Question about Brother FAX-575 Plain Paper Thermal
Problem sending fax copies. Fax pages are to light to read. It is not the ink
Check the resolution settings. It sounds like you may have it set to "photo" or something similar depending on the terminology "Brother" uses. That produces better quality if your faxing photos, or graphics, but not for text. You want it set to "Standard"
Posted on Jun 23, 2009
U162 error on black ink cannon printer
This error occurs when printer fails detecting ink level or printer assume that no ink in the cartridge. We cannot use print, copy,scan, and fax function before the problem fixed. It's recommended for you to replace ink cartridge. To continue using the printer without replacing the cartridge we must deactivate ink level detection function. Be aware that printing in this condition can damage the printer while sending fax or scan is not problem.
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Original source: http://ij-forum.blogspot.com/2008/12/error-message-check-ink-u162u163.html#ixzz2Cpr4Be1K
Nov 20, 2012 | Canon PIXMA MX340 Wireless Office...
HP 1050 Fax--replaced Ink Jet Cart. and now it will not receive but will send okay!
Please do a copy of any page, if you have a printed copy the ink cartridge is OK and maybe you only have automatic answer turned off.
Mar 02, 2011 | HP 1050 Plain Paper Inkjet Fax
I get lines and can't read the right side of copies that I make with the 1270e. How do I fix this?
You have not specified why you can't read the right side of copies and I am assuming that the reason is because the 'lines' are covering the text. I can offer a solution to the lines issue.
Most likely a fax has been sent or a page copied with 'white out' (Liquid Paper), still wet on the page. As the page feeds over the scanner, (a narrow strip of glass that runs across the width of the page along the feed path) the wet liquid paper comes off on the glass as a thin line and dries. Thereafter, when copying, scanning or sending a fax, the scanner light does not go through the liquid paper streak and the result when printed is a thin vertical line that runs the full length of the page. If this is the cause you will also find that faxes you send to other people will also have this line (although faxes you receive are not affected by this problem with your machine).
To fix the problem: follow the path that the paper travels when sending a fax or making a copy, until you find the scanner (narrow glass strip). Take a clean, soft cloth and a small amount of methylated spirit (or white spirit) and remove the now dried Liquid Paper from the glass. Clean the whole strip ensuring that the glass is left clean and dry.
Feb 22, 2010 | Brother IntelliFAX 1270E Plain Paper Fax
My brother fax machine - only receives black pages
do a quick check on 2 things.
- Copy a document(put a printed page on document feeder and press Copy button) , has the Copy come ok? if copy is also blank that means toner/ink problem, needs to be replaced.
- check with your Fax receive Print settings. is any setting of econo mode/ contrast/brightness Off the track? If found any of such issue then Reset it or put it on average (middle).
Hope this will put your Brother on the track
Jul 14, 2009 | Brother IntelliFAX 4750 Plain Paper Laser...
2 inch vertical solid band on right side when making a copy
There is probably dirt or ink on the scanner glass, this would affect both copying and sending faxes.
Here is a link to the manual and a description on page 74 showing how to clean the glass.
http://www.brother.ca/en/products/pdf/manuals/FAX1270-UG.pdf
Jan 21, 2009 | Brother IntelliFAX 1270E Plain Paper Fax
Blank pages
remove the cartridge and using a damp cloth wipe the ink openings...this might fix the issue.
Oct 01, 2008 | Sharp UX B700 Plain Paper Inkjet Fax
Faxing problems
Are u using a dedicated line for the fax or is it shared.....
If u are using an answering mech...then u need to set the rings...on the fax greater than the answering mech...
Or else Clear the NVRAM....(Note u will loose all the contacts saved in the fax mech)
a. Make sure the printer is in “Copy Mode”.
b. Press the “Menu” button once.
c. The screen will display “COPY MENU: Copies”.
d. Press the left arrow button once. The screen will display “COPY MENU: Tools”.
e. Press the button once. The screen with read “Tools: Maintenance”.
f. Press the button once. The screen with read “Maintenance: Ink Levels”.
g. Press the right arrow button until the screen reads “Maintenance: Print Test Page”.
h. Press the button once.
i. This will start the Self-Test. Once the page has printed, the printer will stop. The test is not continuous.
The printer will prompt u to set it up
Jun 16, 2008 | Lexmark X5470 All-In-One InkJet Printer
ERROR ##331
The level of ink cartridge , can not be detected Solution :
  1. resave the detection level Ink by entering the service mode
  2. replace the ink detector
Jan 11, 2008 | Canon FAX-B840 Plain Paper Bubblejet
Light print of incoming faxes, cannot read
are copies light too? if not then it is sending fax, but most times it is inferior ink or drum causing the problem sometimes damp paper (try printing on reverse side as well)
Oct 31, 2007 | Brother IntelliFAX 2600 Fax
Brother FAX-575 Plain Paper Thermal Logo
46 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
