Question about Schwinn Meridian Adult 26-Inch 3-Wheel Bike
What makes a 3 wheel bike pull to the right? - Schwinn Meridian Adult 26-Inch 3-Wheel Bike
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 48 Answers
A bent frame or bent front fork will cause this.
Posted on Aug 03, 2014
Honda VTX 1300 pulls left
Hi, Les and the usual suspects are:
1. Improperly loaded motorcycle. Non-standard equipment on the front end such as heavy radio receivers extra lighting equipment or luggage tends to cause unstable handling.
2. Incorrect air suspension pressure.
3. Damaged tires or improper front-rear tire combination.
4. Irregular or peaked front tire tread wear.
5. Incorrect tire pressure.
6. The shock absorber is not functioning normally.
7. Loose wheel axle nuts. Torque to recommended specifications.
8. Excessive wheel hub bearing end play.
9. Improperly vehicle alignment.
10. Steering head bearings improperly adjusted.
11. Tire and wheel unbalanced.
12. Rims and tires are out-of-round or eccentric with the hub.
13. Rims and tires are out-of-true sideways.
14. Loose spokes.
15. Shock absorber improperly adjusted.
16. Worn engine stabilizer links.
17. Damaged rear engine isolation mounts.
18. Swing arm pivot shaft improperly tightened or assembled.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
bike pulls to right
bike heavy on right side need help vtx 1300r
Honda VTX1300S Service Manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda VTX1300C VTX 2004 Owner Manual
Jun 17, 2017 | Honda VTX 1300 R Motorcycles
How can we keep the rear wheel from coming off of the drive shaft?
Lil' Rider Black 80-Kb901K Fx Wheel Repair Questions ...
www.fixya.com/.../p13170224-lil_rider_black_80_kb901k_fx_wheel_b...
Recent Lil' Rider Black 80-Kb901K Fx Wheel Battery Powered Bike Color Blackquestions, ... How can we keep the rear wheel from coming off of the drive shaft?
KB901 Lil' Rider FX 3 Wheel Battery Powered Bike ...
? 8:05
https://www.youtube.com/watch?v=fED8N8DTQfU
Oct 21, 2013 - Uploaded by TMKGL
KB901 Lil' Rider FX 3 Wheel Battery Powered Bike Instructional Video .... Why does the right wheel keep sliding off the tire gear, leaving it free-wheeling? ... WORST piece of trash I've ever triedto assemble! congrats groupon, you ... axle through, this will keep the axle and motor and drive gear fitting tight.
Jan 08, 2016 | Lil' Rider Black 80-Kb901K Fx Wheel...
Front wheel shakes bad
Hi,food for thought,have you checked that the wheele bearing is not worn(put bike on centre stand hold wheele on tyre 6 clock and pull with one hand and push with other hand)and see if you can feel eney play in the bearing,if so replace,also with bike still on back wheele spine wheele and see if it pins freely and that the discs are not warped,if not then if there is a fork brace check that it is tight ,check that the head racers are not loose or worn,with bike still on centre stand hold weele with one hand and front brake with other hand push and pull with wheele strate towards and away from bike and feel for play if there is try tightening,if not,then turn front forks left and right still holding the forks and wheele in same place do this slowly and when the wheele gose past the centre piont(strate)feel for eney notchy ness,if not bearing should be ok,if there is notchy ness replace,if its none of these I would get the wheele rechecked that it was balanced right,all the best hope you get to the bottom of the problem.
Sep 04, 2015 | 2002 Yamaha Road Star
I cannot get my chain to stop coming off. How do I keep the chain from slipping off?
Loosen the nut that holds the back wheel and pull it back until the chain is tight and then retighten the nut. If when the chain is tight, the wheel is not on the rear frame, you need to take a link out of the chain.
Jun 25, 2014 | Mongoose 20" Mode 90 Boys Freestyle Bike
I recently bought a Schwinn Meridan tricycle but it seems to be pulling to the right? what could the problem be? thank you! (looking forward to riding it on our trails here in FL)
Lots to check, rear wheel alignment would be first on my list.
measure from the center of the axle to the swing-arm pivot point on both sides of the bike, they should be the same, if not it will need to be adjusted. this is the most common problem along with under-inflated tires. If you do re-adjust the rear wheel, make sure that the belt tension is correct after.
Other things to check neck bearings,wheel bearings, brake drag, wheel balance, cable routing (make sure there is no pressure pulling on the cables with the bars centered)
Feb 11, 2014 | Schwinn Meridian Adult 26-Inch 3-Wheel...
Need instruction to replace right rear wheel bearing
The wheel should only be held on by a two nuts. The first one is visible and the second one is holding the bearing s in place. Remove both of those nut, pull out the broken or missing bearing, grease the new bearing and remount the wheel.
Jun 22, 2012 | Schwinn Meridian Adult 26-Inch 3-Wheel...
Rear wheel removal on yamaha cygnus
Everywhere I read is wrong. For Yamaha Cygnus-X 125cc rear wheel removal
It is removed from the right hand side. Do not start dismantling the gear box side !
Remove 5 bolts of exhaust. Careful don't loose exhaust seal where it connects to engine. You may need friend to lean the bike over to access bolts underneath.
2. Remove main 24mm bolt on axle
No need to loosen brake !
3. Remove 3 bolts holding swing arm. That's the big triangular bit.
4. Pull off the swinging arm and on axle is special shaped washer. Note which way it comes off.
5. Pull off the wheel leaving brake shows behind.
Jul 13, 2011 | Yamaha PowerMax 150 GP1 Motorcycles
Chain is to loose. How do I tighten the chain tension?
LOOSEN THE 2 BOLTS HOLD WHEEL ON PULL BACK ON WHEEL WHILE TIGTHEN BOLTS BACK UP. CHAIN DONT HAVE TO BE SUPER TIGTH . ABOUT 3/4 OF SLACK IN CHAIN.
Nov 18, 2010 | Schwinn Scwhinn 26 Inch Womens Coronado...
How do you ajust rear wheel so it is alignedright?
1.loosen the bolts on either side of the bike at the rear of the frame. this is what allows the back wheel to be adjusted. aka wheel adjusters.
2.next loosen the wheel itself.
3.pull the wheel back until there is just a tiny bit of slack in the chain.
4.next tighten those wheel adjusters on either side of the wheel. To get the wheel dead centered count the threads visable and make them the same on both sides.
5.tighten the wheel back up as you pull it back against the wheel adjusters.
good luck and safe riding
Sep 14, 2010 | Harley Davidson FLHTC - FLHTCI Electra...
Schwinn Meridian Adult 26-Inch 3-Wheel Bike Logo
71 people viewed this question
Top Schwinn Cycling Experts
Michial Gueffroy
Tony
michael
michael
Are you a Schwinn Cycling Expert? Answer questions, earn points and help others
