Question about Konica Minolta Office Equipment & Supplies
Error bizhub c450 c9401 - Konica Minolta Office Equipment & Supplies
  • Konica Minolta Master
  • 6,161 Answers
The big bright light under the big glass is bad or the board that control is. replace it.
reset
1. Turn OFF the main power switch.
2. Turn main power switch ON while pressing the Utility/Counter key.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and the it has been reset.
5. After turning off the main power switch, turn it on again more than 10 seconds after
and check if the machine starts correctly.
Posted on Dec 29, 2015
Nitrotrike
  • 589 Answers
SOURCE: bizhub C450 error (C-0212)
C0212 is a LCT (large capacity tray) shift motor, or lock release failure (they both use the same code)
Open the lower paper tray, and look for anything unusual.
Sounds like the paper was loaded incorrectly, and the tray tried to lift.
Posted on Feb 10, 2008
oranous_comp
SOURCE: proplem with KONICA MINOLTA bizhub C450
c-3451
Posted on Nov 10, 2008
rcampsr
  • 90 Answers
SOURCE: Ocr scan for Bizhub C450
according to what I read on the C450 biz hub, in order to do OCR you need to use the option that scans to SMB, that sends the scanned documents to your computer on the network. You can then process the documents on your computer with the OCR software program so you can edit the finished documents. I did not see anything that indicated the Bizhub had OCR software capabilities built into the unit. Regards, rcampsr
Posted on Feb 20, 2009
  • 51 Answers
SOURCE: Konica bizhub C351 with a C9401 error code
The output from the CCD Sensor is a predetermined
value or less during CCD Sensor gain
adjustment.
Check the flat cable for proper connection and
correct or change as necessary.
Change PWB-C.
Posted on Aug 30, 2009
SOURCE: C-2451 on bizhub c450
C2451: New Transfer Cleaner Unit resetting failure
1. Turn OFF the Main Power Switch.
2. Turn Main Power Switch ON while pressing the Utility/Counter key.
5. After turning off the Main Power Switch, turn it on again more than 10 seconds after and check if the machine starts correctly.
Reset your Toners and Imaging units for Minolta Bizhub and CF series.
http://www.chipreset.eu
Posted on Sep 03, 2009
Error c3451 for bizhub c450
Error c3451: "Heating roller warm-up failure"
Oct 12, 2014 | Konica Minolta 120v Fusing Unit For Bizhub...
The bright lamp under the big glass is burned out or the circuit board that controls it is bad try this first if the code comes back get tech out to look at the lamp or board.
5. After turning off the main power switch, turn it on again more than 10 seconds after and check if the machine starts correctly.
Aug 26, 2014 | Konica Minolta bizhub C450 Scanner
How i can rest error code c-d231 on bizhub c450
CD231 in Bizhub C450 come due to missing of DIMM memory board in Fax board.
in service mode(Utility-counter-Stop-00-Stop-01) -system2-option board-unset the Fax1 and fax2 and re-start machine .
Jul 03, 2014 | Konica Minolta bizhub Office Equipment &...
Imaging unit
konica minolta bizhub c654e in display error c9401
no Utility/Counter key. howcreset I resolve lamp already change
Oct 29, 2013 | Konica Minolta Bizhub C550
Konica minolta bizhub c450 error code c- d370
I have minolta c450 show error c d370... how can I solve this problem... plz reply me with solution.
May 14, 2013 | Konica Minolta Bizhub C 353, Bizhub...
ERROR CODE LIST FOR C450
Go to service mode and click on counters, then select Service call counter, there you will find the complete error code list for bizhub c450.
Dec 06, 2012 | Konica Minolta bizhub C450P Laser Printer
Our machine shows C9401 default, can you help us in solving this problem
Not exactly sure if the model is the same but on a C351 the C9401 & C9402 errors are as follows:
16.6.81 C9401 Exposure lamp failure to turn on
16.6.82 C9402 Exposure lamp turning on at abnormal timing
Parts to check:
Scanner Assembly
Flat Cable
Image Processing Board (PWB-C)
Step Action
Corrective steps in order of suggestion:
Check flat cable for proper connection and correct or change as necessary.
Change Scanner Assembly if necessary
Change PWB
Apr 29, 2010 | Konica Minolta bizhub C450P Laser Printer
adjustment.
Change PWB-C.
Aug 03, 2009 | Konica Minolta bizhub C351 All-In-One...
29 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
