Question about Kitchen Ranges
What does Whirlpool Self Cleaning Oven error code F5E1 mean?
  • 1314 Answers
SOURCE: Whilrpool Self Cleaning Range Door won't unlock
try this 1. Verify error code by pressing and holding CANCEL/OFF key for 5 seconds.
Momentarily (less than 5 sec.) press CANCEL key again to remove error code
display.
2. Press and hold any key for 1 minute until F2 E0 code is displayed.
3. Cancel F2 E0 error code.
4. Program and start the clean mode. Observe to see if door locks. If it does not,
inspect the locking mechanism from the solenoid to the latch pawl and door to
find the cause of the problem. If the door is not locking, then 1 minute from the
start of clean, the F5 E1 code will again be displayed. Steps 1 through 3 will
have to be repeated before another clean can be started.
5. Once any mechanical problems with the latch mechanism have been corrected,
program and start a clean cycle (after, if necessary, clearing F5 E1 error code)
to ensure proper operation of the door lock. Immediately cancel the clean mode to observe proper operation of door unlock
Posted on Feb 12, 2008
Agent Matt
  • 8 Answers
SOURCE: Unlocking Oven controls
According to the manufacturer's website you should only need to Press and hold the "Lock" key for 5 seconds. A single tone will sound and the "Loc" will disappear off the display.
This is the link to Whilpool's website and to the manual.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%209761079.pdf
Thank you
Agent Matt
Go Ahead. Use Us.
Posted on Apr 07, 2008
SOURCE: F5E1 error
Whirlpool-KitchenAid-Roper Appliances: Oven Fault Codes:
>>Exception Note:<<
Chart below does not apply to Whirlpool Models using the "Y" line in the products model numbers. Applies to models using 4 digit displays only.
F0-E0 Analog to Digital failure
Disconnect panel for 30 seconds
Should the above error re-appear, replacement of the control is required.
F1-E1 Defective ERC Replace ERC
F2-E0 Shorted Keypad Replace Keypad
F3-E0 Sensor or Sensor Fuse Open Replace Sensor or Fuse
F3-E1 Shorted wire or Sensor locate short and correct it or replace Sensor
F3-E2 Oven over heat Replace Sensor
F3-E3 Cleaning Temp over heat Replace Sensor
F5-E0 Door Error Check Door
F5-E1 Door Latch Check Latch
F5-E2 Door Switch Check Switch
Posted on May 11, 2008
SOURCE: E1 F5 error on self cleaning oven
Press the self-clean button. The panel becomes blank(---), then press the up arrow( ^ ). The panel will appear 3:00 (indication for the duration of self-cleaning). The oven will lock on its own and start the self-cleaning.
This code means the control has detected a problem with the door latch switch. Switch is defective and needs replaced. Part # is W10107820 and cost is $39.99. You can get it at http://www3.sears.com/.
Before calling a repair shop,go to the circuit breaker box and turn off the power to the oven. then turn it back on and then see if the door is released and the error is cleared.
its probaly bent door latch or door sensor gone bad. try pushing on the door when you start the clean cycle see if that helps.
if not our suggestion would be to replace the part....
good luck...
if you got insight into your problem from us , A very helpful rating is appreciated for answering your question
Posted on Aug 10, 2009
SOURCE: I get an error code
What I did was hit cancel and hit the unlock button. Then I leaned against the door a bit as I hit the lock and hit the self clean and start the lock check dissapeared. I hit lock again and nothing else and it started the cleaning process.
Posted on Apr 13, 2010
Range throws an F5E1 code, cleaned the oven 2 weeks ago. Worked fine. Plugged it back in today to clean oven but it threw the code, door is not locked.this is in a rent house.
Using the 'self clean' function nearly always results in faults. We see it here all the time, burnt out elements, doors that won't open, fires and error codes. Google the manual for it. They are all online
make model manual
The error is listed in this link. Also look at the video tab
whirlpool f5e1 error code Google Search
Door latch problem
Whirlpool Super Capacity 465 E1 F5
Apr 09, 2018 | Ovens
How do I find out what FSE1 or F5E1 means on my oven display
If your oven is by Whirlpool (or from that family), the F5E1 error code indicates that the door lock mechanism is damaged, lock motor isn't working or the sensor can't tell if the door is locked. Did you try to do a self-cleaning cycle on the oven recently? Can you open the oven door? Look at the lock mechanism near the top of the door jamb in the oven and check whether the latch move freely from left to right and back. If the oven door is locked, you open the back panel and try to manually move the lock mechanism to open the door.
Please add a comment with the model of the oven for further assistance. The model number will be on a plaque on the oven frame for most models.
I hope this helps.
Feb 01, 2015 | Exercise & Fitness
I HAVE A WHIRLPOOL MODEL NUMBER RF368LXKQ RANGE AND WHEN I TRY THE SELF CLEAN BUTTON I GET F5E1 WHAT IS THE PROBLEM
The F5E1 error codes means that the door light switch OR a switch on the self clean latch has failed. If the oven light comes on and goes off when the door is opened and closed it most likely going to be a switch on the latch thats the problem.
The part numbers are;
DOOR LATCH W10107830
LIGHT SWITCH 3195993
GENE
Aug 28, 2011 | Whirlpool 30" Self-Cleaning Freestanding...
Have Whirlpool self clean electric oven model # F368LXKQ. Am trying to self clean-get a F5E1 or FSE1 error code and it will not start to self clean/heat. Any idea what the problem is?
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
Jan 19, 2011 | Whirlpool Ovens
I have a whirlpool oven self-cleaning.. get code F5E1 or FSEI, when i set the self cleaning?
I live in apartment with a Whirlpool dishwasher and oven. Today was my first day to do automatic clean. After two minutes the "F5SEI" would pop up, then the door would unlock. I repeated this a couple of times. My mind wondered about a water source; perhaps the dishwater. Fortunately, I had a load of dishes ready to go. So I started the dishwasher, then the automatic clean on the oven. Behold! They work together like homies :)
Nov 15, 2010 | Whirlpool Ovens
My oven code is F5E1 , my oven was in self clean , now the door is locked
F5E1 is door latch assembly. One way that may work to unlock is to turn circuit breaker to stove off for few seconds then turn back on and door lock should activate and unlock. If not you are going to have to replace the door lock assembly.
Mar 03, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Tried to selfclean my NEW oven but get error message F5E1
Reading all the questions and responses - I had the same problem (would press "self clean", it would run for less then a minute then give the error message), so once I saw the code was E5F1 and what it meant (thanks for whoever posted that), I just pressed on the door for the first minute of the cycle, and self-cleaning then worked. Go figure :)
Jan 06, 2009 | Whirlpool RF378 Electric Kitchen Range
F5E1 error
>>Exception Note:<<
May 11, 2008 | Whirlpool RF378 Electric Kitchen Range
display.
Feb 10, 2008 | Kitchen Ranges
Kitchen Ranges Logo
490 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
