Question about Samsung ML-2510 Laser Printer
Texts are printing in straight with ml2510 - Samsung ML-2510 Laser Printer
Accidentaly deleted the driver for my Samsung ML2510 printer
hi if you have lost your disc.
dont worry you should be able to look up your driver via the internet and download there. hope that is of help
Jan 17, 2013 | Samsung Black Laser Toner for ML2010...
I purchased the samsung ML2510 and it didn't come with a manual. I have it hooked up but both lights are flashing and it is not printing. What could the problem be.
You can download the manual from the manufacturer's web site at
http://downloadcenter.samsung.com/content/UM/200809/20080926100848859_Guide_English.pdf
Nov 10, 2010 | Samsung ML-2510 Laser Printer
Is there a sensor that tells the print head to
no sensor but what you need to do is to go into the properties of the printer in the printer icon in the control panel. In there will be a way to put the printer thru a realignment and once that is done the print should come out properly.
Jan 23, 2010 | HP Photosmart 8750 InkJet Printer
HP C7280 does not print straight, ie the print is angled on page
There is no way that a printer prints out of alignment unless the paper slips enroute. Meaning that the rollers are not holding the paper tight and the guides not pressing the paper snugly, as you put it. So, it could either be the rollers not aligned to each other properly or the guides not pressing the paper equally. The print head moves on a steel rod which is straight. So that can not be the culprit as the print head has to move in a straight line, irrespective of the paper being straight or slipped. So, that leaves us with the slipping paper for which there are the rollers and the guides. If you feel that the tension in the guides is not equal, then change the guides, else the rollers need a closer look. Or at least clean them with a damp soft cloth and allow them to dry up before using them.
Nov 04, 2009 | HP Photosmart C6180 All-In-One InkJet...
I lost my manuel and can't seem to remove old cartridge samsung ml2510
hello Try this : static.tigerdirect.com/pdf/Samsung-ML2510-Manual.pdf
Sep 22, 2009 | Office Equipment & Supplies
Computer restarts after trying to print. Internal error - false
Sounds like you have a virus on your computer.
Go to download.com and get Malwarebyte's Anti-malware program. (free)
Install it, update, and then run it.
Be sure your anti-virus and Windows updates are done, too.
Sep 11, 2009 | Samsung ML 1610 Laser Printer
Font not Printing.
Try reinstalling the print drivers.
May 29, 2008 | Epson Stylus Pro 4800 InkJet Printer
Samsung ML2510 laser printer not working
unplug from the wall and try it again after an hour
Jan 10, 2008 | Samsung ML-2510 Laser Printer
Samsung ML-2510 Laser Printer Logo
22 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
