Question about Lands Phones
Why does my BT4500 show an F all the time - Lands Phones
I have blocked a number by mistake, how do I unblock it?
Hi Kathleen, The link below is a user manual for a BT4500 CORDLESS PHONE.... The answer you're looking for is on page 28 When you enter the block calls list you can also edit or delete numbers you've stored previously by selecting and then pressing to display either and pressing Delete number You must subscribe to a Caller Display service from your network provider for the block nuisance calls feature to work. Charges may apply.
http://www.manualslib.com/manual/713677/Bt-Bt4500.html?page=1
Mar 31, 2016 | BT 4500 Cordless Phone - DECT - Satin...
When I record programme from the tv it always cuts of at least one or two minutes before the end of the programme is there any way to fix this
Try setting the time of your DVR to be precise. If the recording starts 2 minutes before the show starts it will cut off 2 minutes before the show ends! My DVR has functions that allow me to add a minute or two before or after the times set to record, but that can cause other problems like if you are recording 2 shows and you try to record a new show after a show that was being recorded, it won't allow you to, because it can only record 2 shows at a time! Best bet is tro synchronize your watch to the Internet time and use that to sync your DVR time.
Dec 03, 2015 | Televison & Video
How to re set phone
hi there more often than not phones like your Bt4500 have a battery that's installed inside the handset, now after long charge times and the handset being plugged in the base the battery becomes lifeless and faulty and dies, once a power cut happens as the handset has no longer got power the battery can not recover ! my best advice would be to open the back of the handset and locate the battery and replace with same from mapplins or ebay and give new battery a good charge this should get your phone working again
Mar 04, 2015 | Panasonic P-P301PA/1B Cordless Telephone...
Caller display doesn't work
From the BT website...
"If you are using your phone on a broadband line make sure you fit an ADSL microfilter between the telephone line cord and the telephone socket."
I'm guessing you have one on the landline, probably next to the router but not the handset base :-)
Why is my Caller Display not working Help BT com Help
Apr 23, 2014 | Lands Phones
If i put my camra on self timer win i print the pictures will the time show up on the pictures
The time it took the picture? You want to know if the camera will show the time it took the picture using the self timer?
My answer is Yes and No.
Do you have your camera set to showing the date and time on the pictures now? If you do, then using the self timer would not change anything.
If you do have it set to showing on the picture and you don't want the date and time to show then change the setting on the menu function of the camera and turn this option off.
If you do not already have the camera set to show the date and time, using the self timer option is not going to make it suddenly appear.
Mar 26, 2011 | Vivitar ViviCam 5022 Digital Camera
I'm having trouble setting this item. I can get it to come on, but it won't turn off at the set time. What am I doing wrong? Thanks, Janene
I don't have a Woods 59112 Manual
Here's link to Woods 49063 manual aka Woods TD1000 aka Noma TD1000
If manual is same/similar as your manual, then read solution given below
If solution below is incorrect, the write out your instructions ... I found that writing out instructions makes things clear.
Solution:
I think you have set ON time but did not set corresponding OFF time
Below is whole programming layout for you to read through
The important thing is to look at the display while programming
For example, lets say you are setting ON time for PROG1
For ON time, the display shows 3 things:
-display shows PROG in upper left corner
-display shows the number 1 to right of time
-display shows the word ON to the right of the number 1
Now you want to set OFF time for PROG1
For OFF, the display shows 3 things:
-display shows PROG as before
-display shows 1 as before
-display has changed and shows the word OFF to right of number 1
Here's how to set Woods TD1000 timer
Plug in timer to see if battery will recharge. Display shows when battery is charged. No display, then timer is no good.
TD-1000 timer has 8 on-off functions per 24-hour day
Timer has 5 buttons + reset:
TIME MODE PROG HOUR MIN
Set current time
Press and hold TIME > use Hour to set hour, Min to set minute
Release Time button ... correct time should show
Program: Capacity for 8 on-off times per day
Press PROG to set first ON time
ON and number 1 are displayed on left
Use hour and minute button to set ON time
Press PROG to confirm
Now, OFF and number 1 are displayed
Use hour and min key to set OFF time
When 8 programs are set, Press MODE key.
Choose Manual OFF. Manual ON, Auto ON, Auto Off
To use programs, select Auto ON
DST daylight savings time has to be done manually.
Press HOUR MIN button simultaneously > timer set up one hour
Repeat again and timer goes back one hour
Do not plug timer into extension cord > must be plugged into wall
Oct 05, 2010 | Woods INDUSTRIES 59112 INDOOR DIGITAL...
My PC takes very long time to get started. Disk checking shows "Invalid time set up". Dialogue box shows "CMOS WRONG". drjsil@yahoo.co.uk
just reset your computer time if it is not on the taskbar do it on the control panel. or you can set your time in the bios set up.
May 03, 2009 | Computers & Internet
Time bar
Press the 'Time Bar' button on the remote to toggle the feature on & off.
Sep 05, 2008 | Toshiba RD-XS34 DVD Player/HDD Recorder
Date and Time Setting
You can download the manual for the 1260-3 which I guess is very similar from the link below: http://www.victortech.com/admin/images/products/1260-3%20manual.pdf Here are examples of the date & time setting: Set DATE to September 14, 2004 (09-14-04) 1. Depress the C or C/CE key.Your display with show 0. and the tape will read 0.C. 2. Depress the TIME/DATE key and hold until the display is flashing. 3. Enter the month, in our example, 09. Your display will show 9. 4. Enter the day, in our example, 14. Your display will show 914. 5. Enter the year, in our example 2004, as 04. Your display will show 91404. 6. Tap the TIME/DATE key to set the DATE. Your display will now show 09-14-2004. 7. To PRINT the DATE, depress the (#/S) key, your tape will show # 9.14.2004. Set TIME to 4:37 PM 1. Depress the C or C/CE key. Your display with show 0. and the tape will read 0.C. 2. Depress the TIME/DATE key and hold until the display is flashing. 3. Tap the TIME/DATE key to go to Time Mode. 4. Enter the hour, in our example 16 in military time. Your display will show 16. 5. Enter the minutes, in our example 37. Your display will show 1637. 6. Tap the TIME/DATE key to set the TIME. Your display will now show P 04-37-00 and the seconds will begin counting. 7. To PRINT the TIME, depress the (#/S) key, your tape will show #?04?37. Please update the question & let us know if the information given was useful to you - Good Luck!
Aug 17, 2007 | Victor 1260-2 Calculator
Lands Phones Logo
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
