Question about Frigidaire FRS26R4A Side by Side Refrigerator
My cda554 beko refrigerator not cooling - Frigidaire FRS26R4A Side by Side Refrigerator
    Scholar:
  • 123 Answers
Hello there.........is the refrigerator motor running...(not the fan)...if this is running...pull the fridge out for access.....check the smallest diameter pipe on the compressor for heat.(not the small charging stub which goes nowhere)...in normal operation this small pipe should be quite warm to hot.....if its not it is possibly due to an internal gas leak....fridge motor will run but not cool the fridge.....if the motor isnt running but the internal fridge light is on when you oen the door it is possible the thermostat (temp control) needs replacing
Regards Sir Galahad
Posted on Sep 21, 2009
Our Beko upright fridge is not cooling.
There might be several issues with your refrigerator.
First check to see if compressor is running .if not might be bad relay.
If yes check to see if evaporator fan is running .if no replaced .
If freezer is fine and refrigerator is not then you might have a defrost board isdue
Dec 12, 2017 | Beko Refrigerators
I can't find Condenser Coil in Beko FN244 fridge
Good Afternoon GOODGIRL,
I see that you are wondering where the condenser coil and the cooling fan are located on your Beko FN244 refrigerator. I do see that your fridge is based out of the United Kingdom. I suggest contacting the manufacturer in the UK for further assistance. I have been able to locate a telephone number, of 08445 613 613, for your convenience. Hope this is helpful.
-Best Regards-
WP
May 07, 2014 | Frigidaire Refrigerators
Fridge freezer beko problems
Check your condensor fan motor. Which is on the back of refrigerator.
Mar 03, 2014 | Refrigerators
Is it worth getting my fridge freezer fixed?
Check out the start cap/relay on compressor.
Apr 10, 2017 | Refrigerators
Fridge not Woking but freezer is what is possible causesBeko fridge freezer
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
May 14, 2011 | Beko CDA670F (9 cu. ft.) Bottom Freezer...
The fridge part is over cooling, thermostat is at minimum. Almost perfect rectangle of ice on top half of fridge. Not defrosting????
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
Apr 15, 2011 | Beko Refrigerators
I have a beko fridge/freezer, the freezer is working but the fridge is not, help!
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Feb 21, 2011 | Refrigerators
Replacing Beko Upright Refrigerator interior bulb
Try the second screw you wont know till you try it. Im not familiar with this type but if you have tried everything take the second screw out. Let us know how it goes!! BB
Dec 15, 2009 | Refrigerators
Beko fridge freezer not working... not cooling
yes it can b fixed is the fridge running ? if it is it will need re gasing which is a common fault with beko and you should not pay more than £40 for the re gas if it is not running it will b either your thermastat which again you should nt pay more than £48 4 or the compressor which will b aprox £120 supply and fit none of the above should b done by a novice good luck
Sep 07, 2007 | Refrigerators
Frigidaire FRS26R4A Side by Side Refrigerator Logo
386 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
