Question about Samsung RB215LASH
Water in my crisper draw on my samsung rb215 - Samsung RB215LASH
I need a right hand crisper draw for a Samsung refridgerator model srf680cdls
Hello Kate Nicholas,
Your model srf680cdls... does not respond domestically in the USA... If you provide your ACTUAL PART NUMBER I could attempt to check CRISPER availability ... here (you appear to have an "AU" model.
Just looking around the large plastic body would appear to cost about $60 (USA)... I'm pretty sure we share the MANY of the same internal part numbers..
http://www.woolleys.com.au/?gclid=CPqQzujj184CFQYdaQod1n0AIw
BigWarehouse Spare Parts samsung crisper drawer
Sydney Only Samsung SRF680CDLS 680L French Door Fridge with Water and Ice...
http://www.ebay.com.au/itm/ws/eBayISAPI.dll?ViewItem&item=121998338668&catId=20710&item=121998338668&mid=503315&sdc_id=1081525136346&sortbid=15&rmvSB=true
Samsung 28 15 cu ft 4 Door French Door Refrigerator in Stainless Steel...
http://www.appliancepartspros.com/samsung-case-veg-assy-da97-08437d-ap5805507.html
Aug 23, 2016 | Samsung Refrigerators
How do I put Samsung modal rb215 lash refrigerator in defrost manual? Evaporator keeps freezing up!
defrost system MUST function automatically in order fro refrigeration to function. It sounds like you have a malfunction in the defrost system. Find the time and advance into defrost cycle. If defrost cycle begins (The fridge will stop running and water will start trickling after a few minutes), replace the timer. if not, you may have defective heater or defrost thermostat.
Jul 01, 2015 | Samsung Refrigerators
Water under crisper
Check ur door seals if air gets in it will condensate and accumilate water at bottom, also ur condensation plug line may be blocked or plugged with debris? hence water moister runs down to crisper. u can clean out the line with a thin wire or coat hanger but be careful
Jan 06, 2015 | Samsung RS2534 Side by Side Refrigerator
My crisper drawers collect water
adjust your settings for what you keep in there...and you should be able to solve the problem
Oct 19, 2014 | Samsung RF265AA Bottom Freezer French Door...
RF261BEAESP
Check the pipe that drains the water from the avaperator (the thing that gets cold inside on the fridge)
periodically your fridge will defrost and the water should drip through a tube and collect at the rear of the fridge
If the pipe is blocked the water collects inside at the bottom ( under the crisper)
Apr 15, 2014 | Samsung RF261BEAESP 25.5 cu. ft. French...
Vegetable crisper is filling with water
You may have have your freezer drain stopped up and when it goes into defrost, it melts and the water spills over to the lower section being the crisper. This is a simple fix. You just need to find out where the water is coming from .
Feb 05, 2013 | Samsung RF217ACPN - 20 cu. ft. French Door...
Samsung RB215 -How do you remove the bracket that holds the door
The Cover hinge is misaligned, causing a no cool situation, the door switch and magnet are out of alignment, the door alarm is also on
The Blue arrow shows the hinge improperly aligned, the Yellow arrow shows the correct position of the hinge
f8ccb64.jpg Solution: Using pliers adjust the height of the hinge by pushing it down, the cover hinge will align properly as well as the door switch and the magnet, energizing cooling fan and
having refrigerator cooling properly.
Jul 27, 2009 | Refrigerators
Refrigerator
check behind the drawers is there a water tank for water in thew door that would be my first guess
Feb 10, 2008 | Kenmore 63074 Top Freezer Refrigerator
Crisper door/water line freeze problem
mar...you're box is set too cold. Use -17 C/38 F on the freezer side which is about 38F/4C on the fridge side. Use an outdoor thermometer and let it sit closed for at least a few hours. Adjust accordingly and this will work out. One adjustment is often the cold vents from the freezer into the fridge. If set too wide, too much cold air gets into the crisper and water lines.
Feb 01, 2008 | Maytag MFD2560HES Bottom Freezer French...
Samsung RB215LASH Logo
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
