Question about Futuro Futuro 24-inch Concorde Wall Range Hood
Elica cooker hood manual Ineed to renew the 3 speed switch
How do I remove the panel holding the 3 speed switch?
Have a Neff D9610 cooker hood. Has 3 separate speed switches. Slowest speed switch does not work other ok. No noise from motor when slow switch on. Is the problem with the switch or the motor?
When on high speed the motor is running at it's normal speed.
When a slower speed is selected (mostly) there is external circuitry to reduce the current to the motor so it runs at a slower speed, though in some cases the motor could be specially wound for multiple speeds. The latter way is unlikely to be found in a cooker hood or extractor fan or other small appliance.
The fault with your appliance could be the switch or the current reducing circitry. It is only by delving inside and testing that the fault could be found.
Oct 02, 2016 | Cars & Trucks
Internal fan only works on full blast
The switch is bad, replace the switch
Sep 15, 2011 | 2003 Hyundai Santa Fe
Elite 3 cup rice cooker-need instructions for cooking rice
If you go on this website you can download the manual from the manufacturer of this rice cooker.
www.maxi-matic.com/product.php?productid=48&cat
Regards
Alan Hood
ami-man
UK
Apr 06, 2010 | Salton RA3 3-Cup Rice Cooker
Hi. How can I tell if the charcoal filters in my Smeg cooker hood need replacing? They cost £80 so I don't want to replace them unecessarily.
Firstly operate extractor normally,hold a piece of A4 paper on the underside of fan and see how it holds it on the different speeds.Then if you can remove the charcoal filters then operate as before and compare the difference between the suction,this should tell you if it is the charcoal filters or a blockage in the pipe.
Hope this helps
Jan 25, 2010 | Kitchen Ranges
Elica oven hood fan not working
fan & light on elica extractor fan not working over cooker
Feb 25, 2009 | Kitchen Ranges
Removal of cooker hood to locate electric plug
Thank you for your letter, we had to dismantle the whole cooker hood to get to the electric plug.
Thank you.
Jan 18, 2009 | Kitchen Ranges
Belling DB3 Control Panel
Not easy. Briefly, in addition to the screws you mention, the cooker side panels need to be removed to give access to removal of the control panel side clamps. Then the indicator lamps have to be disconnected, and timer etc. buttons have to be pulled out to allow removal of the the control panel. Then the main control unit (timer etc.) needs to be unscrewed from behind the control panel.
Replacement is reversal of above.
Oct 27, 2007 | Belling DB3 Dual Fuel (Electric and Gas)...
Futuro Futuro 24-inch Concorde Wall Range Hood Logo
56 people viewed this question
Top Futuro Futuro Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Futuro Futuro Kitchen Range Expert? Answer questions, earn points and help others
