Question about Shark Helmet NV22L Shark Navigator Upright Bagless Vacuum
Wher do i buy broken plastic piece on motor housing above brush roller on shark navigator vacuum?
  • 2,478 Answers
Do nothing. Call shark cust. service. They should send you a new part.
Posted on Oct 19, 2014
2 Suggested Answers
macofusa
SOURCE: brush roll won't turn on
Atthe bottom of the vacuuam are screws to take off...two of them are near the rear wheel assembly....two of them are behind the front mini wheels (just pry the front mini wheels so that they pop out...they pop back in)
Remove all of the screws. Remove the bottom from the top..they come apart in two pieces. Ceck the belt on the bottom piece. Slide the roller out starting from the end opposite from the motor end. With the roller off, slacken the the belt so that it misses the gear on the motor (you will have to hold it with your hand). Plug in the vacuum. Turn the power on to the roller on position. The motor should work and the green light should be on. If the motor doesn't work, then it is defective. If it does work, turn off, unplug and shoot the gear and the two ends of the roller with WD-40. reassemble. good luck.
Posted on Jun 24, 2012
Why wont the roller brush turn on my navigator shark NV22L
It could be a bad switch or brush roll motor, a broken belt, loose wire or contact. You must inspect and test all these areas to narrow down the cause.
Feb 28, 2017 | Euro-Pro NV22 Shark Navigator Bagless...
Roller on shark navigator professional
Hello, this is Ava with Think Crucial.
There are a number of reasons why your brush roller has stopped moving. General maintenance to your vacuum is crucial and will help it work at peak performance.
First things first lets focus on the brush roller. Unplug the vacuum and turn it on its side. Look for any noticeable clumps of debris or hair strands that may be caught in the brush roller. Remove these obstructions, probably best to do so with a scissor if it's hair or long pieces of carpet fibers. After removing the debris try manually rotating the brush roller to uncover other hidden clogs. Another thing to take note of is the condition of the bristles on the roll itself. Are they loose or worn down? These are signs that your brush roller is in need of replacing.
While checking out your brush roll you might as well take a look at your vacuums belt. Your belt should be replaced about every three months. After regular usage, the belt will stretch out, lessening the tension on the brush roller. Lesser tension diminishes the brush roller's turn rate and speed. If the belt feels loose then it certainly is affecting your vacuums suction as well as your brush roll not moving at all.
You can purchase a wide variety of high quality Shark replacement parts for your Shark vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=shark
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Nov 27, 2016 | Shark Vacuums
Roll brush on the shark navigator lift awat
While checking out your brush roll you might as well take a look at your vacuums belt. Your belt should be replaced about every three months. After regular usage, the belt will stretch out, lessening the tension on the brush roller. Lesser tension diminishes the brush roller's turn rate and speed. If the belt feels loose then it certainly is effecting your vacuums suction as well as your brush roll not moving at all.
http://www.thinkcrucial.com/search?type=product&q=shark
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Ava B.
Sep 24, 2016 | Shark Vacuum. Navigator Lift-Away Bagless...
Any idea where to find a replacement roller brush for the shark navigator motor head?
Did you try the Shark website?
http://www.sharkclean.com/support/parts-accessories/11/vacuums/
May 27, 2014 | Shark Helmet NV22L Shark Navigator Upright...
The brushes don't appear to be spinning...it looks like the belt falls off, though it's not broken. Also, the motor reves down to what seems to be very slow speed if it's been on for more than a few...
The brush roller may be clogged on the ends, causing the belt to stretch and fall off. If you remove the brush roller and check for free rotation of the ends you may have to disassemble it to remove hair and/or other debris.
Mar 03, 2014 | Shark Navigator Bagless Upright Vacuum
Brush won't spin on my shark navigator.
Maybe not the same issue, but my roller brush would only work intermittently. I had to take apart the main housing and clean the two contacts (female side) that connect to the lower brush assembly. Now it works like new.
Oct 30, 2011 | Shark Navigator Bagless Upright Vacuum
Brush roller won.t turn. It turns for a sec. then shuts off. I have cleaned all clogs. This is a shark navigator. Can I remove bottom of vac to access the roller? The manual doesn,t mention this as a...
There are a number of reasons why your brush roller has stopped moving. General maintenance of your vacuum is crucial and will help it work at peak performance.
First things first let's focus on the brush roller. Unplug the vacuum and turn it on its side. Look for any noticeable clumps of debris or hair strands that may be caught in the brush roller. Remove these obstructions, probably best to do so with a scissor if it's hair or long pieces of carpet fibers. After removing the debris try manually rotating the brush roller to uncover other hidden clogs. Another thing to take note of is the condition of the bristles on the roll itself. Are they lose or worn down? These are signs that your brush roller is in need of replacing.
While checking out your brush roll you might as well take a look at your vacuum's belt. Your belt should be replaced about every three months. After regular usage, the belt will stretch out, lessening the tension on the brush roller. Lesser tension diminishes the brush roller's turn rate and speed. If the belt feels loose then it certainly is affecting your vacuums suction as well as your brush roll not moving at all.
https://www.thinkcrucial.com/collections/vendors?q=Shark
Ava B.
Apr 06, 2011 | Euro-Pro NV22 Shark Navigator Bagless...
Brush roll won't turn on for the shark NV22L vacuum. the light on the brush roll is dark, not red or green
Feb 10, 2011 | Shark Helmet NV22L Shark Navigator Upright...
Shark Helmet NV22L Shark Navigator Upright Bagless Vacuum Logo
102 people viewed this question
Top Shark Helmet Vacuums Experts
Think Crucial
Think Crucial
Dennis Key
Dennis Key
Are you a Shark Helmet Vacuum Expert? Answer questions, earn points and help others
