Question about Maxtor Hard Drive
750gb Power Adapter How much voltage?
  • 37 Answers
3.5drives require 12vdc at no less than 2 amp recomended 12vdc 3amp it is always best to provide more amp for hard drive keep the voltage correct 12vdc
asme adaptors work out to 4 gig drives all my Western digital drive have same power adaptor no matter the Gig size .
Posted on Nov 26, 2014
Need to know input, polarity and voltage to ensure I have the right adapter.
Complete Guide to Using the Correct Charger or Power ...
www.groovypost.com/.../choose-right-power-adapter-charger-phone-lap...
Jun 24, 2013 - If the device has a DC input of +12V / 5.4A, get an adapter that has a DC output of +12V / 5.4A. If you have a universal adapter, make sure it has the proper current rating ... Ideally, you'll have the same voltage, current and polarity on your ......or hdmi on my laptop .can you say what's the reason for the same.
How to select an AC to DC power adapter - ApogeeKits
www.apogeekits.com/power_adapter_selection.htm
An explanation of regulated versus un-regulated AC to DC voltage power adapters. ...voltage output power adapters and how to use this information to select the right one... Some (more expensive) DC voltage output power adapters have voltage ... Care should be take to ensure that the maximum input voltage of the load ...
AC/DC Power adapter ' Laptop Parts 101
www.laptopparts101.com > Laptop parts
Dec 26, 2008 - It's very important to use the right adapter for your laptop. ... Polarityon the new adapter's plug must be the same as on the original ... AC/DC power adapter voltage and amperage ..... I have purchased an non-hp dc-dc convertor (150W), 12Vinput, 19V output. .... So the cable component has to be replace.
Determining Proper A/C Polarity - Galen Carol Audio
www.gcaudio.com > Resources > How-To's
Jan 10, 2016 | Computers & Internet
No power model A8S
If a PC suddenly fails to boot properly, you should perform a hard reset as the first procedure.
  1. Disconnect all peripheral devices and remove all USB devices and media cards. You want to test the computer not the accessories!
  2. Disconnect the AC power adapter, remove the battery, and then press and hold the power button for at least 15 seconds .
  3. Reconnect the AC power adapter (but do not connect the battery), Press the Power button, Look for glowing LEDs near caps lock and num lock keys, and Listen for sounds of a disk drive and fan turning.
  4. if still there no sign of life then send it to nearest service centre
Mar 12, 2014 | ASUS R500N Laptops AMD A8-4500M, 750GB,...
Not power on
For this kind of issue, please follow up the following steps to check:
1.confirm the battery and asus k53 ac adapter connect the laptop normally.Maybe the bad connect lead to this problem. If there are no lights when you turn on laptop, one of possible reason is that your adapter is malfunction.
2.the second possible cause is laptop dc jack failure. If the dc jack is broken or loose, you are required to replace it or repair it.
3.Another possible reason is that there is something wrong with laptop motherboard. For this situation, it includs two kinds of possibility,a failure in an electronic circuit and BGA malfunction.
For more detailed reasons and solutions, please have a look at the following article:
http://www.ifitjams.com/lappower.htm
Jan 07, 2013 | ASUS K53sd 15.6 Inch Laptop Intel Core I7...
Power does not on with adapter
The adapter or the adapter's power lead or the laptop's powersocket could be faulty.Check power adapter's DCplug that connects into the laptop power socket with a multi-meter, the voltageshould be slightly higher than the voltage that is printed on the label on thebottom of the adapter. If the voltage is zero or way below the voltage that isprinted on the label then the power adapter is faulty and needs to be replaced.
Jul 11, 2012 | HEWLETT-PACKARD Commercial PCs HP Smart...
I have no power to my router
The adapter maybe faulty, plug the adapter into the mains outlet and check the voltage on the adapter plug with a multimeter. The voltage on the plug that connect into the router should be slighty higher the the voltage that is printed on the label that is attached to the adapter.
If the voltage is zero or way belew the voltage on the label then the adapter is faulty and needs to be replaced.
Apr 09, 2012 | NetGear WGR614 Wireless Router
I've bougth a Verbatim Hard Drive USB 2.0 750GB 2 years ago. I've used it until yesterday. Now my pc can't recognize the device. "unknown device". How can I solve the problem or how can I...
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
There exist commercial "data recovery" services that can try to repair your device, just long-enough to rescue and copy your files. For example, see: https://services.seagate.com/index.aspx?lng=en-US for a "no data - no charge guarantee".
Nov 17, 2010 | Verbatim External, USB 2.0, 750GB...
WILL NOT CHARGE OR POWER ON
Normal 0 When you connect the power adapter into the laptop, does the power LED light up? If not then -
The battery adapter or the adapter's power lead or the laptop's power socket could be faulty.
Check power adapter's DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced.
Oct 22, 2010 | Acer Aspire 5100 Notebook
My unit is plugged in but dead and cold, no power. Adapter plug is warm. Power outlet is operational. Any thoughts?
Check the output of the adapter plug, it may be warm and functional, but the output connecter may have no output due to an internal break in the wires, usually in the area of the molded strain relief. Some times if you wiggle the wire where the adpater plugs into the device, you will see intermittant operation power. This will indicate either there is a break in the adapter wire or the connector internal to the device is making a poor internal connection. The internal connector may have come loose inside the device as a result of the wear and tear of plugging and unplugging into it. Sometimes these connectors can simply be resoldered and reinforced with a dab of silicone.
Sep 21, 2009 | Maxtor OneTouch 4 Plus 750GB External USB...
Maxtor One-Touch 4 750gb power light flashes and goes out straight away.
Try to remove the drive and connect it directly to another computer.
If still doesn't spin up then most likely the board has failed.
Nov 03, 2008 | Maxtor One-touch III Mini 40 GB USB 2.0...
Maxtor Hard Drive Logo
52 people viewed this question
Top Maxtor Computers & Internet Experts
Computer Links
Rick Arnold
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
