Question about Electronics - Others
My rv generatar runs great and cranks great but it will not run any thing inside my rv. Every thing works great when I plug to outside power. I checked all the fueses inside and out but do not see anything wrong. Thanks
  • 158 Answers
In most situation where you have a dual power source there is a relay or a switch. You may have a box or lever that switches from external to generator power. If you can't find a switch then it is most likely you relay gone bad.
Posted on Jul 01, 2009
Runs/cools great unless outside temp gets in high 80s
try replacing capacitors. or communication cable issue to that a/c
Jun 25, 2013 | Dometic Rooftop RV Air Conditioner
Starts runs for a minutes quits but if you keep pushing the start button it keeps running
You say Guardian that is Generac???? Then you indicate Onan 4.0KY. If it is a Onan and it stops after you release the button there are a couple of things. 1 st check the brushes, and polish the rotor slip rings, check the resisitance of the rotor, the electrical harness plugs are tight. The control requires a voltage feedback while cranking to engage the PCB run circuits, if all those check out you have a bad control board.
Feb 15, 2013 | Onan Cummins 4.0 KY-FA/26100 RV QG 4000...
We have a 96 rexhall rv. we have had the unit plugged into shore power from the house and had been running the air conditioner. it ran great about 4 times and now we can not get it to kick on with just the...
If your plugged in to a 15 amp household receptacle, then an extension cable of any kind or length, then that is likely your problem. An AC unit should have 20 amps of good power available to it. If your using an extension cord of any kind, and it is any less than 12 gauge wire, then that will cause a drop in voltage as well. Obviously the best scenario would be to install and wire a 30 amp receptacle outside your house just for that use, if done often. Take a voltage reading at receptacle, then inside RV, and see how it is probably a little less without even the AC on, then when AC kicks in, or tries to.
It may work once in a while, but it's not good for the AC to try and operate on low voltage, which causes a higher amperage draw.
Aug 27, 2011 | Dometic Rooftop RV Air Conditioner
No 110 power inside coach when pluged in to shore power.Have checked everything I know and still no outlet power. I do know alot about repairing things but have not hit on it here. Power will come to the...
I take it you metered for voltage at the shore power outlet, and at the cord end itself where it plugs into the RV, is there a buck/boost transformer..if so does it have a breaker, are there fuses at the inlet receptacle. Are all GFI outlet breakers in the RV checked for normal position?
Jun 12, 2011 | Electronics - Others
RM 2652 RV refrigerator runs on gas, not on AC. Power surge took out power converter and refrigerator power module. Replaced converter and power module. All display panel lights working. Cools great on...
just had same thing happen to mine. replace control board. starting working on gas. one the ac I then replaced the ac heating element and now working great on ac
Mar 21, 2011 | Dometic RM2652 Refrigerator
HOW TO WINTERIZE AQUAMATE ABOVE GROUND SWIMMING POOL PUMP
Open the plugs on the bottom front of the pump pot and on the pump housing itself. These two plugs will do the pump and just the pump. You should have simmilar plugs on the filter, heater, chlorinator and any other equiptment on the system.
Oct 13, 2010 | Hayward Sp1580x15 Power Flo Lx 1.5hp...
I have a 1992 Itasca Toyota RV with a electric issue
Is there power at the gen? The transfer switch may not be transferring power over from gen. Check it at the gen first thing.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Aug 05, 2009 | Electrical Supplies
Fan works, but if A/C turned on, trips breaker within a few minut
You need to verify if the problem is the unit or the breaker.  To do this, you will need to measure the current it is pulling from the power source.
If the unit is pulling too much current, then the unit is the problem.  If the unit is pulling as much or less than its rated current draw, then the circuit breaker is worn out.
The units WILL pull more power when hot outside.  It should not trip a breaker unless something is wrong with either the unit or the breaker.
A current draw test will tell you for sure.
If it's not the breaker, then it's probably low refigerant causing the issue.
Jul 08, 2009 | Dometic Rooftop RV Air Conditioner
Rv Generator does not turn on inside power, but cranks great
The regulator could be inside the gen. Maybe under one of the covers on the front. I'd poke around and take a cover or two off and look it over. You may be surprised!
Jun 22, 2009 | Electronics - Others
Electronics - Others Logo
74 people viewed this question
Top Electronics - Others Experts
Marvin
Marvin
Are you an Electronics - Other Expert? Answer questions, earn points and help others
