Question about Konica Minolta Bizhub 501 Copier
C2801 konica minolta bizhub 600 error code c2801
  • Konica Minolta Master
  • 6,161 Answers
Might want to have the developer replaced and drum/cleaning blade normally done all together, then run the F8 procedure and make sure the counters where cleared. Did you recently replace the drum and the developer if so did you clear the counters for the drum and developer, FIRST? IF not then the copier thinks the new drum and new developer are old. The copier works on the counters that is how it knows it got a new drum and developer. Get new developer and a new drum and have it installed correctly. Counters are clear before the unit is yanked out of the machine, then you remove the image unit/drum unit replace the developer/drum and cleaning blade. (DO NOT USE A VACUUM CLEANER WHEN REPLACING THE DEVELOPER static electricity can destroy the sensor located below the developer unit. Then reinstall and RUN F8. Make sure the fax line and Ethernet cable is removed can't print anything until the F8 is run. Or you will start all over again with new developer and a new drum.
Posted on Dec 29, 2015
SOURCE: konica minolta bizhub 350
• The Fusing Roller Sub Thermistor does not
detect the required temperature within 30 sec.
after a warm-up cycle has begun; therefore, the
copier does not complete the warm-up cycle.
• The temperature of the Fusing Rollers does not
reach the required level even after the set period
of time has elapsed during a warm-up cycle.
Check that the H1[ fuser lamp] comes on when the Main Power
Switch is set to ON, and correct or replace as necessary.
Check that the H2 comes on when the Main Power
Check the installation of the TH1 and the TH2, and
correct or clean as necessary.
Check the operation of the TH1.
Remove CN80 (4P), and then check that the resistance
across CN80-2 and -3 on the Thermistor is
infinity.
5
Check the operation of the TH2.
Remove CN81 (4P), and then check that the resistance
across CN81-2 and -3 on the Thermistor is
infinity.
6
Check the continuity of the H1.
Correct or replace as necessary.
7
Check the continuity of the H2.
8 Change PU1 - -
9 Change PWB-A
Posted on Nov 19, 2007
oranous_comp
SOURCE: proplem with KONICA MINOLTA bizhub C450
c-3451
Posted on Nov 10, 2008
firecontrol7
  • 6161 Answers
SOURCE: KONICA MINOLTA BIZHUB C350 WITH ERROR CODE C0960
Check your bypass tray, the tray is on the right side of the machine, the tray flips out for legal and 11x17 paper sizes. Check that there is nothing jamed inside, code says that the tray can't lift. so check for anything jamed inside down there. As to reset the code open then close the front door where you put the toner. Turning the machine on and off will not reset the code. but open and closing the front door will clear about 80% of the service codes.
Posted on Jul 25, 2009
SOURCE: Error code C-0211 Konica Minolta Bizhub C-351
I have a Konica bizhub c351 with and error code of c0211. I took the back off and played with the black motor that lifts the tray. The tray moves freely and the motor seems to move freely. When I turn the machine on it does not go through any kind of check like it did before it just goes to the same screen. Is there a way to reset this to get it going again to test if there is still a problem
Posted on Nov 03, 2009
xeerie
  • 347 Answers
SOURCE: desbloqueo del codigo m2 en konica minolta bizhub 163
Este código significa que la vida las partes de su desarrollo + unidad de imagen se ha caducado. Ahora es el momento de reemplazar las partes.
Posted on Jun 19, 2010
How to reset error code 3505 in konica minolta bizhub 600
When you reinstalled the upper and lower fused rollers mite have flipped the sensor so it's not riding on the fuser roller
Dec 31, 2014 | Konica Minolta Bizhub 600 750 Image...
C2801 konica minolta bizhub 501
TCR output abnormality. What is the status of your consumables (drum and developer)? You might need to replace the developer. Also, you should check if the toner bottle is turning; you should see it turning while the front cover door is open and the machine operates; if it is not turning, it is possible that the toner bottle was inserted wrong (by force).
Konica Minolta Error Codes & Solutions - http://www.kmcodes.com
Drum, Transfer Belt and Fusing Unit Firmware Reset - http://www.bizhubreset.com
Drum and Toner Chip Reset - http://www.chipreset.eu
Transfer Belt and Fusing Unit Reset Kit - http://www.resetkit.eu
Aug 15, 2014 | Konica Minolta bizhub Office Equipment &...
Konica bizhub 501 take code c2806
actually code c28xx have 7 variant. for example, c2801, c2802, c2803 (error 3,4,5,6) and c2804. if follow the code code c28xx is TCR output abnormality.
ok, first you clean T/S block, do servicing and cleaning all parts.
second, if still same, do toner auto supply.
third, trouble reset. off your machine first, press and hold utility/counter and on machine, until trouble reset appear. press it and off/on again. ^^,
Oct 05, 2013 | Konica Minolta Bizhub 501 Copier
Error code c6708
Please send me konica minolta bizhub 600 full service manual and help us this code c6708 still and my next machine bizhub 750 still warming up why problem this machine please help and send me your email address.
i want to talk to you continuous
May 18, 2013 | Konica Minolta Developer 02xk Dv710 for...
Error code c2801
Maximum density correction problem.Clean the AIDC sensor located under OPC drum.
Mar 19, 2013 | Konica Minolta Konica Kit For Bizhub Press...
My konica minolta bizhub 361 has an error code c-2801.... what does that mean?
In my experience you have to change the developer and the machine will be ok.Also there is a chance that you have to clean the two toner sensor that are located in the end of the toner bottle,sometimes there is the problem.please let me know.
Aug 16, 2011 | Konica Minolta bizhub C351 All-In-One...
Please: malfunction detected c2801 konica minolta starter
bizhub 600/750 warming up and error 2801
please help
Nov 22, 2010 | Office Equipment & Supplies
Konica Minolta Bizhub 501 Copier Logo
831 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
