Question about Water Heaters
Salus boiler hw temperature fluctuates noticed while using shower then tested by just ruuning hot tap gets very hot then drop to just warm and then gets hot again and so on.
2 Suggested Answers
  • 62 Answers
SOURCE: fluctuating temperatures
Sounds like there is not enough flow in order to keep the burner in the heater firing continuously
Posted on Jul 11, 2009
I have a triangle tube challenger boiler. D.W & radiant. It has a drop in temperature about 1.5 -3 min. after turning water on. In shower and in sinks. Was able to watch tank and feel water from laundry...
A lot depends on the size of the tank. And when it heats some systems only heat at night , this is ok if the system is large , on most heaters there is a thermostat on the side that can be used to set to a higher temp. the thermostat on your heater may be faulty.
Dec 04, 2014 | Water Heaters
Greenstar 30cdi no hot water
It is the shower head or plumbing that has a built in mixer or reducer.
Dec 09, 2013 | Stiebel Eltron CK20E Electric Tankless...
Greenstar 30cdi hot water issue
The problem is not the water heater. The shower has a mixer or a limiter built into the plumbing so that the water wont get hot. It is a safety feature to prevent burns and protect children from scalding.
Dec 09, 2013 | Water Heaters
I have a vaillant eco pro 28 combi boiler. no constant hot water unless tap is on really low.
Oh some of these there was a small black heatexchanger just for hot water they some times block up . or it could be a blockage in the water section where it flows in .I know Valliant have a very good tech line and fitters who do house calls .
Mar 02, 2017 | Water Heaters
No hot water pressure in bathroom
bleed the system,sounds like an airlock issue
Apr 05, 2017 | Water Heaters
Hot water tank does not work when shower is on, it does however work when the faucet in bathroom is on. It quit working in the shower about a month ago.
  1. COLD MIX, HEATER DEACTIVATES
    If inlet water temperature is over 70°F due to geographic location, water maybe very hot out of the tap. This requires a lot of cold water to be added with it in order to attain a useable hot water temperature. The addition of too much cold water will overpower hot water demand from the tankless water heater. This slows the flow within the tankless water heater, decreasing it below activation point, which shuts off the heater. The end result is nothing but cold water coming out of the outlet. See: TWH E2-04 Overcoming fluctuating temperatures [PDF].
  2. FLUCTUATING WATER PRESSURE
    If the water pressure in the home is erratic and the water flow is not consistent while a tap is opened, then the temperature of hot water will fluctuate. The minimum water pressure for the home should be 30psi or greater. For people on well systems the minimum pressure range is 30-50psi. The use of a pressure reducing/regulating valve is an effective way to maintain constant water pressure to the water heater. Watts brand 25AUB- ¾" or N35B-¾" pressure reducing/regulating valves or equivalent is suggested.
  3. CHANGING FLOW RATE
    Major changes in flow rate can adversely affect the output water temperature of the heater. Increases from one major fixture running to multiple fixtures running at one time can cause the temperature to fluctuate. Stay within the heater's specifications. See: TWH E2-03 Outlet temperature vs. flow rate [PDF].
From the Bosch website.
Good Luck,
Gary
Dec 16, 2010 | Bosch PowerStar AE125 AE125 Whole House...
Vaillant ecoMAX 828/2boiler goes on & off when running hot water!
water must be set at 3lts a min ,check diaphragm valve move when hot tap is on, check microswitch ,best of luck
Aug 09, 2009 | Water Heaters
Fluctuating temperatures
Jul 09, 2009 | Rinnai Webstone The isolator EXP tankless...
Water Heaters Logo
19 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
