Question about Magnum Air 2 HP 5 Gallon Twin Tank Air Compressor
Parts pressure relator
My gas cap is hissing after my ride and my fuel mileage is down, are they related?
Related? May be a possibility but the hissing from the gas cap is the vapor pressure that is generated inside the tank, usually means that you have achieved vapor lock and its trying to vent. When this occurs it's usually do to faulty vapor tule or release valve and even your gas cap. If your gas cap is not functioning correctly it will not open the valve with in this cap to relieve the pressure usually about 11psi. Stop by any auto parts store and have them pressure test the cap and replace if needed..
Apr 16, 2016 | 2007 kawasaki Vulcan 500 LTD
Is the power switch for the FH180B replaceable?
  1. McCulloch napa auto parts Pressure Washers Problems ...
    www.fixya.com > Forum > Tags > napa auto parts > Pressure Washers
    McCulloch pressure washers napa auto parts related questions and answers. ... a 7022-140a02 power switch for a McCullouh high pressure washer FH180B.
Jul 22, 2015 | McCulloch FH180B - Pressure Washers -...
Need parts for a 2009 Powermate 2400 pressure washer
check out Watercannon.com They have parts for Fiap and other small pressure washers.. Note that you have several pieces in this pic.. unloader and related are INSIDE the manifold.. All those pieces must be removed to transfer to new manifold... If its all coked up trying soaking it in vinegar for a few days... also see my other reply on unloaders,..
Also you can get that part from jacks small engines
Briggs and Stratton Power Products Unloader Manifold Part 190673GS
Aug 27, 2014 | Garden
The pressure washer leaks from inside casing letting out water/soap might be affecting pressure of hose?
If your part of the country reaches freezing temperatures during winter, the pump probably froze. This can cause cracks to brass and (especially) aluminum pump heads. It is worth opening up the case; sometimes I find loose fittings (caused by freezing) which can be tightened up and everything is fine. If it is not freeze damage, the check valve may have gone out on the soap injector, causing pressure to back flow through the inlet barb. Otherwise, you may have a worn/leaking pump seal.
This is a consumer (throw-away) pressure washer. If it's not a loose fitting which can be tightened, the unit is probably not worth fixing.
Jul 01, 2014 | Greenworks 1700 PSI 1.4 GPM Electric...
SBM-300F spare parts
Samsung Blood Pressure monitor model SBM 400 F needs ...
www.fixya.com/.../t7624392-samsung_blood_pressure_monitor_model
Jan 3, 2011 - Samsung Blood Pressure monitor model SBM 400 F needs new bladder. Are they ... Video; Photos; Link; Replacement Parts. Add. Upload ...
Samsung innotek collar replacement parts Blood Pressure ...
www.fixya.com > ... > Blood Pressure Monitors
Samsung blood pressure monitors innotek collar replacement parts related questions and answers. Ask your ... I have a samsung SBM-300F BP Monitor. It is not ...
Samsung Blood Pressure Monitor Product Support ...
personalcare.manualsonline.com/support/.../blood-pressure-monitor/
Need replacement bulb pump. Samsung ... I am looking for the samsung HD503manual can you. Samsung ... Samsung Blood Pressure Monitor Sam 300f.
Blood Pressure Monitors Parts and Accessories
Dec 04, 2013 | Samsung Health & Beauty
Cooks essentials pressure cooker manual model #918640633
Same as Fagor Duo Pressure Cooker at the www.fagoramerica.com website. Manuals and parts available...
Jul 27, 2013 | Coffee Makers & Espresso Machines
S10 blazer runs but shuts off when i stop at a light it wants to shut off
SOUND LIKE TO ME A POTENTAL FUEL PROBLEM, HAVE YOU TRIED CHANGING THE FUEL FILTER AND FUEL SYSTEM CLEANER? ITS WORTH A TRY, I USUALLY ONLY WORK ON FORDS, WHEN THEY HAVE THIS SYMPTOMS, ITS GENERALLY FUEL RELATED, OR AN IDLE AIR CONTROL VALVE, TRY SCANNING IT WITH A OBD1 SCAN TOOL, MOST PARTS STORES WILL SCAN IT AT NO CHARGE, BUT IF IT IS FUEL RELATED, NO DTC TROUBLE CODES WILL SHOW. OBD2 DIDNT START TILL 1996 YEAR MODELS. IT MAY BE A FUEL PRESSURE REGULATOR, I WOULD CHECK YOUR FUEL PRESSURE BOTH KEY ON, ENGINE OFF AND KEY ON ENGINE RUNNING. IF PRESSURE IS TOO LOW, YOU VERY WELL MAY NEED A FUEL PRESSURE REGULATOR OR EVEN POSSIBLY A NEW FUEL PUMP, BUT CHECK YOUR PRESSURE 1ST BEFORE THROWING MONEY AND PARTS AT IT.
Jul 01, 2012 | 1991 Chevrolet S-10 Blazer
P0340
The vehicle until warm runs off a different set of parameters for the computer as far as timing and fuel are concerned. Temp is not a problem at 200... and it is normal for the oil pressure to lower once warm. ( as long as you have 10 psi oil pressure for every 1,000 rpm's you are ok.)
The two codes cam/crank sensor are timing related related. So I would suspect something that deals with both sensors,Timing chain maybe?This particular engine has a problem with chewing up timing chains. If you find this to be the problem i recommend using factory GM replacement parts. I have had to re-do several that i tried to use aftermarket parts on. The only other thing that comes to mind , dealing with the drive ability, is the fuel pressure. These vehicles are sensitive in the fuel pressure area, but this should not make the light on the dash come on. You may have more than one issue. The other part of the vehicle that deals with timing is the ECM. If you have access to a scan tool with data stream on it , you can look and see if the ECM is receiving a signal.
Jul 24, 2010 | 2005 Jeep Wrangler
P0340 p0141 and p0335 OCD failed at state inspection center. How can I fix? Can I just replace the sensors myself? If so, can I find their location in the handbook?
Dec 31, 2009 | 2001 Mitsubishi Diamante
My mitsubishi mighty max is stuck in gear
Sounds like the clutch, and/or slave cylinder and related parts. Check the pressure plate, and spring tension, slave cylinder, throw out bearing. and replace worn parts
May 05, 2009 | 1994 Hyundai Excel
Magnum Air 2 HP 5 Gallon Twin Tank Air Compressor Logo
43 people viewed this question
Top Magnum Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
JOHN LAPIER
Are you a Magnum Air Tool and Compressor Expert? Answer questions, earn points and help others
