Question about Fuji Discovery S1050 Zoom Date 35mm Point and Shoot Camera
How do you set the zoom on a computer? - Fuji Discovery S1050 Zoom Date 35mm Point and Shoot Camera
Text is too small to read
Use the zoom level on your computer, under the icon that looks like a gear, you will see ZOOM, and you can set the zoom level. Make sure your computer is also set at the right resolution size.
Apr 20, 2014 | Computers & Internet
How to zoom in my computer windows xp
hi
you can zoom in by going in the computers properties and then in the settings then there will be a bar of resolutions by changing the resolution you can change the zoom
Dec 08, 2012 | Cameras
How do you change fontz size on dell computer
  1. Change your screen resolution.
    • 1 Right click on the desktop and choose "Properties" (XP) or "Personalize" (Vista.).
    • 2 In XP click on the "Settings tab, and in Vista click on "Display Settings."
    • 3 Adjust the resolution slider to the right or left (right will set a higher resolution, left lower resolution) and then click "Apply." The screen will change to the new resolution.
    • 4 Click "Yes" to accept the changes.
    Alter the text size in the program you are running.
    • 1 Alter the text size in the program you are running. Many programs have their own font-size settings that can often be altered in a view, settings or options menu.
    • 2 Look for an option to change font size or zoom. Often you can click on a "View" menu and then click "Zoom."
    • 3 Zoom to the required size. (For many programs, you can hold down the "control" key and then use the mouse wheel to automatically zoom in and out.)
    Alter your computer's DPI scale setting in Vista.
    • 1 Right click your desktop.
    • 2 Select "Personalize" then "Adjust font size (DPI)," then "Custom DPI."
    • 3 Enter a number between 100% and 500% (higher numbers mean larger text).
    • 4 Click"OK."
    • 5 Click "Apply."
    • 6 Restart your computer.
    Alter your computer's DPI scale setting in XP.
    • 2 Select "Properties," "Settings," "Advanced."
    • 3 Click on the DPI setting you want to use in the drop-down list or select "Custom DPI Setting (other)" and enter your own number.
    • 4 Click "Apply" and restart your computer.
Jul 09, 2011 | Dell Inspiron 530s Desktop Computer
OVERSIZED DISPLAY
You can use iTunes to enable or disable any accessibility feature, including Zoom:
  1. Connect your device to a computer and open iTunes.
  2. Locate and click on the device under Devices:
  3. In the Summary pane, click Configure Universal Access:
  4. Select Neither to disable Zoom:
  5. Click OK and then click Sync to save the changes to your device.
If you do not have access to a computer or iTunes, use the following steps to disable Zoom on the device.
  1. On the Home screen, double-tap with three fingers to exit zoom.
  2. Locate and tap on Settings > General > Accessibility:
  3. Tap Zoom and turn off using the slider:
Jan 29, 2011 | Apple iPhone 3G
Help! my computer zoomed in and I can't zoom it out anymore!
Right on computer and choose the properties option and then choose the display properties and then setting(HERE ONLY OPTION FOR ZOOM IN OR ZOOM OUT) YOUR SYSTEM.
Nov 18, 2010 | Computers & Internet
Get my laptop to pick up the zoom router
What is the Operating system on the laptop ?
If it is XP then in the bottom right hand corner you will find Wireless network connection ( looks like 1 computer monitor). Use that icon to connect to the wireless network.
If it is windows Vista, then in the bottom right hand corner you will find 2 computer monitor icon. Use that icon to connect to the wireless network.
If it is Windows 98/ME/2000 then use the adapter utility to connect to the wireless network.
For MAC you will see the AIRPORT icon at the top.
Check the wireless settings of the router first . Make sure that yopu have all the wireless settings of the router. If you are not sure about the settings, then open the router set up and check the settings.
Click Here
for step by step instructions on how to connect to the wireless network and troubleshooting steps
Jan 16, 2010 | Zoom (5590-00-03) Wireless Router (G66115)
The monitor is giving a zoomed in view . its not giving the full view of the desktop screen rather a section of it is zoomed in . there are no settings to zoom out .??
ur setting may be set to low resolution...
try doing this
go to Desktop/right click/properties/Settings/Screen Resolution/
What do u c...what's the resolution there...800x600...
if the slider(pointer) is active use it to increase it to say 1024x768, 1152x864, 1280x1024 etc.
use the correct resolution....as too much of resolution will make ur monitor un-viewable...
also try if ur monitor has some press button on them to make changes to the correct setting/zooming of the screen image...
Dec 24, 2009 | Samsung Syncmaster 2033SW Monitor
Zooming with Olympus Stylus 820
Hey missy0528,
There are a few reasons your images might be grainy, one of which is your image quality is set to low. I would always have the camera set to the highest resolution possible, because you can always reduce the size of an image but you can never make it bigger. Another cause of grainy images in digital cameras is the sensitivity of the camera (ISO) is set to high. Since you are only seeing grainy images when you use the zoom the reason for the grainy images is most likely do to using the digital zoom. All a digital zoom does is crop the image much as you can do in some computer applications, and by doing this you greatly reduce your image quality. I would never use a digital zoom. Your camera has a 5x optical zoom and a 5.6x digital zoom. I would only use the optical zoom. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Jun 09, 2008 | Olympus Stylus 820 Digital Camera
When Zooming picture it produces blurred or fuzzy picture
This is when zooming through your camera LCD I presume? For small screens usually banding and pixelation is common, if this happens also when the picture is zoomed in on a larger monitor like on your computer then the resolution you set for your camera is low. You can check for the camera setting and increase the resolution from for example 1024x768 to a much higher value and the fuzinnes (blur) will disappear altogether...
Feb 08, 2008 | Fuji FinePix F460 Digital Camera
Help with my Zoom camera. ASAP
there are several possibilities here: 1. another program that was installed or used got the settings all mixed up. reinstall the camera's drivers. 2. if camera is connected via a serial cable (COM), check for serial-code conflicts. 3. if you are using a firewire cable, turn both computer and camera on, and then connect them. do not turn off the camera while cable is still attached.
Feb 08, 2006 | Zoom DualCam 1300 (1599) Digital Camera
Fuji Discovery S1050 Zoom Date 35mm Point and Shoot Camera Logo
70 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Steven Wander
Steven Wander
Are you a Fuji Camera Expert? Answer questions, earn points and help others
