Question about Electrolux Refrigerators
How do i run a diagnostic check on my electrolux EW28BS71IS4 refrigerator?
How do I run a diagnostic check on my Electrolux EW28BS71IS4 French door refrigerator? my ice maker is giving me problems
2 Suggested Answers
  • 5370 Answers
SOURCE: Electrolux EW28BS71IS4 french door. Refrigerator
The answer to these questions lies in the way the freezer/fridge combo works. The freezer is where the cooling coils are located. Then air is moved over the coils and circulated through the fridge side by a small blower or fan. The problem arises when the air is not circulated for some reason. -------
The reasons the air is not moving is usually two reasons The fan or blower has failed. The coil is covered over with ice and blocks the air flow.
The first reason is pretty simple to fix, you simply replace the air circulator and things are good again. The second reason can be more difficult. 1. The timing device that runs the defrost cycle of the refrigerator is defective. 2. The heater coil that melts the water is shorted or not working
Usually the first thing to check is the heater coil. If there is resistance through the coil then most likely it is still good. The timing device can be an advanced defrost control board or a mechanical timing device. If the heater coil checks out to be good then the problem should be the timer.
For most situations, unplugging the refrigerator and allowing it to defrost on it's own helps.This procedure is called manual defrost reset procedure.You can try this procedure and see if this helps, before replacing any parts.--------
The manual defrost reset procedure is as follows : ----
First unplug the unit from main power outlet. Then empty whole unit completely. Then keep both the doors open. Wait for 24 hours. All the ice collected on the coils and in the freezer section will get melted. Clean the water from the sections. Then Connect the power cord of the unit to main power outlet after 24 hours/.Then set the temperature to normal in both fridge and freezer section. It will take approx 4 to 6 hours more after you reconnect to get proper cooling.Then check, after few hours, do you get cooling in both fridge and freezer section or only in freezer section.-------- if same problem noticed then defrost heater and defrost board parts needs to be tested.--------
You can get required parts from online sites like: --- www.repairclinic.com or from searspartsdirect online site.
----------- This should help. Thanks.Helpmech.
Posted on Aug 24, 2011
Display panel on Electrolux wave touch French door refrigerator will not adjust temperature. Ice or water won't' dispense either.
Hello friend, thank you for your post!
Based off the information you are describing it sounds like your control panel is locked. Can you check to see if the control lock is lit up? If so, please hold down the control lock button for 3 seconds and it should allow you to operate the front panel. If not you could be experiencing a problem within your control panel and may need to have a professional come out to diagnose it. I hope this helps. -Matt
Sep 10, 2014 | Electrolux EI23BC56IS (226 cu ft) Bottom...
Electrolux diagnostics for refrigerator with freezer on bottom
Hey friend, thank you for your post!
Based off the information you have provided your Electrolux refrigerator is running but not cooling. It could be possible that your refrigerator is stuck in a defrost mode. I would suggest resetting your appliance which can be done by flipping the household circuit breaker for roughly ten minutes. If that does not correct the issue I would seek assistance from a professional to come repair your appliance. -Matt
Aug 18, 2014 | Electrolux EW28BS71IS (278 cu ft) Bottom...
Can I turn off the freezer but not the fridge on my electrolux french door bottom freezer refrigerator
Unfortunately, the lower frizzer is connected straight to the primary engine. It can't be turned off, unless you turn off the whole fridge. I know, it will be smart for Electrolux to allow that option at a consumer's discretion: to be able to turn the bottom fridge on/off.
Aug 09, 2014 | Electrolux Refrigerators
Refrigerators Logo
62 people viewed this question
Top Electrolux Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Electrolux Refrigerator Expert? Answer questions, earn points and help others
