Question about Miller SPECTRUM 1251 907305-01-1 PLASMA CUTTER NEW
The cup indicator lamp in me miller spectrum 1251is flashing
I change all thing in the cup but doesn't work anything
kevin_max
  • 37 Answers
SOURCE: circuit board flashed resistor
Check this site out.
www.arc-products.com
1-800-770-0063
619-628-1022 Fax: 619-628-1028
service@arc-products.com
Arc Products
1245 30th Street
San Diego, CA 92154
Posted on May 15, 2009
  • 18 Answers
SOURCE: I bought a used miller spectrum 625, can put on
The consumables on the torch head could be incorrect or not installed correctly. check these.
Posted on Oct 07, 2009
luis_david
  • 407 Answers
SOURCE: I have a Miller
Hi:
I found similar problem with few customers and one issue (should I said the standard issue) is the source of air. You need a steady pressure and flow of air into the machine. Check your air compressor you will need at least 6 cubic feet per minute (360 cubic feet per hour) and a 90 psi of pressure. Since there is no way to check the flow (unless you have an online flow meter at you air pipe) check the pressure at your air tank (reservoir), if the pressure drops below the 70 PSI then that's the problem; your compressor can't stand the flow. Other than that check your ground clamp and make sure it's making a good contact.
Good Luck.
Posted on Sep 15, 2011
  • 5 Answers
SOURCE: miller plasma cutter spectrum 625
make sure your air pressure is high enough and volume does not drop below minimum.
Posted on Nov 27, 2011
  • 1212 Answers
SOURCE: My plasma cutter miller 875 want arc the cup light
Check the cable connection to the cutter head and at the box. Also check to make sure the control boards are blown clean of dust.
Posted on Jan 16, 2012
Has cup fault
Check connections on holder and at the main unit. blow out the unit with air to eliminate conductive dust as being a problem. Also make sure cup seating area is clean.
Jan 11, 2012 | Spectrum Miller 625 Xtreme Plasma Cutter...
Miller plasma cutter spectrum 625
Nov 27, 2011 | Miller SPECTRUM 625 SPECTRUM PLASMA CUTTER...
I have a Miller Spectrum 625. The problem I am having is that after cutting for three seconds the torch quits cutting. Have had it looked at a Miller repair center. They said they cut with it for over...
Hi:
Good Luck.
Sep 15, 2011 | Miller SPECTRUM 625 SPECTRUM PLASMA CUTTER...
Im looking for a miller spectrum 1251, where can i find one?
I have a miller spectrum 1251 for sale. We moved to a different shop that doesn't have three phase, but the machine has only been used a couple of times. You can reach me at 660-229-0171 if you are interested.
Sep 17, 2010 | Miller SPECTRUM 1251 907305-01-1 PLASMA...
I can cut for about 4 min. then Cup Error
look at your duty cycle 40 % duty cycle is 4 min 10 min sraight is minimum 100%, but good machines weld for 3 or 4 shifts till they get turned off
my 2 cents
Feb 25, 2010 | Miller SPECTRUM 625 SPECTRUM PLASMA CUTTER...
Sep 28, 2009 | Miller SPECTRUM 625 SPECTRUM PLASMA CUTTER...
I am looking to purchacs a slightly used miller plazma spectrum 375 from a private owner is there any common problems related to this unit that I should look for?
The main thing that can hurt these things is water. If he didn't have a water filter on the line before it enters the plasma it could destroy the unit. If you buy it try it out to see if everything works. When you install it be sure to buy a filter that they sell for these and put it on before the air enters the plasma. Around $400. to $600 to replace the parts when water meets with the components. The filter that Norco Welding supplies sells for these is a toilet paper filter and you need to check it often.
Jul 29, 2009 | Miller SPECTRUM 375 PLASMA CUTTER 903891...
Plasma problem
check your torch and make sure nothing is loose. If that does not fix it you will need to disassemble the tip and make sure there is not any debris if there is clean it out and replace any worn parts.
Apr 30, 2009 | Welding Tools
Circuit board flashed resistor
1-800-770-0063
Arc Products
1245 30th Street
San Diego, CA 92154
Mar 17, 2009 | Miller Welding Tools
Cup light is on machine will not work
The cup light is referring to the outer most part on the torch tip, the purpose of the cup is to create a gap between the tip and the work piece. The light is indicating that the cup is worn and must be replaced.
Nov 09, 2008 | Miller Spectrum 375 Cutmate Plasma Cutter...
Miller SPECTRUM 1251 907305-01-1 PLASMA CUTTER NEW Logo
70 people viewed this question
Top Miller Welding Tools Experts
Kory Ronning
hubiam
hubiam
Level 1 Expert
John Trevino
Are you a Miller Welding Tool Expert? Answer questions, earn points and help others
