How to fix my hdmi connection - Televison & Video
How to fix no sound audio on Panasonic viera when connected from hdmi 3 port to Sony bluray BDP s480 hdmi port?
Well, first make sure you don't inadvertently have the "mute" control on your DVD player turned to the "on" position. Does it work on HDMI 1 or 2? Play with it a bit. Connect it to other TV HDMI inputs and see what happens. Obviously, the video is getting through, just not audio. HDMI inputs on your TV carry both (unless there is a problem with one of them), as does the HDMI output on your Blue ray. Also, make sure the HDMI OUTPUT from your DVD is connected to the HDMI INPUT of your TV.
Aug 19, 2017 | Sony Televison & Video
Samsung PN43F4500AFXZA HDMI FIX
make sure you have it set to hdmi when cable is connected to source. try another working hdmi cable. try other hdmi ports.
May 08, 2017 | Samsung Televison & Video
Hdmi input not working
Video is different from HDMI. From what I have seen you should have video inputs and component inputs. instead of trying these video inputs, look for tv/component button on your remote or tv settings.
Feb 01, 2014 | Toshiba Regza 52XV645U LCD TV
I connected my dvd player to my hdtv and its only in black and white. I have adjusted the settings numerous times and it isnt fixed. the cables are all in the right color matching holes..how do i fix this?
Ur RCA AV component cable set might bad replace it with another RCA set of cable or tv have HDMI and also DVD player too for HD connection by a HDMI cable through HD hub?Buy and used a HDMI cable connect tv and DVD player to together one HDMI cable for a better functions.
Mar 21, 2011 | Hitachi P50H401 50 in. Plasma HDTV
The hdmi port on my Panasonic CT-30WC14 only works when I push the cable into the port and hold it. It has a bad connection. I was going to take the back panel off and see if I could connect to the port...
Not the HDMI port,it the HDMI cable is dead.If u have dead HDMI port holding the HDMI cable wouldn't work,make no difference.Change the HDMI cable will solved ur problems.
Sep 06, 2010 | Televison & Video
HTMI errors on the following devices DVD Blue-ray HDMI connected; CD Not HDMI connected; VCR Not HDMI connected; satellite works OK HDMI to Yamaha - HDMI to TV NO HDMI error displayed; GUI does not display...
You have to use Component Video on this unit. HDMI will not "Handshake" and pass thru. This was HDMI's first version "1.1a" and there is no fix. Use your receiver to switch audio via Coaxial or optical then use HDMI directly from BLURAY etc to your TV. The downside to this is how many HDMI inputs your TV has. It's an awesome receiver! Don't blame Yamaha!!! This issue is directly attributable to "HDMI" and their race to shelves before truly field testing the product. The current version of HDMI is 1.3b and soon to be 1.4 which includes ethernet capabilities.
I hate to be the bearer of bad news! If you would like an "in depth" look into the world of HDMI issues, Google HDMI problems or HDMI forums, and you can read for hours. Hope this helps
May 29, 2010 | Yamaha RX-V2600 Receiver
Denon AVR-2307CI HDMI won't always connect
In short, HDMI will not work. HDMI is riddled with issues, your's is just one of many! HDMI version 1.1,1.2,1.2a,&1.2b do not work 100% on any receiver. The current version is 1.3b and "so far" it works... Now the bad news; It's not just a software patch to fix the problem, it's a hardware issue as well. If your unit is still under warranty, the manufacturer will update hardware and software for you at N/C. If it's out of warranty, it's way too expensive to have done! The fix is to run your HDMI directly to your TV from source, ie. Cable,DVD, etc. then run coaxial digital or optical to your receiver for audio. The catch.. How many HDMI inputs your TV has will limit sources hooked up via HDMI. If you want further info on HDMI issues, just google "HDMI forums" and there are many different sites to answer the problems of HDMI. Hope this helps.
Aug 23, 2009 | Denon AVR-2307 Receiver
Sony bravia intermittent sound
Yep, same problem with mine. After many trial fixes, I discovered that it's the HDMI connection. I tried two different new HDMI cables in two of HDMI ports on the TV, but still got intermittent sound. The only way I solved it was going to component cables (RGB) with a separate audio cable. Works great now. Other Web sites say that HDMI connections do not always electronically "handshake" well between devices. Not sure how this HDMI problem can be permanently fixed, but using the component connection works fine.
Feb 20, 2008 | Sony BRAVIA KDL52XBR2 Television
Hdmi connections
Yes you should be able to do that. Make sure u switch between hdmi 1 and 2 on your tv. If you are still having problems try and get the tv company to fix the problem if they won't you could get a hdmi splitter on amazon for like 20 dollars.
Jan 21, 2008 | Televison & Video
Televison & Video Logo
12 people viewed this question
Top Televison & Video Experts
Electro Med Services...
