Question about Timex Expedition 40141 Wristwatch
Indiglo circuit broken - Timex Expedition 40141 Wristwatch
The light quit working.
One of two things could be causing the issue. If you have used your Indiglo a lot then the light source has burnt out. The other possibility is that the micro switch inside the case that turns the light on and off has broken. The only way to find out which is the cause is to take the back of the watch off and inspect the works. If you have to pay a watch shop to diagnose and fix the issue you are probably better off just replacing the watch. The labor bench charge in most shops for one hour will probably be more than what you paid for your watch. If you are not sure it might be worth contacting a few of your local shops to see what they would charge to diagnose the issue.
Mar 06, 2011 | Timex Indiglo Analog Watch
Display disappears when Indiglo is pressed
That means your watch has two batteries - one for the movement and another one for INDIGLO. It may have just one battery, but in this case INDIGLO is taking up too much power. Replace the battery and you will be sorted. Rate me, plz.
Feb 19, 2010 | Timex Watches
Indiglo light does not light
Replace the battery for Indiglo function.
Feb 16, 2010 | Timex Expedition 84601 Wristwatch
After about two years, my indiglo night light function stopped working. The watch is still working, keeping time. Will changing the battery fix the indiglo problem?
Definitely, battery change will solve the Indiglo light problem. Many of wristwatches has separate battery for Indiglo function, but my advise is to change them both at once - will be cheaper for you.
Rate me, please.
Sep 01, 2009 | Timex 2J611 Watch
Timex T49271 Expedition Indiglo button dead?
There is no separate battery for the indiglo,maybe indiglo circuit is lose or defected already,just open the watch and check for lose connection.If happen the circuit is tight and still not working then replace the indiglo circuit.
Hope it may helps you;
Regards
VOTIT
Mar 23, 2009 | Timex Expedition 40141 Wristwatch
Timex indiglo. Indiglo feature died.
The indiglo technology is time limited (it dims over the years with use) and cannot be repaired - have you had the watch a long time? if so, I'm afraid it's time to get a new one. Sorry!
Dec 30, 2008 | Timex Watches
THE INDIGLO DOES NOT COME ON WHEN THE BUTTON IS PUSHED. THE WATCH CONTINUES TO RUN HOWEVER. THE WATCH WAS A GIFT THAT HAD NO ENCLOSED WARRANTY FOR ME TO FILL OUT/MAIL IN. WHAT CAN YOU DO FOR ME?
Many of Timex watches has two separate batteries- one for watch and another for indiglo feature. It looks like you have to replace indiglo battery. Nearest watchmaker will do that for you.
Dec 18, 2008 | Timex Watches
INDIGLO watch setting procedure
how to set the time from military to reg
May 04, 2008 | Timex 27191 Wristwatch
Expedition Indiglo Waterproof 50m
how much is this worth my uncle gave it to me
Jan 17, 2008 | Timex Expedition 40141 Wristwatch
Keeping time and indiglo light not working
check to make sure the button is making contact with the circuit board. It may need to be adjusted. Try and manually make contact with the copper contact. If it lights, then just adjust the tab.
Oct 15, 2007 | Timex 27191 Wristwatch
Timex Expedition 40141 Wristwatch Logo
Top Timex Watches Experts
Ansel Alberto
Ansel Alberto
Mark Schmit
Mark Schmit
Carol
Level 1 Expert
Are you a Timex Watch Expert? Answer questions, earn points and help others
