get cold water in the washer. I even changed my water inlet valve. I don't know what else I have to look for. Please post me the solution. The model is Kenmore 80 series-110 26852504
May 17, 2011 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 series electric dryer. metalic sound/burning smell
When i put clothers in my dryer it does not move and it make a sound when i push the start buttom
Feb 24, 2010 | Kenmore Dryers
Tumbler
You may have had a wheel lock up on the dryer. This could cause the belt to break. Is the drum hard to turn? Is this a gas dryer? use this PAGE as a guide to help you get into the dryer and a lot more
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Nov 03, 2008 | Kenmore 62622 Electric Dryer
Dryer really squeals
Ok this is a really broad question, Kenmore will squeal when a belt tensioner or motor bearing is out, a frigidaire or small kenmore with control panel above the door and serial number starting with x will squeal when the bearing is out on the drum or the motor. This is a general cover on dryer noise with a model like Kenmore series 80 I can give solutions ok?
Sep 20, 2008 | Dryers
Open Questions:
Kenmore Elite Dryer HE4 Quietpak 9, has 4 dim lights showing on the console display but won't start or respond, I have bought brand new and replaced all sensors. Replaced heating element. looked like the original heating element. Pack came with new sensors. I did not test with a multimeter. My plan is to measure continuity on all the old sensors. Then do the same on the new ones. The electronic board looks good, does not smell burnt or old burnt smell. I cleaned all the lint in this dryer but unfortunately the motor has some lint in it which I surfaced cleaned. The only way to get to the motor is to remove the drum. So far I have soent $40 on all parts and a week works of troubleshooting as a novice. On the main display read, it shows two small dim lot red lines, wish I could send you a picture. Also when the fuse is off I plugged in the dryer and all the lights turned on normal. All looked in working condition except of course it did not turn on, I have not replaced the switch and with the new fuse, by the way, I bought 5 to 6 of the same fuses thinking I was burning them, that's why I bought a multimeter to retest them to see if they are not burnt. When I plug in the fuse it goes black but the door light works. I have held down the start button, nothing, held down the cancel button, nothing, I have done the crazy push all buttons even shook the machine a bit just in case something was causing whatever myth I was conjuring. I am about to give up and just buy a used one from someone else but I think I can fix this, it should be very simple to fix.
Aug 20, 2018 | Kenmore Dryers
Dryers Logo
232 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
