Question about Kenmore 24 in. 16032 Built-in Dishwasher
Kenmore Ultra Wash Dishwasher 665 clean filter disassemble power wash module
3 Suggested Answers
SOURCE: Kenmore Ultra Wash Dishwasher - 665 - 13783
dcvxzcxzcxzczxc
Posted on Feb 26, 2008
blueextc3221
  • 15935 Answers
SOURCE: Kenmore Elite 665-16959000 dishwasher - soap door
It appears your dispenser wax switch has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 30, 2010
I have a Kenmore Ultra Wash model 665 1373 and it isn't getting totally clean on the top rack - glasses and cups are almost clean but bowls etc are not, any ideas?
Check the shaft of the impeller, the plastic shaft might be broken, it was the problem with mine. To get to the impeller you have to remove the filter at the base of the diswasher and after you will see the screw that hold the impeller assembly in place, unscrew it and you will see right away if it is broken, Good luck
Jul 16, 2011 | Kenmore PRO 24 in BuiltIn Dishwasher with...
The top rack on my kenmore ultra wash 3 dishwasher does not come clean and now even the bottom is starting to not clean
First perform a vinegar cycle wash in the dishwasher. Pour a cup of vinegar into the bottom of the dishwasher. Keep the temperature at the highest setting possible and perform a wash cycle.Then start using a dishwasher most probably that would solve the problem. If this does not solve the problem then there must be some parts worn out or faulty creating the problem.
There are many probable causes of failure .
To clean the dishes the water temperature is essential.It the water is not hot then the dishes will not be cleaned properly.So check the water temperature.
Also check the filter in your dishwasher.Clean the filter if there is accumulation of debris in the filter
If you are in an hard water zone , then try reducing the amount of detergent used and then try cleaning the dishes.
Dec 23, 2010 | Kenmore PRO 24 in BuiltIn Dishwasher with...
My kenmore dishwasher 665-15817 has a blinking ''Lock On'' button
- To clear the flashing light you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
Jun 06, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore dishwasher skips the wash
Replace the electronic control board.Its located under the panel you select cycles from.
May 20, 2008 | Dishwashers
My kenmore ultra wash model #665 does not pump out water.
my model #665 dishwasher will not pump water into the unit
Apr 25, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Kenmore ultra wash 665 dishwasher heating element melted down in one corner
I know no other way the heating element could have ended up bent up like this.
Mar 05, 2017 | Dishwashers
Need to remove wash module
You should be able to hold the spray arm and unscrew the center section to remove the entire assembly. Be aware of any washers or other parts that need to be re-installed when putting it back on.
Jun 13, 2007 | Kenmore 24 in. 16032 Built-in Dishwasher
Kenmore 24 in. 16032 Built-in Dishwasher Logo
50 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
