Question about Samsung WA5451ANW 4.7 cu. ft. Top-Load Washer
How to fix an E3 error code on Samsung washer
2 Suggested Answers
Bajanguru
  • 7752 Answers
SOURCE: washer error code
try a hard reset *2767*3855#
Posted on Aug 18, 2008
I have a Samsung vrt top loader washer it keeps displaying 3e. Sometimes it will not even do it. What could be the problem
Melisa, Check and see if still under warranty and contact Samsung for repair.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Global Download Center
Samsung Washers
Mar 02, 2016 | Samsung Washing Machines
What does the E3 code mean on the 540 model and is there a fix?
Troubleshooting the "E3" error code in Maytag MAH6700 ...
fixitnow.com/.../troubleshooting-the-e3-error-code-in-maytag-mah6700-...
Feb 20, 2011 - These codes in your (made-by-Samsung) Maytag washer might pop up during the ... In fact, the E3 error code means that the Machine Control wants to make the motor spin but won't do it because it's getting a weird reading from the tachometer.... MAH6700 and MAH8700 models (they use the same motor).
I have a samsung frontload washing machine. A code E3 is ...
www.shopyourway.com > Denise LaGrasse > Questions
Mar 15, 2014 - My samsung front loader is not working. do not no what E3 means. ...code F26 mean on a Kenmore Elite model 110.4708 washing machine?
How To Fix 3E Error Code On A Samsung Washing Machine
www.appliancerepairlesson.com/.../how-to-fix-3e-error-code-on-a-samsu...
May 15, 2015 - Samsung uses the 3E error code to indicate a drive motor tach fault. ...If you're handy, you can fix your Samsung front load washing machine error code ....My samsung frontload washer shows e3 and the drum does not turn ...
Jan 06, 2016 | Washing Machines
Samsung front load washer. What is causing E3 code?
My error code database says:
Error: E3,
Machine: Washing Machine,
Type: Samsung,
Fault: Too much water in machine. Check pressure chamber for blockage,check pressure switch and air hose for leaks, check solenoid for sticking or jammed valve.
Dec 26, 2015 | Washing Machines
Error e3
Thank you for your post, friend!
I understand that your Electrolux washer is displaying an "E3" error code while it is spinning. However, it appears "E3" is an invalid error code. It is possible that the error code is missing characters? I suggest resetting your washer. You can do this by flipping the household circuit breaker for roughly ten minutes. If resetting the power does not correct the issue, and your washer continues to display "E3" I would recommend contacting a professional to come and properly diagnose your appliance. -Matt
Aug 11, 2014 | Electrolux Washing Machines
Error code E3
E3 on Samsung Washers is generally associated with Overflow/Fill problem, and is often the result of using the WRONG type of detergent or overdosing with detergent, both leading to excessive foam. This soap foam falsifies the pressure switch detection error of an overfill.
Jun 26, 2014 | Samsung Washing Machines
After main washing, stops and can't spin. Gives error E3.
The "E3" error indicates that a Samsung washer's motor is not running properly. The cycle can usually be restarted by pressing the "Start/Pause" button. However, if the error code appears again, you should contact an authorized service technician.
Sep 25, 2013 | Washing Machines
Errhr code ee
There is no error code ee
Could it be 3E or E3
if is 3E then it means "High current detected"
if its E3 then it means "Motor not running properly"
here is the link to the manual I checked all manuals starting with the model number Wf337AA the error codes are all the same.
http://downloadcenter.samsung.com/content/UM/200710/20071010083409359_WF337A-02440A-06[1].pdf
Jul 11, 2012 | Samsung WF337AA Front Load Washer
E3 error code will not wash, what does this error code mean?
i have a maytag washer and it says E3 and it will not work,does anyone know what that means please let me know...thanks
Apr 18, 2009 | Maytag Neptune MAH5500B Front Load Washer
Washer error code
Jun 15, 2008 | Samsung SGH-E900 Cellular Phone
Samsung WA5451ANW 4.7 cu. ft. Top-Load Washer Logo
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
