Question about Brother IntelliFAX 1270E Plain Paper Fax
Fax in memory 04
My fax keeps incoming faxes in the memory and I can figure out how to retrieve them
boyrevel
  • 71 Answers
SOURCE: Sending Faxes
This could be a cable fault. Get BT to do a line test for you (this is free). If that is OK, change the telephone cable. Perhaps this is on an extention cable? Remove it.
Posted on Aug 21, 2007
checkitright
  • 1362 Answers
SOURCE: Brother 4100 Fax Machine / Incoming Faxes
here is the manual
http://www.retrevo.com/s/brother+4100+manual
Posted on Nov 27, 2007
SOURCE: Need to clear the memory of Brother MFC-8220 fax
Menu 2, 5, 1
Set fwd/page/store to *OFF
It will then ask if you want to delete all faxes in memory. Say yes.
Posted on Apr 29, 2008
marsrover
  • 682 Answers
SOURCE: cancel incoming fax's
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_IntelliFax_775_EN_86.PDF
Posted on Aug 03, 2008
FixinFax
  • 3085 Answers
SOURCE: how do i give a fax tone to an incoming fax
Press START
Posted on Oct 17, 2009
Testimonial: "thank you very much this was very helpful it worked like magic. (smile)"
How do i print a fax stored in lexmark x5495 if a fax is sent and does not print out, is it saved anywhere for me to retrieve
When an incoming fax is stored temporarily in the printer's memory, chances are, one of your cartridges has low ink level. To retrieve stored faxes, current state of printer must be on the instance when the fax is temporarily sent to printer's memory. Replace your low-ink cartridge without navigating away from the Fax function. Once you have replaced the cartridge, press Ok button to continue printing the fax.
Jun 21, 2011 | Lexmark X5470 All-In-One InkJet Printer
I want to retrieve a fax sent to me last year
I'm afraid your printer does not have the capability of retrieving faxes sent last year.
The only time you can retrieve faxes is when you get "low ink level" notification while a fax is coming in, where the incoming fax is temporarily stored in the printer's memory. You'll be asked to replace the low ink cartridge (without navigating away from the fax function) then hit Ok to receive the incoming fax. Other than that, you won't be able to retrieve previous faxes.
Apr 10, 2011 | Lexmark X5650 All-in-One InkJet Printer
I can send a fax, but can not retrieve. Line continues to ring,
Press the START button while it is ringing. Scroll through the menus and set your machine to AUTO RECEIVE.
Jan 26, 2010 | HP Office Equipment & Supplies
All recieved faxes going straight to memory
Either it needs toner/drum unit replaced or it's hungry for paper....is it displaying an error code?
Aug 03, 2009 | Canon LaserClass 2050 Plain Paper Fax
OUR FAX SAYS 98% MEMORY FULL SOMETIMES WHEN THEY TRY TO FAX SOMETHING. HOW DO I CLEAR THE MEMORY? NATALIE
Press Menu, 2, 5, 2. The screen prompts you to choose a fax setting. Press <-- or --> to select OFF then press SET. If there are faxes in memory when you turn Fax Storage to OFF, the LCD prompts you to erase faxes in memory. If you press 1, all fax data is erased and Fax Storage is turned OFF.
You may want to enable Real Time TX so you can send fax without using memory. (Under FAX-SETUP SEND-REAL TIME TX)
You may also disable Fax Storage if you don't want to store incoming faxes in memory for remote retrieval (Under FAX- REMOTE FAX OPT-FAX STORAGE)
For effective use of the memory, you may also clear the caller IDs stored in the memory. Press MENU, 2, 0, 2 Press the arrow keys to display # then press CLEAR.
Hope this helps!
Jul 08, 2009 | Brother IntelliFAX 4100 Laser Fax
Retrieval of fax from memory
No. And even if you could, it would simply list the # the fax was received from, and the # of pages. The actual fax is not retained.
May 14, 2009 | Office Equipment & Supplies
When i receive fax,my samsung 4216f didn't print it just save it in momery
receiving incoming fax in the memory, displaying "memory received" but never print out.
I wonder if there is a way to retrieve fax from memory and print out manually?
Feb 22, 2009 | Samsung SCX-4216F All-In-One Laser Printer
Not recieving only in memory
My good friend:
The only reason why your unit stops printin faxes is because the toner cartridge is nearly empty. Th e unit will then try to conserve the remaining toner for printing and copying. Follow this steps to program the unit to print all faxes, even with toner low:
When the toner cartridge is nearly empty, the machine shows
the “[Toner Empty]” message and continues printing except
incoming faxes. In this case, incoming faxes are saved in
memory.
However, you can set the machine to print incoming faxes, even
though print quality is not optimal.
1 Press Menu until “Machine Setup” appears on the display.
2 Press the scroll button ( or ) until “Ignore Toner”
appears on the bottom line and press Enter.
3 Press the Scroll button ( or ) to select “On” or “Off”.
Select “On” to ignore the [Toner Empty] message.
Select “Off” to stop printing incoming faxes when the
message appears. This is the default setting.
4 Press Enter to save the selection.
5 To return to Standby mode, press Stop/Clear.
Be blessed
Jun 15, 2008 | Samsung SCX 4521F All-In-One Laser Printer
Brother IntelliFAX 1270E Plain Paper Fax Logo
21 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
