Question about Building Materials
How do u program model 139 30498 garage door opener?
  • 118 Answers
SOURCE: jag xj6 1996 97 programming the garage door openers
1. For first time training, press and hold the two outer HomeLink buttons, releasing only when the HomeLink indicator light begins to flash after 20 seconds. (Do not perform this step when training the additional HomeLink buttons.) 2. Position the hand-held transmitter 1-3 inches away from the HomeLink surface (located on your visor), keeping the HomeLink indicator light in view.
3. Using both hands, simultaneously press and hold both the desired HomeLink button and hand held transmitter button. DO NOT release until the HomeLink indicator light flashes slowly and then rapidly. When the indicator light flashes rapidly, both buttons may be released. (The rapid flashing indicates successful training.)
property_damage_symbol_sm.gif Note: Some garage door openers may require you to replace step 3 with the “cycling” procedure noted in the “View Canadian Instructions” section.
4. Press and hold the trained HomeLink button and observe the indicator light.
  • If the indicator light is solid/continuous, training is complete and your device should activate when the HomeLink button is pressed and released.
  • If the indicator light blinks rapidly for 2 seconds and then turns a solid/continuous light, proceed with the following training instructions for a rolling code device. A second person may make the following steps quicker and easier. Please use a ladder or other device. Do not stand on your vehicle to perform the next steps.
5. At the garage door opener receiver (motorhead unit) in the garage, locate the “learn” or “smart” button (usually near where the hanging antenna wire is attached to the unit). If there is difficulty locating the training button, reference the garage door opener’s manual or contact us. 6. Press and release the “learn” or “smart” button (the name and color of the button may vary by manufacturer). NOTE: Once the button is pressed, there are 30 seconds in which to initiate the next step. 7. Return to the vehicle and firmly press and hold the trained HomeLink button for two seconds and release. Repeat the “press/hold/release” sequence up to 3 times to complete the training process.
Posted on Jan 30, 2009
picatudo
  • 239 Answers
SOURCE: Program car to garage opener
on the garage door opener there is a button, that is called the" learning button "you press that button until light blinks, then within 20 seconds press the open button inside car.
Posted on Feb 01, 2009
Doorguy27
  • 30 Answers
SOURCE: i installed a model hd900d
My best advise to you is get the brand name remote for your opener. I know it sounds like a pain but click brands are not super great because there supposed to work for many different kinda. For the most part you can call your local garage door dealer and pick one up for your opener. They may sell you a lift master brand opener which is find sears/liftmaster/chamberlain are all the same. Should only be about 35 bucks if you pick it up
Posted on Feb 10, 2009
SOURCE: programing garage door opener remote
ok crystal,calm down this is an easy one! first locate the smart button on your openers , next you will press and hold down the smart button until you see an indicator light above it shut off, while your holding that button the light will be solid ,Now your ready to program your remotes ,first programm one side by taking each of your four remotes and pressing the smart button on machine then pressing the button on the remote you want to program,by doing that you will notice the lightbulbs on your machine shut off and go back on , This is an indicator that your machine has accepted the code , now do it with the other three remotes , after you,ve programmed all four ,go over to the other machine and repeat the process but this time you have to choose another button on your remotes since you,ve programmed all four remotes to the same button on each remote ,just choose the bottom button on your remotes this time to keep them seperated , hope this helps you and it is as easy as 1-2-3 your owners manual will describe exactly the same ,i know because i,ve installed over 27,000 machines working as an installer for sears, please leave a nice feedback rating if i was able to help you, good luck,Sincerely Glenn Mayer
Posted on Apr 01, 2009
  • 1348 Answers
SOURCE: programming garage door opener
there are three buttons on the opener.hold the 2 outside ones down for 25 to 30 seconds to erase the program. once the light (if equipped)flash rate changes,let go.
then push any one of the the three buttons and hold it in. and then push your remote. when the flash rate changes,the code is now in the homelink transmitter.the slt and slt plus had that feature.
Posted on May 14, 2009
My condo has a Chamberlin Elite Model sl 3000ul3. I have a 2015 Lexus & am having trouble programming the garage door opener with the car. Can you help?
go to manualsonline.com and find the garage door model's manual. read it along with your cars owners manual. make sure you are parked close/under the opener as you try to program for best results.
Nov 27, 2015 | Building Materials
How do I program the garage door opener?
You post again, what the model is of the opener, the car model, it looks like this control is in a car.
Most times you need the garage door remote, then you have to hold a button and the remote button to sync the two.
What ever you are trying to program, if this is a car, you need the manual.
If you need more help, you need to post the model number of everything.
Not every car, every opener is the same at programing.
Imagine that, life simple.
Apr 03, 2013 | Building Materials
Keypad won't program to garage door opener, tried several times, keypad easily programs to 2nd garage door of 3 car garage, but not to main garage door. Need main garage door to open with keypad. Changed...
It sounds like the keypad is not compatible with the main garage door. Make sure the keypad is the correct only for that model number opener. Older models will not work with newer openers and vice versa.
Oct 02, 2010 | Sears Craftsman LiftMaster Chamberlain...
How to change the password on the key pad for a garage door opener model number 13918415
Quick response. Thanks.
To program the keypad first unplug the garage door opener from the electrical outlet. Next remove the nameplate from the console that the keypad plugs into and locate the program/operate switch. Flip the switch to program. Next enter your desired four-digit PIN into the keypad. Slide the switch back to operate and plug the garage door opener back in. The keypad should be programmed.
Sep 17, 2009 | Sears Craftsman LiftMaster Chamberlain...
I have LiftMaster garage door model 41A3039 and Chamberlain wired keypad--how do I change the keypad code to open the garage door
To program the keypad, first unplug the garage door opener from the electrical outlet. Next remove the nameplate from the console that the keypad plugs into and locate the program/operate switch. Flip the switch to program. Next enter your desired four-digit PIN number into the keypad. Slide the switch back to operate and plug the garage door opener back in. The keypad should be programmed.
Jul 13, 2009 | Sears Craftsman LiftMaster Chamberlain...
3 bootons on the key opens both garage door at same time
Reprogram one at a time with others unplugged...no power no programming will be received...pretty simple.
Mar 01, 2009 | Sears Craftsman LiftMaster Chamberlain...
Building Materials Logo
50 people viewed this question
Top Building Materials Experts
hpgwva
Tom Chichester
ray gallant
Are you a Building Material Expert? Answer questions, earn points and help others
