Question about Toro TimeCutter SS5000 zero turn mower
Toro time cutter every time you turn key on it blows a fuse
Have replaced battrie cylnoid checked switch that ok but now burnt wires
2 Suggested Answers
2strokeJim
  • 577 Answers
SOURCE: I have a 05 Toro 44in ZTR with a 19HP Kawasaki
sounds like your electric clutch is prob bad check to make sure wires are not bare touching something, the clutches do go bad eventually like any other electrical part, disc the pigtail and try fuse, if it blows then I would consider a clutch
Posted on Jul 28, 2011
Pto will not work on ss4235
could be the switch, pto assy, fuse, broken wire. belt off the pulley. take your pick
Jun 18, 2015 | Toro Mowers - Time Cutter SS4235 42""...
Toro lx 500 riding lawn mower
check the connections from the battery to starter-check the fuses -and relays than start with the safety switches --seat-clutch-and cutter deck the safety switches are a kill switch
May 24, 2013 | Garden
TORO TIME CUTTER SS4235,NOT STARTING,NO ELECTRCAL POWER TO SWITCH
Check wiring for ground. Ensure battery is fully charged or replace. Replace spark plug. Clean or replace air filter. check oil level, all mowers have a low oil start cutoff. Bad gas? Flush out fuel tank by removing gas line, flush fresh gas thru. Reattach gas line, fill with fresh gas, always use Stabile in gas! Check fuel line for cracks and secure connection to carb. Battery should read 12.8 volts or higher. .
Aug 21, 2012 | Toro TimeCutter Zero Turn Lawn Mower...
My toro keeps blowing fuses when i turn the key i have a toro 14-38hxl wheel horse rider
its either getting to many amps which will blow fuses
you might have a short (positive wire touching metal)
fuses are not right ie: 10 amp when should 15amp
trace the leads from the key switch (turn it on) to your coil check that they are good
the coil might be faulty
hope this helps
Sep 30, 2011 | Toro Lawn Mower With Toro Power Tools
I have a 05 Toro 44in ZTR with a 19HP Kawasaki engine with under 300 hours the main 30amp fuse keeps blowing when I turn on the ignition switch on. I noticed when I disconect the PTO switch the fuse dousnt...
Jul 27, 2011 | Toro Zero Turn Rider 74833 Lawn Mower...
2000 Grand Voyager blowing the ignition fuse
Was the old fuel pump bad? It might be worth the cost to replace the ignition switch. The wires to the fuel pump would be a second guess if the old pump was bad and burnt the wires before the fuse went. When you eliminated the fuel pump you also eliminated the wires to the pump and it started. Then you replaced the pump, but not the wires. The ignition switch is the other end of the circuit.
Jun 08, 2009 | 2000 Chrysler Grand Voyager
1989 Chevy Pick-up..when 4x4 engages it blowes THE FUSE!
I would replace the 4 x 4 actuating switch located top rear of transfer case. The switch has a 2 wire harness hooked to it. The same thing happened to mine. Cost me $80.00 and 30 minutes.
Feb 04, 2009 | 1989 Chevrolet K1500
No brake lights blows fuse every time
there is most likely a short in the wires have you put a tow package on it if so did you splice in to the lines check all wires and see if they are burnt any were most likely short
Jan 05, 2009 | 1995 GMC Jimmy
Toro TimeCutter SS5000 zero turn mower Logo
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
