Question about Kata T2 - 8" IPS ANDROID 4.1.1 TABLET
Need Tablet to PC Driver
I need to transfer picture files from the Kata T2 Tablet to my PC. Where can I find the USB Driver for download?
How do i transfer my ebooks from my pc to the tablet
Hello Michael. What kind of tablet is it? If you're on an iPad, Please follow the guide below.
If the files are saved on computer, you'll need to use iTunes to transfer them. The EPUB files you purchase in iTunes on computer are also needed to be synced to iPad, therefore iTunes provides great help at this moment to transfer ebooks to iPad.
transfer-ebooks-from-pc-tablet-oxaxc0rwhkhzilrwacqreyis-3-0.jpg After syncing PDF and EPUB files to iPad Pro, people are able to read these ebooks on your tablet with ease.
Get more information here. http://www.leawo.org/tutorial/how-to-put-ebooks-on-ipad.html
Jan 03, 2016 | Tablets & eReaders
Why is my battery drains so fast?
If you have your WiFi or any other Bluetooth like thing, this will drain your battery relatively fast. Also if you have multiple apps open at the same time you will encounter an increasing amount of drainage. Also, the screen brightness should be dimmed to allow longer battery life
Jul 15, 2015 | Kata T2 - 8" IPS ANDROID 4.1.1 TABLET
How do i transfer photos from a usb to samsjng galaxy 3 tablet
To transfer files directly from a usb flash drive you will need a USB on the go adapter. If your tablet is rooted, StickMount will make the process much easier.
You can also use a computer to transfer the files, plug both the tablet and the flash drive into a computer and use windows to transfer them between the two devices.
Additionally you could use some sort of cloud storage to transfer them, attach the usb drive to the pc, and copy the photos to a service like Google drive or Dropbox, then simply download the files onto the tablet using that services app.
Oct 12, 2014 | Samsung Galaxy Tab on 3 Mobile Tablet PC
How do I transfer pictures from my tablet to my PC?
Can you be more specific please? The make and model of your tablet? Usually, you would connect the USB cable into your port on your computer and one to your tablet or other device. If you do not have the software to communicate with your tablet the computer should prompt you to get it. If it can't find it, you have to go and get it. Once you get it, and you plug your device into your computer, it will ask you what you want to do. You can view file, download files, etc.... you choose. It should sync all your photos to your computer if you choose download. If you only want a few, then click "view files" and one by one select the ones you want to transfer. Good luck. Also you can go to that very popular website for videos and watch a video on how to do it. Not saying name f website, but you can watch music videos there too, while you work on your pictures!
Oct 08, 2014 | Tablets & eReaders
Can i transfer my pictures from the gallery on my tablet to a flash drive
Yes, but it takes several steps to transfer pics from your tablet to a flash drive.
There are two ways of accessing tablet files: 1) wireless access which requires a sync app on your tablet and PC software of the same app type. One such app for sync between Android (any) to/from PC software is Cheetah Sync: http://www.jrtstudio.com/cheetah-sync-android-wireless-sync.
Alternatively, you can use ES File Explorer's Network/LAN/Cloud/FTP functions to share files between your Android phone/tablet and your PC via secure Wifi: http://www.cnet.com/how-to/share-files-between-android-and-windows-with-es-file-explorer/
or 2) wired via the USB charging cable, which I will explain in more detail:
Plug your table to your PC using the Samsung charger cable that doubles as a data transfer cable when you remove the USB plug from the wall charger cube and plug it to the USB port on your PC.
Your PC should read your tablet as an external drive: Open "My Computer" and double-click the tablet drive icon>search your subfolders for your pictures. Highlight your picture files and either copy and paste or drag and drop (different way of copy/paste) to your desktop (or desired location), copies will be transferred but not moved from the tablet unless you "cut and paste" from your table to PC to clear out your tablet and make more space. When done, unplug your tablet cable from the PC. Plug in your flash drive to the available USB port: access the flash drive icon on My Computer. Drag and drop or copy and paste picture files to your flash drive.
Sep 24, 2014 | Samsung Tab Tablets & eReaders
How do we transfer files from tablet (samsung galaxy 4) to laptop please?
Usually you would just plug in you tablet to the computer and it should see it as a new drive. You would then browse the folders and transfer what you want. A manufacturers model would help to troubleshoot the issue.
Sep 23, 2014 | Tablets & eReaders
How do I transfer photos from eviant tablet to HP PC? The tablet plugs into the wall with no way to insert an end into my PC. The only way I've been able to transfer is thru email a few at a time.
The USER guide here http://www.qvc.com/Eviant-8-Tablet-w-8GB-Memory-Android-4.0-&-Google-Play.product.E223749.html
(Click on second set of red words below pictures to download. marked user guide in red.)
Shows you how to transfer files (photos) to your PC using a micro-usb to usb cable from your tablet to your PC.
Sep 10, 2014 | Eviant 7" 8 GB Wi-Fi Purple Tablet Android...
How to put photos on my sd card
This more than likely means your internal storage is low and not the SD card and may not have anything to do with your pictures but more so with your apps. Go into settings and see if your tablet has the feature to set where your downloads and other media is stored, by default that will be your internal memory. change it to SD card or USB storage. In Settings you can also click on your apps individually and transfer them manually one by one to the SD card or USB storage or download a file manager and do so all at once. Some apps and files may not have the feature to transfer these apps the tablet came with or apps you downloaded that uses the internal memory. By default if a memory card is in you tablet pictures are automatically store there, if this is not the case the easiest way to transfer is connecting the tablet to a computer/laptop and transfer to the card or again use a file manager.
Aug 15, 2014 | Acer Iconia Tablet with 8GB Memory - Steel...
I need some drivers for i craig tablet usb cord driver
If you plan is to do Android Programming, you just need to download adb, or a rooting kit like RootThat. If you plan to just transfer files to it, BEFORE plugging in the USB connector, go to SETTINGS, scroll down to USB, and turn off "HOST MODE".
Now plug in; the tablet & the computer should recognize each other.
Mar 14, 2014 | Craig CMP741d Tablet
Kata T2 - 8" IPS ANDROID 4.1.1 TABLET Logo
16 people viewed this question
Top Kata Tablets & eReaders Experts
Are you a Kata Tablet and eReader Expert? Answer questions, earn points and help others
