Question about Panasonic PV-M1368 13 in. Combo
WHY WONT THE VHS EJECT - Panasonic PV-M1368 13 in. Combo
How to remove a cassette stocked in a vhs machine?
If the VHS tape is stuck inside, and when you push the eject button, it wont come out. Then you need to unplug the VHS player, take it apart so that you can access the inside. See how the tape is stuck inside and start to take it out the best you can. Once you get it out you may have to throw away the tape if it is messed up badly, if not wind it back up. Put the VHS player back together once you get the tape out. Then try to play another VHS tape and see if it works again. If not, it may be a bad VHS player or it may be the tapes. Hope this helps. I have had to take mine apart to take a tape out, so that's how I know
Feb 12, 2015 | Televison & Video
How to eject a VHS tape from a FUNAI DV220FX4?
turn off power unplug wait a few plug back in turn on should eject if not try again
Aug 17, 2014 | Televison & Video
Vhs player wont eject the tape?
If your Emerson TV is an older unit, the VHS player may have worn out
Jul 10, 2013 | Televison & Video
VHS tape will not eject.
The elctromagnetic tape may be jammed inside. Open the front access to the VHS and inspect for some jams such as toys (if you have kids). You can try grabbing the VHS tape with something while pressing the eject button. Sometimes it needs some assistance to overcome the jam. Good luck!
Sep 15, 2011 | Televison & Video
Tape wont eject small spring found
Take off top of vcr to expose the tape carriage lift tape door, on the lhs/rhs you shouls see the other small spring fit the spring that you have to the opposite side and try to eject your video cassette, the spring is the part that is stopping from ejecting the tape hiopefully once you have reattached the spring all should be well.
Aug 14, 2009 | Sharp VC-A560U VHS VCR
My Panasonic Omnivision VHS won't eject
take the top off and eject it manualy, there is nothing else u can do with replacing a part, (small white spring loaded, ) probabaly
May 09, 2009 | Zenith ZHX-313 System
TAPE WILL NOT EJECT
Try unplugging the player from electrical power for several minutes. Plug the player back in and try to eject the tape.
Feb 26, 2009 | RCA VR639HF VHS VCR
Vhs eject will not release tape.
I had a suggestion that did work. Reach into the VHS compartment with left hand and press down toward the back of the tape. With the right hand press the eject button a few times and the tape did come out. I would not buy a Samsung product again. No help from their 800 tech support. No more playing the VHS side of the player. Lynn
Jul 12, 2008 | Samsung DVD-V8600 DVD Player/VCR
DOOR WONT EJECT AND ZOOM NOT WORKING
JVC GR-AXM310
Will not eject!!! I have put in a fully charged battery and tried to eject it, it will not open at all. Please help me out if you can.
Thanks Shorty_007
Jun 07, 2008 | JVC GR-AXM310 VHS-C Analog Camcorder
Panasonic PV-M1368 13 in. Combo Logo
22 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
