Question about Smartboard Smart Board 680i Gen 3 Projector Lamp
What does the red temperature light mean? - Smartboard Smart Board 680i Gen 3 Projector Lamp
What does the red thermometer light mean on my Neff oven?
Please provide me with model number from the serial plate.
Feb 17, 2016 | Neff Ovens
Red power, blinking red temp
if the Lamp error and Temperature error lights are flashing red this means that there are two separate errors.
  • A flashing lamp light means the lamp failed to ignite. It could be a lamp driver problem or lamp failure. Replace the lamp to resolve the issue. If the issue is not resolved, then service the projector.
  • A flashing Temperature light signals a fan error. Turn the projector off and allow it to cool down. If the light is still flashing after the projector is turned back on, service the projector.
Goodluck..
Feb 25, 2008 | Hitachi CP-X250 Multimedia Projector
Re lights lit on freezer
Red light lit on freezer means that is not reaches operating temperature.
Most often the old freezer has three indicator lights.
- Green light : that it is brought to a power source and turned on - Red light : means that the temperature is above -18 degrees
- orange light : pressing the so-called SUPER-switch which means that the compressor is running continuously. The SUPER-button switch on a few hours before you begin deep-freeze foods. Freezing time depending on foods quantity (kg). With old freezer must be careful to turn off the switch S (orange light) when the red light goes out or when foods are frozen, otherwise after a few days may burn out the compressor. You should be following the instructions from user manual.
In new freezer managed by the electronics, this function has a predetermined maximum duration, in order to protect the compressor, and can have different marketing names like "shopping".....
Dado
Sep 02, 2014 | Electrolux Freezers
What does the red warning light by the triangle mean on a blomberg
Under normal operating conditions, the internal
temperature of the freezer will ensure the longterm
conservation of the stored food.
When such temperature rises above a certain
level (-12 °C), the appliance will trigger an
acoustic and light alarm. The light alarm is a
blink red light (Red Alarm Indicator Light), while
the acoustic alarm is an intermittent sound.
You can stop the acoustic alarm by pressing
the Acoustic Signal Stop Switch once.
When switching on the freezer for the first
time, the Red Alarm Indicator Light will
blink until the internal temperature has reached
a level required for the safe conservation of frozen
food.
Dado
May 28, 2014 | Zanussi 10.31 cu. ft. / 292 liter Chest...
What do the red light with abell shape which is lit up mean on my 18 year old tricity bendix freezer mean
It's a temperature warning that the freezer is no longer at the correct temperature. Check all is clean and working, door seal intact etc. If short of gas, probably time to get a new one!!! Bet it won't last 18 years this time though!
May 01, 2014 | Freezers
There are 3 lights on the front of the Zanussi Freezone. The green one on the left doesn't light up. What does that indicate? The red light on the right is on constantly. Does this mean that the freezer is...
Starting the Appliance
Insert the plug into the wall socket. The green pilot light will illuminate to show that the appliance is switched on. The red alarm light will also illuminate until the freezer reaches the correct temperature.
Alarm Light
The red alarm light will illuminate when the temperature in the freezer is higher than the thermostat setting. This alarm light will illuminate if:
- The appliance has just been started.
- Fresh food has been put in the freezer.
- The lid has been left open, opened frequently or open for too long.
The red light will go out when the freezer has returned to the correct temperature
Dado
Oct 14, 2013 | Zanussi 14.62 cu. ft. / 414 liter Chest...
What does the flashing red light mean?!?
The flashing red probably means that the charger is working correctly and is indeed charging the batteries. The light should turn green when charging is complete after anything from 1 to 16 hours depending on how this charger works.
Do the following test: Fit the charger with your batteries and connect it to the mains. After 1 hour check if there is a detectable temperature rise in the batteries. You can do this without interrupting the charge cycle by touching the cells with the back of your fingers. If the temperature is still low, let it continue for another 15 hours or so, checking every now & then for any temperature increase. Should the temperature rise more than a few degrees, then stop the charging by removing the charger from the mains. Should the red lamp remain flashing after 16 hours, then I suspect you to have a defective charger.
Dec 27, 2010 | Duracell AAA NiMH Battery Charger with 4...
A warning lght is on, looks like a fan and it is red. What does this mean?
It tells you that the Temperature out side is below freezing and it comes on when it cold out side. Just to warn that could be freezing places. and sometimes it get Orange too. Hope this helps
Dec 10, 2010 | 1999 Mercury Cougar
I hve a round red light on in dash, can you tell me what this is? it's at the right top just above the steering wheel to the right
If the red light looks like a radiator then the coolant is low, temperature sensor is defective, or the system is overheating. It is red so that means STOP so it is going to be something serious like oil pressure, or temperature. Is it just a round red light?
Oct 14, 2010 | 1998 Cadillac Catera
Smartboard Smart Board 680i Gen 3 Projector Lamp Logo
69 people viewed this question
Top Smartboard Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Smartboard Office Equipment and Supply Expert? Answer questions, earn points and help others
