Question about General Electric Dishwashers
Why does Dishwashing solution not empty into dishwasher?
The liquid or powder is left in the soap dispenser and trailing down into the machine , this is fresh soap, that I am using
    Problem Solver:
  • 16 Answers
Sounds like the soap door is not opening. This is controlled by a relay in the door. This panel needs to remove to troubleshoot.
Posted on Jan 30, 2015
  • 81 Answers
SOURCE: Soap still in dispenser and dishes dirty after dishwasher is ran
Your description sounds like the water pump is wearing out. Call the repairman.
Posted on Apr 24, 2009
handygirl911
  • 65 Answers
SOURCE: I put liquid dishwashing soap
I suggest purchasing a pipette (long thin flexible plastic eyedropper thing) from hobby lobby, Frye's, or from a scientific lab supply.
Draw up as much a you can from inside. Apart from that unless you remove the panels from the door to access the reservoir, then it may take several more washes to remove the soap from the the rinse additive dispenser. One more thing, you could start the machine in the rinse mode to wash the dishes and stop it when done and restart in the wash mode to rinse. When that is finished, stop and restart in the drying cycle. Good Luck!
Posted on Jul 03, 2009
THENTHEREWER
  • 131 Answers
SOURCE: 13 year old daughter put liquid dishwashing soap
Sorry but thats funny!!lol About the easiest way I know to tell you is take a turkey baster or marinade injector & draw as much as you can out of the reservoir,fill it with water & repeat until you get very little foam when putting water in it.Fill with rinse aid & the rest will just have to work its way through.Should be fine after a few wash cycles.
Posted on Jan 07, 2010
Testimonial: "Thank you! That should work. Also, I ran the empty dishwasher with the lid to the rinse dispenser off, which flushed most of the soap out."
  • 457 Answers
SOURCE: Wet dishwashing soap
make sure that the you let the hot water run for 2-3 min to make sure it is hot going into machine or it will not break down the soap.if the dispenser is opening then it is a tempproblem. let me know if my assistance was any help with a 4 thumbs up post
Posted on Feb 27, 2010
  • 423 Answers
SOURCE: After the dishwasher runs there is a lot of soap
With the LG LDF6810 model, this is not a common problem. Please try the following test, With and empty dishwasher, add a small to normal amount of dry dishwasher powder and run an (empty) load.
Check to see if any soap remains in the dispenser cup.
If any remains, here are three things to do: 1.) Upgrade your dishwasher detergent to a name brand powder (e.g.: Electrosol or Cascade)
2.) When you load the dishwasher, do not place large items in the front, near the door/soap dispenser.
3.) Before you load the dirty dishes for the next several loads, with your hand, turn both the upper and lower wash arms so they point at the door. Load as you normally do and push the racks fully in. Before you close the door, spin both the upper and lower arms and confirm that they spin freely and neither hits anything. if either does not spin freely, pull out the rack and arrange so the arms can spin freely.
I find that the only time I have left over detergent powder is when the wash arms do not spin freely.
This is a common problem on most every energy star/water conserving dishwashers.
Please report back what you find, OK?
Posted on May 21, 2010
The dishwashing powder dispenser opens, but does not empty. After the wash, you have the powder that is one harden mass.
This usually indicates that either the machine is overloaded, or the "fill valve" has
failed. If the center hole in the lower rack is covered by dishes the soap will not
dispense properly because the "power tower" cannot pop up to spray.
The fill valve is relatively inexpensive, located under the machine and requires
shutting off power at the breaker panel and shutting off the hot water
to the machine to change out.
Jun 05, 2011 | Whirlpool Dishwashers
How can i use the liquid soap inside the dishwasher
just fill the same holder that you would use for powder.
Dec 17, 2010 | Dishwashers
After the dishwasher runs there is a lot of soap left in the soap dispenser. I've tried powder and liquid. Liquid is a bit better. I've tried using less soap but there still is a lot left. Also my glasses...
May 21, 2010 | LG LDF6810ST Stainless Steel Built-in...
Feb 27, 2010 | Maytag 24 in. MDB9750AW Dishwasher
Soap not breaking down in dishwasher
Be sure to run kitchen water hot at faucet before starting dishwasher or you will get an entirely cold water washer. Also be sure the jet dry dispenser is not empty. Only use liquid jet dry. Pay no attention if soap says with jet dry. Does not work as well. Hope this helps.
Jan 31, 2010 | Frigidaire 24 in. FDBB840DC Stainless...
Soap dispenser does not open during wash
Well you can please follow the below steps -
1. Remove any dishes in the dishwasher. Unhook the dishwasher's dish trays or racks from their tracks, and set aside. Empty the soap dispenser if it contains unused soap that failed to dispense. Use a wet rag to wipe down the interior of the dishwasher, as well as the inside of the dispenser.
2. Close the dispenser, and shut the dishwasher door. Turn the dishwasher on to a manual setting, then stop it and open the appliance. Check to see if the dispenser is open. If it is, continue to Step 2. If the dispenser is closed, skip to Step 4.
3. Switch dishwasher soap. Some dishwasher dispensers have difficulty with dry or liquid dishwashing soap, depending on the make and model of your dishwasher. Incompatibilities typically result in the dispenser sticking shut, which explains why the dispenser opens when empty. Switch to liquid soap if you are using dry powder soap, or vice versa.
4. Check the dishwasher soap dispenser's spring. The spring is located behind the dispenser top's hinge. Consult your dishwasher's original manufacturer's manual or user guide to find a replacement spring. Pop the old spring out with a screwdriver, and replace with a new spring. This should resolve any issues related to the dispenser failing to open.
Please post comments if you need more help or information..........
Good Luck!!
Thanks
Jan 08, 2010 | Kenmore Dishwashers
13 year old daughter put liquid dishwashing soap in the rinse dispenser. Now all dishes come out covered in soap scum. How do I get liquid dishwashing soap out of the rinse dispenser?
Jan 07, 2010 | Admiral 24 in. DWUA601 Built-in Dishwasher
Dishwasher soap dispenser does not release(sometimes partially)and as a result dishes are not cleaning
the solenoide which pops open the soap lid may be faulty.
Better to poar your dishwashing powder or tablet in the bottom of the dishwasher tray until you get the machine repaired. You may want to do a prewash rinse first, then stop the machine and add your soap.
Make sure not to use too much soap. Just the normal amount as you would use in the soap dispenser.
Ash
Oct 27, 2009 | Dishwashers
There is soap left at the end of a cycle from the dispenser. It is trailing down the door and standing in a puddle at the bottom of the dishwasher. The soap that is not in the trap door seems to wash...
Try different detergent types--liquid instead of powder, capsules instead of liquid. Don't put large dishes near the door that might block spray. Check the spray holes in the spray arms for blocking.
Sep 18, 2009 | GE 25 in. Nautilus GSC3400J Free-standing...
Does not wash well, does not use dishwashing liquid
Here are a few steps to solve your problem. First of all empty your dishwasher and pour in two cups of vinegar. Run the longest and hottest cycle you have. This will clean your machine.
Always run the hot side of your kitchen sink until the water is as hot as it gets and then start your dishwasher.
Switch over to a tablet as opposed to powder or liquid and just toss the tablet into the machine,
now you should be back up and running.
Aug 31, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Dishwashers Logo
69 people viewed this question
Top General Electric Dishwashers Experts
Tom
gbob59
Are you a General Electric Dishwasher Expert? Answer questions, earn points and help others
