Question about Oreck Vacuums
Why is my oreck xl10 dragging?
Why is my xl10 dragging whilst in use? Only a few months old, replaced belt & bag but still dragging. Struggle to move it on carpet. Checked for blockage, etc but everything clear. It's hard work using when I know from previous experience the oreck usually glides across carpets & tiles.
chrispurs1
  • 372 Answers
SOURCE: suden loud noise when vacuming carpet
Hi.
Check that brush roller (beater bar) is free to turn with no obstruction.
If it is still noisey after doing this try this site for Dyson repair manuals.
http://dysonmanuals.inc.io/
Chris.
Posted on Nov 19, 2007
  • 9 Answers
SOURCE: Oreck XL21
You can also set the brush to the middle setting of the special/ normal brush settings. Also, your micro-sweep blade might have popped off making it very hard to push in that direction. The micro-sweep is the plate held by two screws right below the intake with the little blade that sticks up.
Posted on Dec 07, 2007
  • 45 Answers
SOURCE: How to for Belt replacement and solution to suction loss
You say it lost its suction, then you also say this is plenty of suction power, seems you cant figure out the prob. Try cleaning the fan on the suction blower. The blades can get chocked with dust which will give you a reduced suction.
Posted on Jan 06, 2008
SOURCE: Dyson suddenly hard to push on carpet
I know this sounds silly, but it works. Turn it over and wipe all the black residue off the bottom of it (off the plastic on the bottom that rubs on the carpet as you push and pull it). I thought my husband was out of his mind when he told me that was the solution, but it really works.
Posted on Jul 10, 2009
SOURCE: bissel proheat 2x main suction problems
bissel pro heat x2 does not suction up the cleaning fluid
Posted on Sep 09, 2009
Suction problem
Probably have a clog some where in the base and that is what causes it to throw stuff back out.
Apr 04, 2014 | Oreck XL Ultra Bagged Upright Vacuum
Just replaced the roller on my oreck XL, and it is smelling like burnt rubber
If the roller bearings are starting to seize the the belt may be slipping
Oct 25, 2012 | Oreck XL Ultra Bagged Upright Vacuum
MY ORECK PUSHES SO HARD.
It be one of two problems or both.
1. You may need to change your belt. a belt change on an Oreck should be done about every 6 to 8 months.
2. A new roller brush. a roller brush acts like tires on your car. when the brushes wear out they have no traction and cant grab your carpet to pull the vacuum.
A combo of replacing both would more than likely be very helpful.
Aug 23, 2011 | Oreck XL2200 Bagged Upright Vacuum
Oreck does not have good suction and leaves lint on rugs, and floor---any solutions?
If it has been longer than 6 months I woulf replace the belt. Wile doing that look to the rear of the vacuum and the side chute and make sure you do not have anything plugging those entrances.
Feb 10, 2011 | Oreck XL2200 Bagged Upright Vacuum
I have an Oreck XL2 and the brush is not rotating.
First, check to see if the drive belt for the brush is broken. If it is you need to get it replaced. Also, remove the brush from the cleaner and clean if of all debris then check the small caps at both ends of the brush. If they do not move freely, add a little WD40 and rotate by hand until they move freely. When putting the new belt on or replace the old one, be sure it is put on properly so the brush rotates in the right direction.
Sep 15, 2010 | Oreck XL2200 Bagged Upright Vacuum
My Oreck XL was working fine, then when I vacuumed a shag rug is started smoking and smelled like something is burning. (I changed the bag, checked for clogs--none found, and roller brush is turning. It...
Even though the brush is spinning, the belt is probably worn out and stretched. when you vacuum the shag carpet, it puts more drag on the brush. try running it on a shorter carpet or hard floor for a few minutes. if it doesn't smoke, then you know it's your belt. if it does smoke, then it's probably the motor burning up.
Jim
Jun 02, 2009 | Oreck XL2000 Bagged Upright Vacuum
ORECK VACCUM
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=747767
Generic problem for all Vacuums
ORECK VACCUM
Posted by FISHERMAN928 on Jul 06, 2008
Older Oreck XL, new belt, new bag, checked for clogs, does not pick up
as it used to, and, much harder to push, seems to grab or drag, why????
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. There are a couple of things that may work. Depending on if you have the old style brushroll you can upgrade to a new style Oreck brushroll that has twice the brushes and will a work a lot smoother. Also, clean the bottom plate – get rid of any dust and dirt build up and then spray the bottom with silicone and let it dry after you have totally cleaned it. Always use Oreck genuine belts and to change the belt every 4 to 6 months for the best cleaning and store the extra Oreck belts in a Ziploc bag in the refrigerator, other wise if you have a new belt, gag, you have checked for clogs there is no reason why it should be hard to push, if the silicone does not work replace the bottom plate.
http://www.oreck.com/ Customer Service 1-800-989-3535
Monday thru Friday Hours are: 7:00 am to 7:00 pm CST
Saturday and Sunday Hours Are; 8:00 am to 4:30 pm CST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 06, 2008 | Vacuums
Oreck XL Classic
http://geeksquad.fixya.com/ThreadView.aspx?prdid=19810&thid=703827
Oreck XL Classic
posted by balis on Jun 24, 2008
The belt is on properly, however the brush will spin, then stop.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Oreck XL Classic. It sounds like the belt may be stretched out and my needs replacing. The average belt change is every 4 to 6 months and to store the extra belts in a Ziploc bag in the refrigerator. Also check the brushroll, the gray bearing ends with say on either side the words NEW or OLD and both ends need to be identical – new/new and old/old NOT new/old, if the belt and the brushroll are OK then it may be the motor but I don’t think so. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
Go Ahead. Use Us.
Jun 24, 2008 | Oreck XL Ultra Bagged Upright Vacuum
Oreck Vacuum Cleaner problem (upright)
The best solution to any Oreck vacuum problem is to replace it with another brand. You are going to continue having problems with the Oreck..Not that other brands don't have problems. But, at least with
other brands the problems don't occur as often. Belt burning up. clogs, roller brush bristle wearing down prematurely, cord breaking internally, etc.
P.S. Oreck is good at one thing. Marketing!
Aug 30, 2007 | Oreck XL2200 Bagged Upright Vacuum
Vacuums Logo
26 people viewed this question
Top Oreck Vacuums Experts
Kory Ronning
Randy Schumann
Randy Schumann
Are you an Oreck Vacuum Expert? Answer questions, earn points and help others
