Question about Panasonic SC-AK33 CD Shelf System
Disc player how do you pause cd?
Have to leave and cd in middle of story how do you pause it to continue at later time?
Does the Eclipse Fit Clip Plus have resume play functions?
I have just discovered that if you pause the player and then let it shut off on its own then press pause again later to wake up the unit and again it will pick up where you were. Now, I don't know if it uses any battery life when it's sleeping so will just have to experiment there. But the key here seems to be NOT actually turning it off. Turning it off will reset it to song #1 every single time. Which is really obnoxious.
Feb 01, 2015 | Eclipse Fit Clip Plus 8GB* MP3 Player
What are the steps to record cd to cd
rip your cd on a laptop/pc and put in a blank cd and burn it to that simple option!
Aug 07, 2012 | Teac RW-D250 2-Disc CD Recorder
Where is the pause button on cd player model #md6451r-blk
The Play & Pause Buttons are combined, press once to Pause and again to continue.
Please leave feedback.
Cheers
Andy
May 27, 2011 | Memorex Audio Players & Recorders
Hi Last night I was listening to my disc player and when I went to change discs nothing played. I don't know if I touched the wrong button in the dark but nothing happened. I changed batteries and when...
Not to worrry , but there is a sliding button, knob that makes the set pause and called as HOLD. All you need to do is to slide the knob back,look at teh side of the door/set. please look carefully even if the pause is pressed twice.
I am sure you will find this out and continue to enjoy music during your treatment. I wish you luck and my prayers for a good treatment. Good day
Jun 17, 2010 | Memorex MD6451R Personal CD Player
Pause/resume function in analogue, manual recording mode
This player has essentially the same guts as my Pioneer PDR-509, so this is what it means...
'Repair' means the player lost power in mid-recording without commiting the track memory to a table of contents. It would likely take up to 40 minutes for the player to reconstruct it from the disk.
There is NO reason the player need be turned off (if that's where it took you) for a track pause.
Just press Pause, flip the LP over and hit Play or Pause again when you wish to continue recording.
Perhaps you don't know how to Finalize the disc either. It's not that intuitive. Press Finalize, after a while it will display a time, like 4:07. That means how long it will take to do the operation. Now press Pause and it will count down to 0:00 and be done. Then you can play it on any other CD player.
Feb 14, 2010 | HHB 830 Plus CD Recorder CD Player
I'm recording from cassette tape to CD and cannot figure out how to create a new track when I do it. I remember from the manual (which is lost) that a silence of ~4sec should automatically do it, but that...
Can you name the make and model? Maybe we can find a manual. I find a lot of them at retrevo.com. Just register for free and download whatever they have.
I think you have the 4 second thing backward.
Most CD Recorders will interpret a 4-second silence while recording as the end of a given track and will stop or pause. Some can can be set to leave a blank of 4 seconds between tracks (or not) when manually starting a new track. That can really be a problem on continuous recordings like live music or some classical material where brief silences occur routinely.
On my Pioneer PDR-509 there is a "Track No. Auto/Manual" selection that allows me to write a track manually whenever I want to. This is good for live or segued musical selections and doesn't require a stop/start of the recording. Of course, any time you pause or stop the track number will be incremented.
I can't really speak to the TOC errors. The fault could be with a) your machine, b) the media or c) the playback machine. The TOC is automatically created when you Finalize the disc. My machine takes 4 minutes to write it.
Little-known fact: a CD that is not finalized will not read/play on a CD player but a DVD player might play it from start to finish just fine, but without the ability to skip around because of the missing TOC. Nice to know if you mess up an original irreplaceable CD recording by not finalizing it and need to copy it over.
Jan 30, 2010 | Audio Players & Recorders
Can I leave a dvd movie on pause in the player for a couple of days?
No, firstly the player will stop after a short time if it is left like this to prevent damage to the lens & disc. Secondly there is no real reason to leave it in pause for such a long period of time.
Oct 05, 2009 | Sony DVP-NS50P DVD Player
Will not record disc-to-disc
The first thing to try is cleaning the lenses,sounds obvious,but i think thats why its continuing to try :initialising: if that fails the lense that reads the disc or both likely need realigning most problems that acure whith any cdplayers ect are down to the lenses.
Apr 04, 2008 | Philips CDR796 2-Disc CD Recorder
Cd player shuffles through all discs, but won't play
contact Durabrand at 1-800-252-6123 or Venturer Electronic
203 Eggert Rd,Bufflao New York 14215-0248
Dec 23, 2007 | Durabrand W600 Shelf System
Panasonic SC-AK33 CD Shelf System Logo
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Michael Kovalik III
Michael Kovalik III
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
