Question about Sewing Machines
How to thread kenmore 1950280 sensor sew 70 - Sewing Machines
2 Suggested Answers
radiohead68
SOURCE: serger
As long as this is a sewing machine and not a serger, I don't know about them. I only tinker on my own. Remove the bottom. There is a rod running along the length of the machine. it needs to be turned 180 degrees. You may need to retime the machine.
Posted on May 29, 2009
I got the Sliding Buttonhole Foot for my Kenmore Sensor 70 Model 385-19950180 but the manual has little information on how to use it. Is there a video where I can learn?
There are a lot of videos on YouTube. Just search for something like: sewing machine buttonhole
Most sliding buttonhole accessories work the same from machine to machine.
May 22, 2017 | Kenmore Sewing Machines
How old is my sears Kenmore sensor sew 70 model# 3851950180? Iwould like to know if it can be repaired
Almost any machine CAN be repaired, but it may not be worth the money to get it repaired and with older machines finding parts can be a real problem.
If you call Sears and tell them the model and serial number they should be able to tell you the age of the machine, and whether or not they are still willing to repair a machine like it. They may not have parts though.. sometimes independent repair shops are a better bet. Ebay is often a good source for old machine parts too.
Nov 18, 2014 | Kenmore Sewing Machines
I have a Kenmore sewing machine - 12 stitch model which I bought in the 70's. I am having a tension problem and can't seem to fix it. What is the normal setting for the top, and bottom?
Hello
Load your Kenmore sewing machine with the right thread and bobbin thread for your project. If you use the wrong weight thread for your fabric or severely uneven weights of thread, this can cause the appearance of a tension problem when it is, in fact, a thread weight problem or a problem with your sewing speed. If you go too fast, you will break the thread. If you go too slow, you can cause loops. Uneven pressure can cause stitches to vary greatly.
Test your Kenmore sewing machine's tension by sewing on a piece of scrap fabric. If your tension is way off, then test on some basic cotton or a firm blend simply to get your tension right. Do not try to start adjusting your tension on silk or leather. Get a base adjustment on a more standard fabric first.
Look at the top threads and bottoms threads. If the tension is off on one side, it will usually affect the other side slightly. So select the side that looks more maladjusted to start adjusting the tension.
If the top thread is too loose or too tight, you will need to adjust the tension dial. This dial is usually located a few inches above the needle on the Kenmore machine body. Usually, your machine will have markings to indicate which direction tightens the tension. If these have worn off over the years, watch the dial as you turn it. If it appears to move toward the machine body, then it is tightening.
If the bottom thread is too loose or too tight, then you will need to open the door to the bobbin case. On some Kenmore models, there is a little screw near the bobbin case that can be adjusted slightly to adjust the tension. On other Kenmore models, there is a screw on the bobbin case itself--not on the bobbin, but on the bobbin's casing. This will also adjust the bottom thread tension. Adjust the bobbin thread tension to make slight changes.
If the thread is looping severely on one side, the thread weights might be off. For instance, look to see if you have a lightweight thread on the bobbin and a heavyweight one on the top. If the thread keeps breaking, the top tension or bottom tension could be too tight or the thread is too lightweight for the material you have selected. Check your combination of threads and material. Also make sure you are using the right weight needle and the right foot for the sewing step or project you are working on.
If your Kenmore sewing machine's tension is off severely or if you have not used your Kenmore in a long time, then you might need to take your machine in to be serviced. Sometimes, the inner parts need to be oiled or the entire machine might need to be cleaned and calibrated by a professional. If you sew a great deal or if your machine sits idle a lot, both situations will usually require some servicing to keep your Kenmore sewing machine and its tension in perfect working condition.
Jul 11, 2011 | Kenmore 15358
Older Kenmore sewing machine stops due to threads bunched
Mary, just re-thread the upper and make sure the threaded is seated between the tension disc
Aug 01, 2010 | Kenmore 11101 Mechanical Sewing Machine
Kenmore 27-stitch machine jamming badly in bobbin
Sounds like a timing issue. Did you attempt to force fabric through too quickly? Sometimes this can alter the bobbin's tension, and alter the timing of the machine as a whole as well. Not a cheap fix, sadly(Local to me, for example, this will cost about 70 bucks to have fixed. Do NOT try to do this yourself, leave it to the professionals, there are more moving parts in a sewing machine than in a space shuttle.)
Apr 23, 2010 | Kenmore Drop-In Bobbin 16231 Mechanical...
Turns on does not work
It probably has a bad circuit board, I don't think they are available though.
Sorry!
Jan 27, 2009 | Kenmore 19233 Computerized Sewing Machine
Serger
Oct 03, 2008 | Kenmore 19233 Computerized Sewing Machine
Kenmore sewing machine model 385 16764
There's a website called managemyhome.com which is sponsored by Sears. It's free to join. Go to the Home Manager column and choose Owner's Manuals from the drop down menu.
You can type in the brand name (Kenmore) and model number of your machine. Not all of them are in there but, I did find the one for the 1950280 question. It's a pdf file.
For the 38516764 question, please double check your model number. I received either no response or a Kenmore Elite dishwasher manual in response to my query.
Apr 10, 2008 | Kenmore Drop-In Bobbin 505S-21BH...
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
