Question about Epson Stylus RX680 Color All-in-One InkJet Photo Printer
Where is the paper sensor on epson stylus rx685?
I am getting a false paper jam message. Done all the usual including the good old vacuum. I can only think it is a faulty sensor, but where is it? Hmmm...?
  • 4 Answers
SOURCE: Epson Stylus CX8400 Paper Jam Error
I have the same exact problem of paper half torn removed but I can not see the other half anywhere. The printer has hardly worked for at the most six pages and now showing paper jam error. How do I fix it?
Posted on Aug 12, 2008
Dipu007
  • 2110 Answers
SOURCE: Epson Stylus D88 Plus paper jam
1. Unplug the power and USB cables from the printer. I pried open my C42UX printer, careful not to break anything. I use a flat blade screwdriver to pry it apart; there are two-three tabs at the back and two at the front. Gently push them in, and then using a bit of force pry apart the cover.
2. Next I removed the two (2) waste ink pads. They are located at the back on the left hand side. I used the flat blade screwdriver to lift up the ink pads (they were soaked). Please use rubber gloves as it gets very messy.
3. Next I took the pads to the kitchen skin and washed them with just plain hot water until they were white again. I just let the hot water run on them (the pads are about three inches long).
4. Once washed I dried them using a hair drier. (you could place it the sun for a few hours or on top of your heater or maybe in a heated oven; (make sure you do not set it on fire with too much heat).
5. Once dried I placed the pads back in the ink waste bin at the back of the printer.
6. I closed the printer cover and put back all the pieces and plugged in the USB & power cable and turned it on. (Yes the lights are still flashing).
7. Go to this link and download this software: http://inkjetprinterhelp.us/epsonSSC.html
8. Install the software and run it.
9. Select your printer and model number ( It only says C42 there is no UX, choose it anyway).It will ask if you replaced with new pads; say “YES”. Then close the window.
10. Now right click on the SSC service utility, it looks like a printer icon near your clock in the task bar.
11. Then click on reset counters. You can do all other stuff with this utility too.
12. Turn off the printer power and then turn it on again. If necessary un-plug the power cord from the back of the printer, wait 20 seconds. Plug it back in.
13. THERE YOU GO! IT WORKS AGAIN.
14. By the way I use generic ink and I fill my own cartridges. I use ink from www.atlanticinkjet.com. Great stuff.
try this and let me know it worked or not ...
Posted on Dec 12, 2008
SOURCE: Epson Stylus Photo R350 giving a paper jam error message
An Epson service man (he was VERY kind to suggest this) told me to use a weak detergent solution on the rollers, NOT alcohol as that will dry out the material the rollers are made of. Although the problem has recurred a couple of times, it's worth repeating when necessary. I actually activate the 'print' command so it tries to feed in paper, while I FIRMLY hold a piece of fine cotton cloth stretched over a thin plastic ruler, which I hold down where the paper feed grabs its paper. The printer has a couple of tries to feed paper, reports an error message (because there was no paper) and I activate it again, thus exposing the WHOLE of the feed wheel to the cleansing cloth! WORTH A TRY!
Posted on Feb 20, 2010
pineworks
  • 4041 Answers
SOURCE: Epson Stylus TX110 printer paper jam light flashing but no paper
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 28, 2010
KingDWS
  • 1606 Answers
SOURCE: My Epson 1290 (some years old) doesn't grab paper,
That could be from the rubber rollers not being able to grip the paper. They get polished or shiney over time with use and age. Then they slip or pull incorrectly and you get your problems. There are other things that can cause this but nothing worth fixing.
Fixing the rubber rollers is easy. You need some ispropyl rubbing alcohol and a paper towel. Make sure it is isopropyl type as this won;t attack other parts. Simpley wet the paper towel and wipe down the rubber rollers. You will see the rubber go from a dull shine to dull flat rubber. This takes off the buildup on the rubber and lets it grip again. Eventually the rubber will age harden and this trick won;t work but this can give you years more service.
Posted on Apr 20, 2010
I have an Epson stylus photo PX 660,which is displays an error message that,paper jam inside and in real sense there is no any paper jam inside.show me how i can solve this problem.
Check the rollers (the inlet and outlet for the paper) and blow them out with a blower,vacuum, or a can of air. That should "fixya" right up. Lmk if it doesn't and I'll get down to specifics with more info from you as well
Feb 12, 2015 | Epson Stylus Photo Px660
Paper jam in px 710
The next step it to test each sensor, both mechanically and electrically. Get really good light on the sensors, sometimes little hairs cause a false read. Verify that each sensor opens and closes electrically when actuated.
Sep 25, 2012 | Epson Artisan 710 AllInOne InkJet Printer
I HAVE A EPSON STYLUS SX218 IT IS ALWAYS SAYING PAPER JAM EVERY TIME I WANT TO PRINT AND THERE IS NO PAPER JAMED IN IT . IT IS ONLY 1 MONTHS OLD.
This error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
Apr 12, 2011 | Office Equipment & Supplies
Top light blinking. Getting paper jam error message repeatedly. Cleaned the pad. did a nozzle check, replaced THREE cartridges. Did not give my blood type yet. How to fix? The waste pad is not...
Feb 18, 2011 | Epson Stylus Photo R2400 InkJet Printer
Paper jam has been cleared, but paper jam message remains.
Try these steps and see if it resolves your problem. Hope it helps:
Follow these steps to clear a paper jam:
  1. Press the cp_button_45_er.gif Start button to eject the jammed paper. If that doesn't work, go to step 2.
  2. Turn off the Epson Stylus.
  3. Lift open the scanner and remove any paper inside, including any torn pieces.
  4. Close the scanner, then turn the Epson Stylus back on.
Aug 02, 2009 | Epson RX595 Photo All-In-One Printer
EPSON STYLUS PHOTO RX685
try with chip reset for all you cartridge
Jun 29, 2009 | Epson Stylus Pro 10000 InkJet Printer
My Epson r220 photo printer is giving false paper jams. What can I do?
the false paper jam problem is creating by paper out cansor so please this is the repairing mater you care it a repairing shop.
Jun 23, 2009 | Epson Stylus R220 Photo Printer
Message: Error paper jam. There is no paper jam.
Yes there is some micro piece of paper is under a sensor somewhere Get serious and pull it apart, what have you got to loose! Inkypete
Apr 20, 2009 | Epson Stylus Photo RX500 Printer
Paper Jam
because of your paper sensor is not working or jam
Feb 28, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Epson Cx3200 paper jam
Then there is something stuck in the paper feed path which is holding up the sensor flag making it think there is paper in it.
Or maybe the sensor flag has been broken off by yanking paper out the wrong way when it gets stuck.
Get your vacuum cleaner and stick the hose down the paper feed path and see if it suck out a push pin, piece of paper paper, fur ball, eraser, coin, toe nail, false eye lash etc (all of which I have removed from machines with "paper jams")
Dec 12, 2007 | Epson Stylus CX3200 All-In-One InkJet...
Epson Stylus RX680 Color All-in-One InkJet Photo Printer Logo
53 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
