Question about Xerox WorkCentre 4118X All-In-One Laser Printer
Why is there an open heat error message for xerox work centre 4118x
Bubbabear64
  • 2794 Answers
SOURCE: FAX ERROR MESSAGE
It sounds like the fuser rollers are not at the proper temperature to work.
They should be inspected by a technician.
Posted on Jun 19, 2008
  • 2072 Answers
SOURCE: my xerox workcentre pe 220 machine have an error message on "low heat error"
You will have to replace the fuser.
Posted on Apr 19, 2009
pineworks
  • 4041 Answers
SOURCE: Xerox Work Centre C2424 System Error
Hi there
I found some thing maybe do for you it may not be rhe right code you have at this moment but it come in handy for you.
31,004.40:6909: it's a mechanical initialization jam error. Pull out the paper tray to make sure it doesn't have a jam. Try also to manually feed some heavy paper or card stock through the printer to make sure the sensor in the preheater isn't stuck.
39,002.40 : DRAM test failure.
39,012.40:56208: "Cycle the power" and if that does not work replace the document feeder.
39,012.41: Document Feeder Optical Failure. Replace the document feeder.
4,0XX.6x: Process Control Software Fault.
· Reset NVRAM and then retest.
· Ensure ground integrity for the system
· Replace the EEPROM chip.
· Reboot the system.
· From the System Setup menu, go to "Information", "Troubleshooting"
· Service Tools menu.
· With the cursor at the top of the Service Tools menu, press both the Up Arrow
· and Down Arrow buttons to display the Hidden Service menu.
· Reset NVRAM is in there.
Also may be handy is this.
4,0XX.6x Process Control Software Fault
Error 04,041.66
Solution 1:
a. Reset NVRAM and then retest.
b. Ensure ground integrity for the system.
c. Replace the EEPROM chip.
d. Reboot the system.
1. From the System Setup menu, go to Information --> Troubleshooting -->
Service Tools menu.
2. With the cursor at the top of the Service Tools menu, press both the Up Arrow and Down Arrow buttons to display the Hidden Service menu.
3. Reset NVRAM is in there
Solution 2:
1. Turn the system power ON.
2. Wait for the Xerox logo to begin moving across the display.
3. Before the logo is centered on the display, press and hold the Back and Info buttons on the control panel.
4. Hold both buttons until the display reads “Beginning Service Mode Initialization”. Release the buttons and the system reboots into service mode with the Service Diagnostics menu displayed. Hope it will help you in some way of finding the fault. Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 03, 2010
  • 33 Answers
SOURCE: Hi i have a Xerox work
Heater quarz lamp is blown/cut. You can access it by removing the right side back vertical panel, removing a connector and four screws. You can pull the whole fuser assembly out very easily.
There is no spare part for the lamp itself. You must replace the fuser unit (which contains the lamp + thermostat).
Posted on Sep 15, 2010
  • 2072 Answers
SOURCE: Xerox Work Centre XD120f -
J2 means the drum unit has reached the end of its life. You need to replace it.
Staples . office max etc normally has them in stock.
If not google a company called The Parts Drop.
They will have what you need also.
Posted on Oct 25, 2010
My xerox work centre 4118 is locked How am I going to unlock it
Do you mean your "Scanner" is locked? Were the paper exits to the left of the opening there should be a sliding switch. I suggest that you should use a flashlight to locate it This is the locking mechanism that once toggled , it will unlock the scanner. Remember to turn-off the printers power before attempting this.
I hope this resolves your problem, Steve
Nov 06, 2015 | Xerox WorkCentre 4118x multifunction ( fax...
Open heat error
Disassemble fuser and inspect thermistor, thermostat and heat lamp. Replace broken part.
Nov 24, 2010 | Xerox WorkCentre 4118X All-In-One Laser...
Open heat error xerox work Centre 3119
Jul 12, 2010 | Xerox WorkCentre 3119 Laser Printer
Problem scanning with a Xerox 4118x printer
you might have to configure the scanner manualy
May 24, 2010 | HP Jetdirect 175x Print Server
Error message open heat error is appearing how do i fix the problem?
The fuser will need to be replaced. There is a web type heating element in that fuser that goes bad.
Feb 18, 2010 | Xerox WorkCentre 4118X All-In-One Laser...
Open heat sensor
Bad fuser . There is a heating mesh in the heat roll that opens.
That requires replacing the fuser.
You can call Xerox or google a business called The Parts Drop and order it there. I would recommend The Parts Drop. Have done business with them for years. best in the business.
Feb 09, 2010 | Xerox WorkCentre 4118X All-In-One Laser...
Workcentre 4118 open heat error
Bad fuser module. There is a web mesh heater in that heat roll that goes bad.
Jan 16, 2010 | Xerox WorkCentre 4118X All-In-One Laser...
My Xerox Document Centre 265ST just stopped working and a message: Copier is not available Printer Fault please call for assistance I cannot access tools or anything else.
turn it off completely unplug it. open up all doors and trays....turn it on with everything open if you still get the error you are going to have to call in a tech if it starts up . start closing things till you get to when that errror comes up then repost and ill look up an answer for you. i work for xerox
Dec 14, 2009 | Xerox Document Centre 265ST Printer
FAX ERROR MESSAGE
Jun 19, 2008 | Xerox WorkCentre M20i All-In-One Laser...
Xerox WorkCentre  4118X All-In-One Laser Printer Logo
20 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
