Question about Solar Hardware & Accessories
Why do I have intermittent alarms? - Solar Hardware & Accessories
I have a Taurus 2004, and it happens that the car horn beeps 3 times randomly. does anyone know what would it may be?
the horn beeping at random is indicating a fault in the alarm system. alarms have their own battery which is balanced by the car battery and any unbalance ( corroded connections -bad earth, low charged battery in alarm, loose battery connections ) will cause the horn to sound --same as too sensitive a setting for the alarm or a intermittent power to the alarm
Mar 08, 2015 | 2004 Ford Taurus
How do I stop smoke alarm from beeping
Smoke alarms beep in two different ways: it beeps continuously when smoke is present, and it beeps every so often (intermittently) when the battery needs to be replaced.
Feb 18, 2015 | Cars & Trucks
F1 alarm intermittent
check the block under rear seat a white one small 2 wires in it, short them with a hair clip or fuse wire turn ignition on see what comes up on dash
May 12, 2014 | Suzuki Boulevard C50 Motorcycles
Car alarm goes off intermittently for no reason
Save yourself a big headache and disable the alarm system.
Jan 25, 2014 | 2003 Lincoln Town Car
I have a MGE Galaxy UPS and it's giving me an intermittent alarm saying "INV. NOT. SYNC./ AC.BP".
Dear Yared,
The alarm is pretty clear about what is going on. It's a syncing issue between the inverter and your bypass supply.
What you can try is to go to the 'Command Screen' of the UPS and select Resynchronize AC BP.
Best regards,
Ron
Nov 13, 2012 | MGE UPS Galaxy 3000 UPS System
Need to reset prestige car alarm - going off intermittently
If your alarm is going off intermittently:
It could be the shock sensor; usually located around the steering column under the dash. It is a small black box with two small lights ( one red, one green) and a philips screw used to adjust the sensitivity. Counter clockwise reduces the sensitivity.
It could be an open trigger: door, trunk, or hood pin. If you have a pin in the trunk or under the hood that was added by the installer, they sometimes can be inadvertently bent downward by loading the trunk or, some guy changing your oil. If that is the case, just bend them back upwards until they make contact with the hood/trunk lid when closed and you receive one chirp when arming the system.
Here is a quick way to determine what exactly is causing the alarm to trigger:
After the alarm triggers, disarm the alarm and pay close attention to the LED light. One flash is the shock sensor. Two flashes is the hood/trunk pin. Three flashes is the door trigger.
Oct 06, 2010 | APS787 Prestige Remote Start and Security...
Alarm goes off intermittently and has run the battery down. It is happening every other day or.
Your Alarm sensor is set to high *sensitivity level*...either have sensor adjusted or disconnect
Aug 28, 2009 | 2003 BMW 5 Series
2001 Acura 3.2CL security alarm problem
Make sure your car battery is 100%. (Battery test.) Batteries only last 3-5 years.
If battery power drops down, alarm designed to come on.
Other possibility, if someone in neighborhood nearby (within 500 yards) has a cb radio or ham radio or a service truck with a radio in it, that could set off the alarm intermittently due to same radio frequency.
May 22, 2009 | 2001 Acura 3.2CL
Intermittent alarm
pull your range out there is a tech sheet on the back that will tell you what the reason for the f1 code is. you can go from there.
Jan 03, 2009 | Magic Chef Kitchen Ranges
Hardware & Accessories Logo
Top Solar Hardware & Accessories Experts
Gil Shultz
Bill Boyd
Gene Haynes
Are you a Solar Hardware and Accessory Expert? Answer questions, earn points and help others
