Question about Whirlpool Dishwashers
Whirlpool top rack not working
No water spraying
SOURCE: Dishes not cleaning particularly on top rack
Thank you, so much, for the update!
Lita
Posted on Jun 18, 2008
  • 188 Answers
SOURCE: Top spray not functioning in dishwasher
The top rack is not cleaning because of low water pressure from the wash motor to the upper spray arm.
Assuming the top spray arms are clear of debris, remove the lower spray arm and lower feed tube to access the wash motor. Remove the 4 torx screws and the filter (accumulator assembly). Remove the torx screw and the inlet protector that covers the chopper assembly. Make sure the chopper is not broken (broken chopper will fill with debris and block water flow). While holding the chopper blade, reach inside the "D" shaped opening on top of the motor and spin the wheel/motor by hand in each direction to make sure either the chopper gear or the motor gear that drives the chopper is not broken. Replace the chopper if necessary (part # 8268383). If the motor gear is broken, replace the sump and motor assembly (part # 8535150). Remove any debris from the sump area in the process.
You don't have to shut the power off to the dishwasher because the door will be open, but if you feel more comfortable, do so.
Posted on Apr 23, 2009
  • 744 Answers
SOURCE: dishwasher not cleaning dishes on top rack
Check the riser tube coming from the pump assembly and be sure it isn't blocked or that something else isn't obstructing the pump intake area. Make sure the upper wah arm assembly isn't excessively loose on the spindle and losing pressure because it's leaking. You may have to remove the lower rack, lower wash arm and cover to see.
If everything is clear, it could be a worn or damaged pump impeller. If the machine drains normally, it's not the motor.
Posted on May 16, 2009
  • 423 Answers
SOURCE: whirlpool dishwasher top Spinner and top rack
First, confirm that the holes are not blocked on these arms. (I did not want to assume you have done this.)
Then check the impeller on top of the motor stem for being loose or worn/damaged - to rule the impeller out. If it is fine, then the motor is failing and too weak to drive the spray arms.
To answer your question, I think the answer is "They don't make them like they used too!"
Posted on Sep 12, 2009
SOURCE: top rack not cleaning and spray arm possibly not moving
I removed the lower arm, the strainer, and three screws (Torx, but I used small allen wrench). I took of the pump cover, and found a small white ball blocking the tube that goes to the top rack sprayer. I put everything back except the ball. It has worked well ever since.
Posted on Mar 27, 2010
My Whirlpool Quiet Partner II does not clean the upper rack of dishes properly. They are greasy. I have checked the top spray arm for blockages. There were none. I am fairly certain that water is
Make sure the center loading is not obstructing the water jet to the top shelf. Top shelf is only for glasses and saucers , use Jet-Dry .Pre rinse and clean bottom pan strainer from dirt debris.
May 14, 2012 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool Gold Dishwasher - GU2700XTSB The top rack of the dishwasher is not cleaning. The bottom rack dishes clean fine. There are no clogs in either the bottom or top spinner arms, the plastic tube...
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
Dishwasher Residue and Film on Dishes
heatman101
Jan 20, 2011 | Whirlpool GU2700XTSB / GU2700XTSQ /...
Whirlpool DU1301XTV dishwasher - the top rack started cleaning woefully a few months ago. The bottom seems OK. I checked wash arm action by starting the washer and opening the door several times. The...
Hi, I have an older dishwasher also and recently my wife alsocomplained about it not cleaning right... so me being the man I am tried invain to clean the things... Bought new spray arms online and installed them inminutes...now the thing works like new... However I have also found that if theheating element goes bad then that also can mess things up bad... So I wouldbuy new spray arms, and also check out the heating element to make sure it isworking... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
Dishwasher Problems The Heating Element not Working
heatman101
Nov 04, 2010 | Whirlpool DU1301XTV Builtin Dishwasher
I have a whirlpool gold dishwasher model Quiet Partner 3. The top rack is not cleaning the dishes very well. We live in the country and have hard water. I am wondering if there could be a buildup of some...
if it is just affecting the upper rack i doubt it is just a plugged spray arm (though i could be wrong). more likely than not you have a blockage on the intake of your spray pump motor. a series of bones, toothpicks, foreign material, etc could be blocking the entrance of the pump causing it to starve for water so to speak.
you will more than likely need to remove the lower rack and spray arm to be able to disassemble the strainer and gain access to the sump.
a complete model number would help bunches to.. alas
May 20, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
Whirlpool du1055xtsq 3 not cleaning top rack of
In my experience, you probably have a clog in the spray arm/arms for the top rack. Take the arm(s) out and see if the holes in them are clogged. Rice, plastic wrappers, and glass from dishes that broke in there are the most common culprits I've seen.
Nov 25, 2009 | Whirlpool Dishwashers
Top rack items are not coming clean
When you slide the top rack out, there is a tube below which aligns with the back wall when closed. if the clips come loose or it does not go all the way back to the "cone" shaped spout , it will not spray water from top wand that spins. if using a disposal, the smell will help to throw a lemon or lime in and grind with water running slow.
Nov 06, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
No water going thru washer arms
remove the pump screen and, clean the pump
you probably have broken glass preventing the pump impeller from moving
May 29, 2009 | Whirlpool Gold Black-on-Black 25.4 cu. ft....
Dishwaher does not clean, upper rack
Assuming the top spray arms are clear of debris, remove the lower spray arm to access the wash motor. Remove the 4 torx screws and the filter (accumulator assembly). Remove the torx screw and the inlet protector that covers the chopper assembly. Make sure the chopper is not broken (broken chopper will fill with debris and block water flow). While holding the chopper blade, reach inside the "D" shaped opening on top of the motor and spin the wheel/motor by hand in each direction to make sure either the chopper gear or the motor gear that drives the chopper is not broken. Replace the chopper if necessary (part # 8268383). If the motor gear is broken, replace the sump and motor assembly (part # 8535150). Remove any debris from the sump area in the process.
Mar 13, 2009 | Whirlpool 24 in. DU1100XTP Built-in...
Mar 09, 2009 | Whirlpool 24 in. GU2500 XTP Built-in...
Dishwashers Logo
12 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
