The vbxr1070w0ww model hotpoint washing machine doesn't agitate. How do I disassemble the machine so I can get a better look at what could be the problem?
2 Suggested Answers
localwonder
  • 6784 Answers
SOURCE: how do you remove agitator
Hi. The agitator is fastened to the agitator shaft and its movement is driven either by splines or a simple clutch assembly, which is removable as well. The splines are usually plastic or rubber nubs on a cylinder that fits over the agitator shaft. If the nubs wear down, the shaft will not turn properly or it will turn weakly. If the agitator is moving in only one direction, the likely cause is the clutch assembly. The clutch has dogs that depress and pop up with each turn. If those dogs are worn, they will not engage properly and the agitator will turn only in one direction.
Various makes and models differ in how the agitator is removed. In some newer models, the agitator just lifts straight up and out. However, in most models you will have to preform a combination of the following steps. First remove the fabric softener dispenser, if any. It should either lift or screw off. Next remove the cap. It may lift off, screw off or failing that, it may need to be pried off.
Beneath the cap some agitators are secured in place by a bolt. Use a socket wrench with an extension to remove that bolt. Some Maytag's may have a screw near to the bottom of the agitator post that must be removed. Now try to lift the agitator straight up, possibly with a little back and forth rocking motion. Use caution when pulling, the agitator may come loose suddenly and hit you in the face or send you flying backward.
If the agitator is particularly stubborn, you can loop some rope under one side of the agitator at the bottom and then up over a broom handle. Now loop it again under the other side of the agitator and back up to the broom. Brace one end of the broom handle against the top of the washer and lift up on the other end. Double check that you have removed anything that may be securing the agitator in place. Do not use too much force or you may damage the washer cabinet, agitator or injure yourself.
Posted on Aug 04, 2009
Can the impeller/agitator (looks like a hubcap) be reattached if it broke off?
No, you will need a new one. They are under immense strain, it would never last.
Google
make model agitator
and you will end up at a place like this
Hotpoint Washing Machine Agitator Parts
hotpoint agitator Google Search
Sep 04, 2017 | Washing Machines
The Hot Point washing machine has stopped agitating but does spin-what is wrong?
The most usualthing wrong when the Hotpoint brand washer doesn't agaitate is a stripped agitater coupler,i don't see a model number in your question so i don't know if yours uses that coupler but its by far the leading thing wrong with that problem.
This youtube video will show ya how to replace that coupler,watch it and take off your agitator to see if that's the problem. http://www.youtube.com/watch?v=N26MCQKuXn0
GENE
Oct 13, 2011 | Hotpoint Washing Machines
All cycles on my washing machine work, but machine will not agitate. What are possible solutions to fix the issue? It is a Hotpoint, top load, model # is vvsr1070daww
The most probable thing causing it to not agitate is going to be stripped/broken agaitator coupler.
The video will show you to take out the agitator and check for a defective agaitator coupler
GENE
Sep 05, 2011 | Hotpoint VVSR1070D Top Load Washer
I have a HotPoint washer (VBXR1090D) and it stopped agitating. It still spins, and everything else, just doesn't agitate.
Do you here the motor running on the agitation cycle yet it doesn't agitate? If so the agitator coupling is the problem.I have included a youtube video that will show you step by step how to repacle the coupling.The part number in the title of the video(WH49X10042) is the part number that you would need(Hotpoint is made by GE) it could be ordered by simply googling that part number
here is the lik for that video http://youtu.be/N26MCQKuXn0
I hope this helps and if it does please give me 4 thumbs up
Gene
Jul 28, 2011 | Washing Machines
I have a Maytag Model A412, series 11 washing machine. After the machine fills with water the machine appears to start its cleaning cycle but the agitator doesn't work. The water starts & the...
if this is a two piece agitator,it should behave like a ratchet turn freely clockwise and catch counter clockwise if it doesn't catch the agitator "dogs " are shot this is a verry inexpencive repair
Jun 08, 2011 | Washing Machines
My washer makes a terrible screeching sound when it starts agitating for the wash cycle. what could this be? it is a Hotpoint, model wlw2500b
Hi this sounds like the clutch assembly, this model is fairly old, you would probably be better off getting a new washer.
Sean
Mar 27, 2011 | Washing Machines
My GE Hotpoint VBXR1070W0WW stopped spinning. When I opened it the belt was very loose but it does not look worn at all. Is it the belt or probably something else?
Either the belt has stretched or the motor bracket has slipped (if adjustable). If the bracket is adjustable (like on a car alternator) you can just adjust out the slack and retighten, but if not then you must replace the belt.
May 19, 2010 | Washing Machines
Hotpoint washer won't agitate?
hotpoint agitater will not work. how to fix this problem
Aug 05, 2008 | Hotpoint VVSR1070D Top Load Washer
Hotpoint washer
Two types of Hotpoints had two different ways of removing the agitator. One had a pop off top that when you removed it, you can remove the center bolt, the remove the agitator. Another one you had to put your fingers under the agitator and pull straight up to unclip the agitator. Good Luck!!! Jim
Sep 04, 2007 | Washing Machines
Washing Machines Logo
51 people viewed this question
Top Washing Machines Experts
