Question about Dishwashers
Maytag MDB6000AWW Spray Arm not turning
The soap remains in the dispenser after the wash cycle has finished. The door to the dispenser is open when the dishwasher door is opened.
I emptied the dishwasher of dishes and started a wash cycle. I opened the door of the dishwasher and found the water level was just below the heating element.
I noted the positions of the lower and upper spray arms and closed the door again to continue the wash cycle. When the door was opened again, the bottom spray arm had moved, but the upper on had not. Tried this a couple of more times to verify, and the top spray arm never moved. I have cleaned both of the spray arms thoroughly but the problem persists.
Can someone suggest what I should do next?
Thank you in advance!
SOURCE: Dishwasher upper arm does not spray
possible ball valve problem
Posted on Jan 03, 2009
  • 254 Answers
SOURCE: SPRAY ARM ASSEMBLEY NOT TURNING ON MY BOSCH
If your dishwasher leaks, check these:
Main tub seal
Door gasket or seal
Water-inlet valve
Hoses
Main tub seal Note… If the main motor of your dishwasher is mounted vertically, beneath the center bottom of the dishwasher, the following instructions probably apply to you. But if your motor is mounted horizontally, the pump isn't serviceable--you need to replace the entire pump and motor assembly.
The main tub seal is beneath the drain impeller. It prevents the water in the dishwasher from leaking out near the shaft of the motor. To get to the seal, which is inside the dishwasher, remove the:
  • Lower rack
  • Spray arm
  • Spray arm support
  • Wash/drain impellers
Then pry the seal out of its housing and replace it.
Door gasket or seal Over time, door gaskets and seals harden and lose their ability to seal properly. You can't repair the seals. You need to replace them if they've begun to leak.
Water-inlet valve The water-inlet valve, itself, seldom leaks. But, the water-supply line from the house and the rubber tube leading from the valve to the inside of the dishwasher may leak. Tighten or repair/replace these as necessary.
The water-inlet valve could mechanically stick open. When that happens, the water continues to flow into the dishwasher, which then floods your kitchen. Turn off the water supply to the dishwasher, and replace the valve.
Hoses Behind the lower access panel on your dishwasher are several rubber or plastic hoses. If the leak appears at a connection, try a new clamp. If that doesn't work, replace the hose.
  1. A common leaking trouble maker
  2. Another common leaking trouble maker - especially for leaking out of the door area
  3. Can I use a rubber or plastic hose for the hot water on my built in dishwasher ??
  4. Some common pump assembly pictures...
  5. Dishwasher Basics
  7. Dishwasher soap notice
  8. Draining and washing help
  9. Help for storing an appliance
  10. How to remove the access panels
  11. I just installed my food waste disposal, now my dishwasher will not drain, what could be wrong??
  12. I moved and lost the tap adaptor for my portable d/w, help!!
  13. Important disclaimer
  14. I would like to try to install my own dishwasher
  15. Loading your dishwasher help
  16. Motor and pump assembly screw and impellor help
  17. My dishes are not as clean as they used to be, what might be wrong?
  18. My dishwasher racks have rusted.
  19. My dishwasher will not fill with water
  20. My dishwasher will not start
  21. My soap dispenser will not open
  22. Sand like deposits inside the glasses and d/w
  23. Some common soap door dispensers breakdowns
Posted on Mar 09, 2009
  • 412 Answers
SOURCE: Lower spray arm does not spin on my bosch dishwasher
Sounds like you may have put it together wrong. I would just take the arm back off and make sure that it all fits together right. A little tip for you too. Dishwashers will clog up all the time with water deposits and food gunk. There are all those expensive cleaners out on the market but the best and cheapest way to clean them is with white vinegar. Simply pour it into the dishwasher when it is empty and run it on the pots and pans setting on hot. Always make sure to pre heat your water too by running the sink till it starts steaming. This will make it easier for your dishwasher to heat the water. If you don't, then when you turn on the dishwasher it starts to fill with cold water and has to heat it on its own. Run the vinegar though through it at least once a month or so and it will extend the life of the dishwasher. Hope this helps. Just try taking that arm back off though and putting it back together making sure everything is fitting properly. If you have any other questions feel free to ask me. Good luck.
Posted on Mar 20, 2009
MNfisherman
  • 11896 Answers
SOURCE: upper spray arm on dishwasher does not move
you most likely have gunk inside the arm or holes not allowing the water to spray out and turn the arm. Otherwise, the arm bearing may be stuck and will need a gentle push to loosen up.
Posted on Sep 22, 2009
  • 2501 Answers
SOURCE: lower spray arm siemens aquastop dishwasher doesn't rotate
Sprayers require water to pass through the jets to provide motion to the arms.
Suggestion;
Remove the sprayer from the machine and look for blockages. (Removal should be easy, at it is expected that the user will need to clean the jets occasionally; If you have any problems removing it, consult your manual).
Posted on Dec 14, 2009
Testimonial: "Thanks for a speedy and v helpful reply. Sounded obvious, but I hadn't checked the water inlet(which was calcified)just the jets on the arm itself! "
After running a cycle, there is some water in the tub and the soap dispenser is open but the soap has only run down the inside of the door. It does not sound like there is a vigorous spray during the wash...
May have a stripped wash impeller. I would tear into the pump and look for any kind of obstruction but if its clean probably the motor assembly needs replacing.
Sep 27, 2011 | Frigidaire Dishwashers
Hi I have a Blanco dishwasher BFDw8 which is having poor wash results in the top tray I have tried all the trouble shooting things in manual. Investigated further by opening door during wash cycle several...
  1. Check the water temperature. Should be 125 to 140 F.
  2. Check pump re-circulation., Listen, see if it sounds like it is spraying the water around with enough pressure.
  3. Check water level when the fill cycle has completed. Should be just under the heating element. If not, possibly need to replace the water inlet valve.
  4. Check the spray arm and pump cover for splits or leaks.
  5. Check to make sure dishwasher is draining after each cycle. There should only be a little water in the bottom of the tub.
  6. Make sure the dishes are loaded properly, or dishwasher is not overloaded.
  7. Possibly try a different detergent. Some liquid-gels will bubble and a pump cannot pump bubbles.
Scrape away large pieces of food, bones, pits, toothpicks, etc. Burned on food should be loosened before loading. Empty liquids from glasses and cups. Foods such as mustard, mayonnaise, vinegar, lemon juice and tomato products may cause discoloration of stainless steel and plastics if allowed to sit for a long period of time. Unless the dishwasher is to be operated at once, it is best to rinse off these food soils. Load racks so that large items do not prevent the detergent dispenser from opening. If the dishwasher drains into a food disposer, be sure disposer is completely empty before starting the dishwasher.
just click on the above questions for more help the answer will come to the screen
  25. Stainless Steel Cleaning
  26. Strange grinding noises and not washing properly
  27. The dishwasher doors falls down
  28. White filming on the glasses
Oct 05, 2008 | Dishwashers
The soap remains inside the dispenser, thus door opens up, but soap remains inside....just drips down the door.
What you have is a faulty cycle timer. Replace this and your dispenser will dispense the soap when prompted.
Mar 16, 2011 | Kenmore Elite Stainless Steel 24" BuiltIn...
Hi. My problem is with my dishwasher detergent dispenser. It does open (at least it is open at completion of cleaning cycle), appears to deliver soap to dishes (as they appear clean), however, from the...
There are three common problems that cause the Soap Dispenser or Cup not to open. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem
Detergent Cup does not Open
heatman101
Feb 14, 2011 | Maytag MDBH985AWB / MDBH985AWS 24 in....
Dishwasher soap still in door after wash cycle, so dishes are not very clean. Soap dispenser cover is sprung open but soap (on both sides, wash and prewash) is still mostly where it was poured, only now...
Check for the right amount of water in tub. In this unit close to the lip of the tub after fill. If water fill is correct check movement of lower spray arm. Other possibilities delayed action of dispenser from defective wax motor. Most probable is wash motor. Start unit after fill and when was starts, open door and see if water is being pushed to the top rack and dripping from the top of tub. Motor is easy to install.
Oct 12, 2010 | Maytag MDB7100AWB Dishwasher
The soap dish opened, but the dishes were not cleaned. The soap remains on the door even after two or three wah cycles. Checked all of the buttons.
Since you mention that your dishwasher has a dispenser has a flap that opens but detergent does not come out, the problem could be the wash water is not getting to it.
Can you confirm if during wash cycle the water is circulating especially through the top wash arm.
Keep a small container on the top rack and see if there is water collected in it at the end of cycle. Alternatively run the dishwasher with door open (you will have to find a way to enable the door switch inside the latch).
Please post a comment to confirm what you observe.
Sep 07, 2010 | Maytag Dishwashers
GLD6500 Series Dishwasher -- soap dispenser has
Yes that's normal for that machine. The soap has to be washed out of the soap drawer by the top spray arm turning, and that's usually the problem - the arm isn't turning. Check both spray arms for blocked jets at the very end - remove blockages with a pin and water flow from tap. In the worst case, you may need a new spray arm - but they are usually cheap.
More points to remember - on a rapid 30 minute wash program only, if you are using wash tablets, don't put them in the soap drawer as there wont be enough time for them to dissolve. put the tabs in the cutlery basket. Also - a dishwasher is not a garbage disposal unit, and uneaten food must be scraped of plates before putting them in the dishwasher. Run a dishwasher cleaner through now and then, or do a full program wash with nothing in the machine to clean it out and to keep spray arms clear.
Feb 02, 2018 | GE 24 in. GLD6500L Built-in Dishwasher
Powdered Soap Dispenser
The soap door doesn't open fully on that model, and usually flips fully open as you open the dishwasher door.
It relies on the top spray arm turning to 'wash' the soap out of the drawer - and that will be the problem.The spray arm isn't turning.
Check the spray arm for blocked jets at the very end - use a pin to clear them out, or replace them - check both spray arms. Make sure the spray arm rotates freely also.
Remember the dishwasher isn't a garbage disposal unit - remove food deposits from plates etc before loading the machine. Run a dishwasher cleaner through the machine now and then. Food like pasta, or fruit pips often get carried to the end of spray arms and block them.
If using a 30 min rapid wash program ONLY and dishwasher tablets, put the tab in the cutlery basket as it wont have time to dissolve fully if you put it in the dispenser.
Feb 02, 2018 | General Electric Profile PDW7980NSS...
Soap still in dispenser even though the dispenser door had opened
Be sure that nothing on the top rack is interesting with the door opening. Next place in unit in the wash mode. Let it fill and start washing. Open door and you should have water standing just below the lip on the wall of the unit below the lower rack. If so you are full of water.
Next is to ensure your washer rotating arms are not plugged. The very end of the upper and lower arms spray on the door to wash the soap out. If the are contaminated you will have to remove them and clean the out.
Lastly, the dispenser is operated by what is called a WaxMotor. Simply put it is a small amount of wax contained in a tube with a piston inserted. There is then a heating element around the tube. When it appmys heat the wax expands and pushes on the piston which I turn releases the door to be opened by its spring.
These can go bad and open too late in the machines cycles. It is located in the door and unless you are quite handy I would recommend a qualified technician.
Jan 01, 2018 | Maytag 24 in. PDC3600A Built-in Dishwasher
Maytag jetclean eq plus dishwasher: soap problem
This could be due to 2 problems: not enough water or water is not being pumped hard enough through the system. The 'not enough water' is easy to check - open the door in the middle of a wash cycle. If you have enough water (about 1" or more) then that is probably ok. The 'not pumping hard enough' could be as simple as plugged up filters and holes in the spray arms. Remove the racks and disassemble the lower spray arm and the filter assembly all the way down past the screen. Clean the arm holes, throughly clean the screen, clean everything. Pull the top spray arm and throughly clean the spray holes there. Put it all together and run a cycle. You should see a pronounced increase in the sound of the water spraying around. This should fix your problem - it did for me.
Mar 11, 2008 | Dishwashers
Dishwashers Logo
328 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
