Question about Air Tools & Compressors
I have a puma 1/4' ratchet when you pull the trigger it doesn't run it just has air coming out side of tool, whats wrong?
  • 27 Answers
The air ratchet needs to come apart. Better done by a professional tool repairer who knows what to look for. Problems could be any of the following: 1)you have put air tool oil in the gear head instead of light grease. 2)The gear head likely has worn out flat spotted ball bearings and there are two of them. If this is the case they will also have gouged the face of the washer the bearings run on. 3)you may have twisted the gear head yoke by pulling improperly which spreads the yoke too wide where the bearings and gears are located. 4) A gear may have broken in the head or perhaps other parts. 5) there are three small gears inside where the yoke joins the handle which may have broken. A repair kit is most likely needed.
Posted on Sep 29, 2014
  • 26 Answers
A seized bearing, broken rotor blade (vane), or rust/dirt in the motor can cause this.
Posted on Aug 13, 2014
  • 2712 Answers
SOURCE: Ratchet Question
* Are easy and economical to use. * Have fewer moving parts for longer wear. * Provide more power and torque than many electric-powered tools.
Posted on Aug 27, 2008
  • 174 Answers
SOURCE: Chicago Pnuematic air ratchet runs continuously
under the lever you push to make it operate you will se a pin .if this pin is stuck down the ratchet will run all the time.also this could be a bad O ring on this same part,
Posted on May 31, 2009
brewerstool
  • 141 Answers
SOURCE: My 1/4 ratchet operates with air applied, without
Most CP ratchets have an oring that seals the trigger valve. You can remove the screw on the top of the trigger and then remove the spring and valve pin. There should be an oring around the bell of this pin. You can probably get away with using any oring that is the same size, and not having to get the exact oring from the manufacturer.
Posted on Sep 09, 2009
brewerstool
  • 141 Answers
SOURCE: I have a brand new husky 1/2
There could be a couple of things wrong with it. First and foremost make sure your compressor has the correct cfm's to operate the tool. Psi is only half the battle when it comes to air tools. Second, make sure that your reversing switch on the ratchet is properly engaged. Sometimes it will get stuck in the middle. You may have a crimped hose so check the hose. There may have been debris in the line that got into the motor. If this is the case, then you are going to need to have to take it apart to see what is wrong. If you just bought it though you should take it back to Home Depot. I had a customer who basically had the same thing happen. He used the ratchet twice and the valve pin cap just popped off. It is plastic and just broke in two. I tried to look up the part and it is unavailable. Husky is made by Campbell Hausfeld for Home Depot. Sometimes it is not that easy to get parts for certain models. I believe they make a run of tools and then discontinue the line they just made, and do not make parts available. You could try taking it back to Home Depot and swapping it out for a new one. Or my suggestion would be get your money back and by a better brand ratchet like IR or CP.
Posted on Sep 22, 2009
kel1guy2002
  • 3740 Answers
SOURCE: I have an old Chicago Pneumatic 3/8 air ratchet.
Hi and welcome to FixYa, I am Kelly. I apologize for the much delayed response but I was helping another customer and your post appeared after I answered that post so I am going to respond now.
You will have to determine the part number of your Air drive.
The seals are dried out and cracked. Also the spring for the trigger is probably broken or the plunger is stuck down.
The CP828 parts can be found here:
http://www.ereplacementparts.com/chicago-pneumatic-cp828-t022708-3834-ratchet-parts-c-36298_36356_36369.html
The parts you probably need are items 3, 5, 7, 30 and 34. Possibly even item 109. That just repairs the trigger. You still need to repair the motor and head. See item 800 of the link for the repair kit. $33.75 Also note what item numbers above are in the kit.
The repair kits can be also located here:
http://www.pneumatictoolsonline.com/HTML%20pages/Tune%20Up%20Kits.htm Notice there are several versions of the CP air motors. I send this link because there are three types of ratchet heads and it lists both the CP828 and CP886 repair parts.
You should be able to breathe life back into this thing with just a repair kit.... and possibly a few other trigger parts.
Thanks for choosing FixYa,
Kelly
Posted on Mar 03, 2011
Testimonial: "Good advice from a fine gentleman."
When trigger is pushed lost of air through the exhaust. never spins ratchet
take some oil and lube the head of the ratchet real good and then take a wrench and put it over the square socket attachement and try working it back and forward and also keep working the position knob .if this frees it up put 5 or 6 drops of oil in the air intake connector and plug yor air line into it and pull yor trigger .remember run it in both directions.hope this helps.
Mar 12, 2016 | Campbell Hausfeld 3/8" Ratchet
Ratchet stop spinning
Apr 07, 2014 | Air Tools & Compressors
I have a milwalkie 1/2 inch drive air rachet ...all of a sudden now it wont work when you hit the trigger air just comes out where the top of the rachet joins to the bottom half...is there a way to fix it?
it sounds like the viens in the air motor may be stuck. try pouring some "Air Tool Oil" or any thin oil will do, even veg oil. when pouring it in make sure to pull the trigger so that the oil goes into the ratchet. let it soak for a while and try it. I hope this works for you.
Apr 16, 2011 | Air Tools & Compressors
I have an old Chicago Pneumatic 3/8 air ratchet. It appears to be a CP 886 or CP 828? I hooked it up the first time and it started up without the handle being pushed down? Air comes out of the top and...
Kelly
Feb 26, 2011 | Chicago Pneumatic Air Tools & Compressors
Craftsman 3/8 inch air rachet model number 875.188020, stuck on as soon as you plug it into the air supply. any ideas on fixing this issue or where to get a diagrahm of this tool.
sounds like the trigger is gooed up from water and **** from the compressor
if you can pull trigger apart and clean it problem probably be resolved
Dec 14, 2010 | Craftsman 3/8" Pro Air Ratchet Rapid...
When air is turned on it wont stop turning
The trigger valve is leaking. Disassemble it and find if the seal has failed or is sticking. This is a fairlky common problem with air tools,
ake sure you ALWAYS out air tool oil in the tools daily.
Apr 09, 2010 | Chicago Pneumatic CP7830HQ 1/2" Super -...
I have a brand new husky 1/2'' air ratchet. It was working fine yesterday and today I went to use it, no go. When I hit the trigger, air just shoots out of the release port. The ratchet does not turn. ...
Sep 22, 2009 | Air Tools & Compressors
My 1/4 ratchet operates with air applied, without moving the pin. The pin and spring are there and free. This ratchet has sat in my tool box for 10+ years. Was there a plastic "ball" that used to be in...
Aug 09, 2009 | Chicago Pneumatic 1/4" Air Ratchet
May 16, 2009 | Chicago Pneumatic 1/2" Heavy Duty Air...
Ratchet support
Like any power tool, air tools are safe to operate when the proper precautions are followed. Always read and follow the manufacturer's recommendations.
Aug 27, 2008 | Astro Pneumatic 3/8" Palm Ratchet Wrench
Air Tools & Compressors Logo
582 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
