Question about Delta 23 883 8 Inch Bench Grinder Wheel, 36 Grit Coarse
Need a delta grinding wheel Cat. No 23-583 36 grit coarse AL. OXIDE were can I find one?
    Genius:
  • 1,406 Answers
It doesn't need to be Delta, all it needs is to be 8" diameter, same width (1" or 3/4" or 1/2" or whatever), and have an arbor hole (or plastic adapter) the right size - they're all pretty standard.
You can buy wheels like that locally at your hardware store, or online at Amazon or eBay or Sears or any number of other places. They're nearly as common as dirt, and really inexpensive.
Posted on Jul 28, 2014
I have a Delta 6 bench grinder model #23-680. How do I hold the shaft from turning as I loosen the nut hold the grinding wheel in place?
Hold (or lock) the grinding wheel on the other side if loose or lock because the locking direction is the same direction and don,t forget to ringing (sound-check -like a tuning fork) the stone if you replace it with a new one The risk is small but safety first
Apr 10, 2017 | Delta Grinders
To sharpen tools
The angle things on the grinder are usually set up for drill bits and never moved again. If you need to sharpen your shovel, I would get a 4 1/2 grinder with 80 grit disc in there and grind away from the edge, Not into it, it cuts 10 times faster, cleaner, straighter, than the grinder, use fit or the lawn mower blades too, and the machete, use the grinder for your drill bits and other precision type stuff, don't let the wheels get rounded off or uneven, use a wheel dresser if they do. I have a couple grinders set up in my shop, one wheel for finer stuff, then a wire wheel, then a green wheel for carbide, and then another wire wheel. I use a 1 inch belt for knives and finer stuff, and a 10 disc for serious stuff along with the 48 inch belt. So you can see, I use them a lot. But if you need to use the grinder for your shovel, I would not use the angle stops, I would do it freehand and you can only cut the outside edge, and it will be hard to get it around there. You might have to take the angle stops off. Hope this helps.
Jul 29, 2010 | Delta ShopMaster 8in Grinder with Light...
Delta bandsaw cat. # 28-203 need manual
need a manual for a delta band saw, serial #91F36294, cat.# 28-203. Can you help?
Jan 30, 2010 | Delta Cycle Rothko Rolling Bicycle Stand
Does not grind evenly When I try to grid a coarse grind for french press coffee I get a lot of small grinds.
I was a little confused at first but where ir says coarse on the adjustment "wheel" is actually the fine setting. If you want coarse you need to turn it the opisite direction. If you look cloosely you will notice there is an arrow beside where it says coarse pointing to the right and beside where it says fine there is an arrow pointing left. It kind of makes no sense, but I guess since they've been making it for like 70 years they figure why fix it. I hope this helps, I had the same problem the first time I used mine, and the manual doesn't really mention it.
Nov 04, 2009 | KitchenAid A-9 Electric Burr Grinder
Grinding wheel for Delta bench Grinder where to get one.
It should take a standard grinding wheel, available at almost any hardware store.
Oct 13, 2009 | Delta Grinders
Removing wheels on delta gr450 grinder
They are usually left handed threads so they will self tighten when running. Try turnung then the ither way.
Sep 15, 2009 | Delta GR450 ShopMaster 8'' Variable Speed...
What wheel do I use for grinding chrome
Grinding chrome is not recomended on a bench grinder
Aug 30, 2009 | Baldor Grinders
Use of a Sait Cut abraise wheel to cut PVC Pipe
I worked at a tool rental business while going to college and became familiar with OSHA requirements as it pertains to construction. There is an old saying that if you follow the rule-book by the letter things will quickly come to a grinding halt. I checked on OSHA web site and could not find anything on you question. I recall that using the correct blade only results in a cleaner cut, however there is the possibility that the pvc material can load-up on the blade and cause jambing. An inspection of the blade will answer this. More important is that all safety items are in place like the blade guard and that all workers in the vicinity of the saw are wearing eye protection. We used Norton brand abrasive blades and the following is their guide. APPLICATION GUIDE:
Concrete:
For concrete/masonry - silicon carbide specification for brick, block, concrete, and other masonry materials.
Metal: For metal/steel - aluminum oxide specification for mild steel, stainless, and metal decking.
Asphalt: For use when cutting mostly asphalt.
Asphalt / Green Concrete: For asphalt and green concrete - silicon carbide in coarse grit range. For high performance, hot pressed wheels provide significantly longer life.
Ductile: For ductile iron and cast iron pipe - formulated with a special blend of silicon carbide (for cutting) and aluminum oxide (for long life). This specification is also suitable for cutting PVC.
Hope this helps, enjoy
Dec 09, 2008 | SAIT Portable Saw Cut-Off Wheel TM 12 x...
Delta 23-880 bench grinder
You should be able to hold the grinding wheel with a pair of leather gloves on your hands and lossen the bolt. Look very carefully at the threads to make sure you are trying to lossen and not tighten. Some are left handed threads on bench grinders.
Aug 29, 2008 | Delta ShopMaster 8in Grinder with Light...
Delta 23 883 8 Inch Bench Grinder Wheel, 36 Grit Coarse Logo
402 people viewed this question
Top Delta Grinders Experts
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Delta Grinder Expert? Answer questions, earn points and help others
