Question about GE Washing Machine Pump Assembly - WH23X10013
Ewas600k2ww waher will not fill only pump runs
Unit will not fill pump runs the goes into agitation with no water
4 Suggested Answers
garing
  • 998 Answers
SOURCE: when i turn my waher on it starts agitating
replace the water level control (it's the one with the small tube that goes down to the outer tub( the contacts in yours are fused together) throw it on the sidewalk may jar them open....hi hi( just kidding)
Posted on Aug 26, 2009
pride applia
  • 232 Answers
SOURCE: GE front load waher Model #: WSSH300GWW fills and
take drain hose and lay it in a bucket to drain water or a wet vac works better. remove 2 scews from lower pannel it will drop down and come off. look for a accordian shaped black hose. disconnect it and remove junk in it. check inside the pump inlet for stuff it's the thing one end of the funny hose is hooked to. put back together and don't over tighten clamps nut driver tight is fine.
Posted on Feb 17, 2010
blueextc3221
  • 15935 Answers
SOURCE: it fills with water agitates and then stops does
The timer is failed.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 10, 2010
Frigidaire washer goes straight to agitation and won't fill with water.
IN UNIT THERE IS A SENSOR OF PRESURE WICH HAVE A TUBE FROM WATER CUVA , and when fill water presure high from tub activate membrana and cicle startit ;may there a problem and also at ev . of in water, chec connection and clean dirt but with main out
Nov 04, 2012 | Frigidaire Washing Machines
Waher fill up but wont agitate
see this possibles causes: God bless you
see the diagrams
Lid switch
test the switch for open or defective with VOM see the diagram
Motor coupler
replace motor coupler
Belts
can be worn.
Clutch
clutch wear
Drive motor
one winding burn, one direction if for agitaten in another winding for spin.
Drive pulleys
worn replace
Transmission
worn or broken gear, +shifter defective
Agitator
worn and replace.
May 16, 2012 | Amana Washing Machines
GE front load waher Model #: WSSH300GWW fills and agitates, but does not spin and drain.
Feb 17, 2010 | GE Washing Machines
Washer functions but doesn't fill with water, with
if it agitates without water then the fill pressure switch is stuck , this will lead the unit to beleive its full already.
replace the water level/fill switch for the fix.
Phil
Jun 10, 2009 | Washing Machines
Whirlpool Roper Gets to Rinse then water runs but will not fill
The contacts for the outlet pump have fused together in the programmer so that as soon as you apply power the pump motor starts running.
Remove the power first
Quick check is to take off the back panel locate the pump and remove one of the supply leads
put some insulating tape around the end of the lead you have taken off in case it shorts out then put the power back on and try the machine, it should then fill and start to agitate .
If that works then you need a new programmer .
Turn off the power , replace the lead and then put the machine back on to drain out the water
Jun 05, 2009 | Roper RAS6233KQ Top Load Washer
Commercial speed queen won't agitate
sounds like it is in the gearbox, possible broken gear
May 26, 2009 | Washing Machines
Fills, doesn't pump to sprayer, drains on drain only cycle
Sounds like there is still something in the pump. I am 99% certain this unit has a reversable motor.
Jan 26, 2009 | Kenmore 24 in. 16539 Built-in Dishwasher
Doesn't agitate
Place the unit in the spin cycle and see if it will pump the water out and if it will spin. (This makes the motor,transmission and pump run in the opposite direction.)
Jan 13, 2008 | Maytag Performa PAV2200
Bosh dish waher
Does it make the same noise when it's just filling or just when the motor starts? Usually just filling the dishwasher opens a valve and doesn't run the pump. If it makes noise during filling the valve may be getting hot and shorting, or may have a loose connection, or air may be in the water supply line causing the valve to bounce. If it takes a long time to fill the filter may be clogged.
Nov 30, 2007 | Bosch 23 in. SHU 8805 Built-in Dishwasher
GE Washing Machine Pump Assembly - WH23X10013 Logo
10 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
