Question about Garden
2005 21 HP Briggs & Stratton Intek V-twin engine misfiring
I purchased a used MTD Yard Machine with a 21HP B&S Intek V-Twin engine that was manufactured in 2005. It was running fine when I tested it out prior to buying and when I got it home it ran fine until I put some gas left over from the last mowing season into the tank. Apparrently the gas was no longer any good so the mower died and I could not get it started. Once I figured out the problem, I drained the bad fuel and put in new fuel and changed out the plugs for good measure. I tried starting it and it took several tries before it turned over (I assume because of a little of the bad fuel still left in the carburetor). Once it started it sounded OK for a few seconds and then started misfiring every other second. It still can run and mow and has lots of power, but I would like to know what I need to look at in order to fix the misfiring problem. Thanks for any advice you can give.
  • 95 Answers
SOURCE: mower dies after running for a few minutes
It sounds like the carburetor is running out of fuel.First make sure the tank is full then loosen or remove the gas cap when it starts sputtering to see if that corrects the problem. Then with engine off remove the fuel line that goes from the tank to the fuel pump,hold it low and see if any fuel flows out of it,if not lightly blow air backwards to the tank,(with fuel cap off),then see if the line is plugged. Next remove the fuel line that goes to carburetor from the fuel pump,crank the engine and see if any fuel flows,if so the carburetor should be cleaned by removing it and disassembling it.
Posted on Aug 09, 2009
mowerman1857
  • 389 Answers
SOURCE: Briggs and Stratton 22hp v twin OHV smoking badly
First thing to do is pull your dipstick and check for broken or missing O-ring also as you pull it, look to make certain that it was seated properly and all the way locked. If either condition exists, you will be leaking into the crankcase which will cause your symptoms
Posted on Sep 14, 2009
SOURCE: 21hp intek v-twin runs only with choke on full
You are not getting enough fuel.... by choking it you are enriching the mixture with less air , more fuel.Some where in the fuel system or carbureator something is still plugged.Or the mixture screw is too far in.
Posted on Nov 07, 2009
  • 420 Answers
SOURCE: Have a Yard Machine riding mower with 21hp Briggs
It depends on the model but most riders have the following;
1. Seat switch
2. Brake pedal switch
3. PTO switch
4. Neutral switch (if its a shift model)
All need to be closed in order to start engine.
Posted on Jun 04, 2010
kel1guy2002
  • 3740 Answers
SOURCE: My 20 hp Intek v
Hi and welcome to FixYa. I am Kelly. What your describing is a fuel starvation / lean fuel mixture symptom.
First off remove the fuel supply hose to the carb and check fuel flow. It should be a normal gravity flow rate. If you don't have flow check the bottom of the gas tank for debris. I note you already changed the fuel filter and pump.
--Check to make sure that the fuel solenoid on the bottom of the float bowl is working correctly. You can unplug it and then test it with battery power to see if the plunger is moving.
--Also check it in place for 12VDC with the key on and seat switch activated (if installed).
Your parts list can be found here:
http://www.briggsandstratton.com/document/index.aspx?doc=MS3562_C_LO.pdf
The solenoid is item 947A of the above link. (pdf file page 5 top right)
With the fuel hose connected float bowl removed you should also chec the fuel float needle item 105 for proper operation. Float down... fuel flow.... GENTLY lift the float to LEVEL there should be no fuel flow.
These are the 2 most common problems:
Either the fuel bowl solenoid is not being energized / not working or.... (item 947)
There is debris in the needle and seat. (Item 105)
If you do not have 12VDC to the fuel solenoid you will have to find out why. (Safety switches.. broken wire etc.)
Before you reinstall the fuel solenoid clean the area with carb cleaner.
Thanks for choosing FixYa.
Kelly
Posted on Sep 28, 2010
Engine rpms is constantly going up and down.
Is the air filter clean?
Governor Ajustment Briggs V-twin - YouTube
? 3:12
www.youtube.com/watch?v=tOoArROpM_oJun 26, 2010 - Uploaded by IFIXIT4U The Briggs manual does not do a very good job. You have to adjust the tension on the two springs to set the RPMs that the engine runs at the low and high position. ... I really really need help guys my race motor has a 21hp vtwin brigs, .... Briggs & Stratton opposed twin carburetor series 1 of 3 disassemble ...
Sep 17, 2015 | Briggs & Stratton Briggs Stratton Intek V...
Does a briggs 18 hp twin 2 have a oil filter its a late 90's model mtd riding mower
Most likely yes. It will look like a car oil filter. It looks like a round can that is screwed to the engine.
Mar 17, 2011 | Briggs & Stratton Briggs Stratton Intek V...
Briggs and Stratton Intek V twin 22HP motor misfires.
Misfiring could be caused by simple things like fouled or worn out sparkplugs or an ignition system that is slightly faulty or Fuel problems such as dirty or stale fuel or clogged filter causing a leam mixture. Some B & S motors have an switch that cuts the Ignition if the oil pressure or oil level is low.
Another cause could be the Valve clearances are out of adjustment.
Armed with your Engine Number, visit the B & S Website for comprehensive information and specifications as well as a good FAQ listing.
Sep 16, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Brigss and Stratton engine getting to much fuel
I HAVE A BRIGGS & STRATTON INTEK 18.0 ,JUST FINISHED CUTTING THE YARD,WENT BACK ABOUT 20 MINS LATER TO PUT LAWN TRACTOR AWAY. WILL NOT TURN OVER WHEN I TRY TO START, FUEL LEAKS OUT OF THE EXHAUST AND AROUND THE BOWL
Jun 19, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Have a Yard Machine riding mower with 21hp Briggs Stratton engine OHV/IC V-Twin. when I turn on key nothing happens. How many switches control the start motor from the ignition and where are they located....
1. Seat switch
3. PTO switch
Jun 03, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Oct 30, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Briggs & Stratton Briggs Stratton Intek V - Twin Vertical engine 24hp,48in riding lawn mower,keeps smoking.
these are common for doing this ,if you dont want to pull it down and hone the cyl. then i would use a heavier oil say 20w/50and that will probabley solve your problem
Oct 21, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Briggs & Stratton 18 hp v-twin engine surges while running.
I put a new carburator kit in a Briggs & Stratton 18 HP Twin. But did not replaced the needle nor the new seat that came with kit, because I did not know how to remove it and did not to damage it. now the gas over flows
Jul 12, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Garden Logo
26 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
